Lockz Posted September 2, 2013 Share Posted September 2, 2013 Hi I'm making a map for Dungeons and Dragons using a rather large resolution. 20,000x13,332 @ 300 pixels per inch. My max zoom is @ 164% when I try to just it further the Zoom percentage increases but the image doesn't actually zoom. Which I'm having a hard time adjusting small details with, any ideas on how to increase how far I can zoom? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 2, 2013 Share Posted September 2, 2013 Version 3.5.x has a limitation in that (image size) X (zoom level) cannot exceed ~32,767 pixels on either side (width or height). 20,000 x 164% = 32,800 pixels. So it sounds like this is exactly what you're bumping into. Version 4.0 completely removes this limitation (sorry, it's not available yet because it isn't done). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted September 2, 2013 Share Posted September 2, 2013 @Lockz: I recommend you seriously consider making the map in smaller segments. You could use two halves (at 10,000 x 13,332) or even four quarters. The reason is that the memory overhead for such a large image is going to quickly overwhelm your system. Roughly, your very large image is going to need 3gb of RAM + 1gb for each additional layer. See: http://forums.getpaint.net/index.php?/topic/8606-out-of-memory-to-loadedit-an-image-read-this-first/ Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
pdnnoob Posted September 2, 2013 Share Posted September 2, 2013 If you do take EER's advice (I highly recommend you take it...), it helps to make your map pieces overlap a little on the edges so it's easier to make it seamless. Quote what I do all summer Emote Cursor Pack 'noob gallery No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
BoltBait Posted September 2, 2013 Share Posted September 2, 2013 Have you considered a vector editor for your project? Inkscape is free and good. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Rick Brewster Posted September 2, 2013 Share Posted September 2, 2013 The reason is that the memory overhead for such a large image is going to quickly overwhelm your system. Roughly, your very large image is going to need 3gb of RAM + 1gb for each additional layer. Pffft RAM is cheap Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
