Color wheel and Layers suddenly not responding
Go to solution Solved by toe_head2001,
I've searched the site (and elsewhere) for the answer to this but haven't found anything; if I'm overlooking something obvious, my apologies.
I've been using version 5.0.7 very successfully but on running it today I found that the colour wheel and layer windows wouldn't open.  Neither clicking the top-right icons or pressing the appropriate function keys called them up.  I opened a pdn image which I know to consist of multiple layers but those layers weren't recognised; and trying to add a new layer to an existing picture or a newly-created one also produces no result.
I suspect of course that the problem lies with my computer, though I can find nothing amiss with any other image editing programs (or indeed anything else):  I'm running Paint.net on a desktop PC under Windows 10 Home Professional v22H2 and I've made no changes to anything major since the last time I successfully used the program.  Virus and unwanted program searches found nothing.
I'd be very grateful for any thoughts or advice.  Many thanks.
Edited by Bert Coules
I'm sorry but we can't provide help with older versions of paint.net.       Oops - mis-read this.
Can you post the Diagnostics please:
Pixey, thanks for your speedy reply.  Should I simply paste the copies dignostics window here?  I'll try that and see what happens...
Application                                          paint.net 5.0.7 (Stable 5.7.8575.34822)
Build Date                                           24 June 2023
Install type                                         Classic
Language:                                            en-US
DPI                                                  144 (1.50x scale)
UI/Canvas GPU                                        True
Rendering GPU                                        🚀 Performance (Intel(R) HD Graphics 530)
Remote session                                       False
Animations                                           True
Translucent windows                                  True
Windows Ink                                          True
OS                                                   Windows 10 Pro x64 (10.0.19045.0)
Runtime                                              .NET 7.0.8 x64
Physical Memory                                      16,270 MB (11,668 MB free)
Virtual Memory                                       133,947,906 MB free
Paging File                                          18,702 MB (13,414 MB free)
CPU                                                  Intel(R) Core(TM) i5-6400 CPU @ 2.70GHz
    Speed                                            ~2712 MHz
    Cores / Threads                                  4 / 4
    Features                                         SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX, AVX2
Video Card                                           Intel(R) HD Graphics 530
    Hardware Acceleration                            Supported
    Dedicated Video RAM                              128 MB
    Dedicated System RAM                             0 MB
    Shared System RAM                                8,135 MB
    Vendor ID                                        0x8086
    Device ID                                        0x1912
    Subsystem ID                                     0x86941043
    Revision                                         6
    LUID                                             0x00015C0A
    Flags                                            AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                              TriangleBoundary
    Compute Preemption                               ThreadBoundary
    Outputs                                          2
    Feature Level                                    Level_12_1
    Features                                         Doubles, ComputeShadersEtc
    DXGI Formats                                     A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float
    Buffer Precisions                                UInt8Normalized, UInt8NormalizedSrgb, UInt16Normalized, Float16, Float32
    Maximum Bitmap Size                              16384
Video Card                                           Microsoft Basic Render Driver
    Hardware Acceleration                            N/A
    Dedicated Video RAM                              0 MB
    Vendor ID                                        0x1414
    Device ID                                        0x008C
    Subsystem ID                                     0x00000000
    Revision                                         0
    LUID                                             0x00015FA4
    Flags                                            Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance
    Graphics Preemption                              InstructionBoundary
    Compute Preemption                               InstructionBoundary
    Outputs                                          0
    Maximum Bitmap Size                              8388608
Managed assemblies                                   150
    System.Private.CoreLib                           .\System.Private.CoreLib.dll, Version=7.0.0.0, PublicKeyToken=7cec85d7bea7798e
    paintdotnet                                      .\paintdotnet.dll, Version=5.7.8575.34822
    System.Runtime                                   .\System.Runtime.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Fundamentals                         .\PaintDotNet.Fundamentals.dll, Version=5.7.8575.34822
    PaintDotNet.ComponentModel                       .\PaintDotNet.ComponentModel.dll, Version=5.7.8575.34822
    System.Windows.Forms                             .\System.Windows.Forms.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Diagnostics.Tracing                       .\System.Diagnostics.Tracing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Thread                          .\System.Threading.Thread.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Base                                 .\PaintDotNet.Base.dll, Version=5.7.8575.34822
    PaintDotNet.Collections                          .\PaintDotNet.Collections.dll, Version=5.7.8575.34822
    PaintDotNet.Systrace                             .\PaintDotNet.Systrace.dll, Version=5.7.8575.34822
    PaintDotNet.Windows                              .\PaintDotNet.Windows.dll, Version=5.7.8575.34822
    TerraFX.Interop.Windows                          .\TerraFX.Interop.Windows.dll, Version=10.0.22621.2, PublicKeyToken=35b01b53313a6f7e
    PaintDotNet.Primitives                           .\PaintDotNet.Primitives.dll, Version=5.7.8575.34822
    System.Collections.Concurrent                    .\System.Collections.Concurrent.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Runtime                              .\PaintDotNet.Runtime.dll, Version=5.7.8575.34822
    PointerToolkit                                   .\PointerToolkit.dll, Version=1.0.0.0
    System.Threading                                 .\System.Threading.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.SystemLayer                          .\PaintDotNet.SystemLayer.dll, Version=5.7.8575.34822
