light blub , light glow effect ?
Hi all
I used to have an effect that creates a light bulb, light glow around its
surrounding area.
it also had the option to select light color , adjust the light angles and light rays radius.
( i thing the transperency too)
can someone point me to that missing effect plugin.
thank you
Avi
Edited by avim1968
"DDAP=Don't Drink And Post!" :-)
The description sounds like my 'highlight' plugin. link below shows UI or in the pack - link in sig.
http://forums.getpaint.net/index.php?/topic/21835-highlight-now-in-red-ochre-plugin-pack/#entry354238
(sorry pdnnoob, it really does sound like it - not just plugging the plug-in - honest! :lol: )
I can feel an new award forming: "Shameless Self Promotion"
(I'm guilty for references to the Plugin Index - WHICH YOU CAN FIND HERE: Plugin Index by EER)
:lol:
Actually, I was going to suggest that myself, but I got the two confused xD I would say it matches the description perfectly!
@EER It sounds like such a negative award until you know the stories behind it...I like it! :D
You're earning it one post at a time. I'm keeping my eye on you... :cyclops:
