Posted
I finally figured out how to make put an oval frame on my picture.  I would like to put a border around it.  I do need to go through all the basic tutorials but this is something I need right away.  Thank you for your help.
Posted
Hi rsrusher1957, welcome :D
If your oval frame is on its own layer (it should be), you can add a border using one of the Outline Object plugins. Check out the Plugin Index link in my Sig to find the plugins.
Posted
Hi rsrusher!
You can also make yourself.
Link:  http://forums.getpaint.net/index.php?/topic/30186-easy-photo-frame-rectangular-circular-and-elliptical/
Gandhi