    System.Diagnostics.Process                       .\System.Diagnostics.Process.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Uri                               .\System.Private.Uri.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.Primitives                 .\System.ComponentModel.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    WindowsBase                                      .\WindowsBase.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Windows.Forms.Primitives                  .\System.Windows.Forms.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    PresentationFramework                            .\PresentationFramework.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Runtime.InteropServices                   .\System.Runtime.InteropServices.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xaml                                      .\System.Xaml.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Drawing.Primitives                        .\System.Drawing.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel                            .\System.ComponentModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.TraceSource                   .\System.Diagnostics.TraceSource.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.ObjectModel                          .\PaintDotNet.ObjectModel.dll, Version=5.7.8575.34822
    System.Collections                               .\System.Collections.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.CodePages                   .\System.Text.Encoding.CodePages.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    Microsoft.Win32.Primitives                       .\Microsoft.Win32.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Core                                 .\PaintDotNet.Core.dll, Version=5.7.8575.34822
    PaintDotNet.Resources                            .\PaintDotNet.Resources.dll, Version=5.7.8575.34822
    System.Configuration.ConfigurationManager        .\System.Configuration.ConfigurationManager.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.ObjectModel                               .\System.ObjectModel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.Specialized                   .\System.Collections.Specialized.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Data                                 .\PaintDotNet.Data.dll, Version=5.7.8575.34822
    System.Xml.ReaderWriter                          .\System.Xml.ReaderWriter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Framework                            .\PaintDotNet.Framework.dll, Version=5.7.8575.34822
    CommunityToolkit.HighPerformance                 .\CommunityToolkit.HighPerformance.dll, Version=8.2.0.0, PublicKeyToken=4aff67a105548ee2
    System.Private.Xml                               .\System.Private.Xml.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Threading.ThreadPool                      .\System.Threading.ThreadPool.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Windows.Framework                    .\PaintDotNet.Windows.Framework.dll, Version=5.7.8575.34822
    Microsoft.Win32.SystemEvents                     .\Microsoft.Win32.SystemEvents.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Drawing.Common                            .\System.Drawing.Common.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Net.WebClient                             .\System.Net.WebClient.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PaintDotNet.UI                                   .\PaintDotNet.UI.dll, Version=5.7.8575.34822
    System.ComponentModel.EventBasedAsync            .\System.ComponentModel.EventBasedAsync.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Linq                                      .\System.Linq.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.Immutable                     .\System.Collections.Immutable.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.FileVersionInfo               .\System.Diagnostics.FileVersionInfo.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Memory                                    .\System.Memory.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    Microsoft.Win32.Registry                         .\Microsoft.Win32.Registry.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.Encoding.Extensions                  .\System.Text.Encoding.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Security.Principal.Windows                .\System.Security.Principal.Windows.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    ComputeSharp.D2D1                                .\ComputeSharp.D2D1.dll, Version=2.0.3.0
    System.Security.Claims                           .\System.Security.Claims.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.ComponentModel.TypeConverter              .\System.ComponentModel.TypeConverter.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Windows.Core                         .\PaintDotNet.Windows.Core.dll, Version=5.7.8575.34822
    PaintDotNet.PropertySystem                       .\PaintDotNet.PropertySystem.dll, Version=5.7.8575.34822
    PresentationCore                                 .\PresentationCore.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    PaintDotNet.Effects.Core                         .\PaintDotNet.Effects.Core.dll, Version=5.7.8575.34822
    System.IO.Packaging                              .\System.IO.Packaging.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    DirectWriteForwarder                             .\DirectWriteForwarder.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    Accessibility                                    .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35
    System.Runtime.Extensions                        .\System.Runtime.Extensions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.Debug                         .\System.Diagnostics.Debug.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.CompilerServices.VisualC          .\System.Runtime.CompilerServices.VisualC.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Collections.NonGeneric                    .\System.Collections.NonGeneric.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Numerics.Vectors                          .\System.Numerics.Vectors.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    UIAutomationTypes                                .\UIAutomationTypes.dll, Version=7.0.0.0, PublicKeyToken=31bf3856ad364e35
    Crc32.NET                                        .\Crc32.NET.dll, Version=1.0.0.0, PublicKeyToken=dc0b95cf99bf4e99
    System.Security.Cryptography                     .\System.Security.Cryptography.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects.Gpu                          .\PaintDotNet.Effects.Gpu.dll, Version=5.7.8575.34822
    PaintDotNet.Effects                              .\PaintDotNet.Effects.dll, Version=5.7.8575.34822
    System.Threading.Tasks.Parallel                  .\System.Threading.Tasks.Parallel.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Reflection.Metadata                       .\System.Reflection.Metadata.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.IO.MemoryMappedFiles                      .\System.IO.MemoryMappedFiles.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Reflection.MetadataLoadContext            .\System.Reflection.MetadataLoadContext.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Runtime.Loader                            .\System.Runtime.Loader.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PhotoShop                                        .\FileTypes\PhotoShop.dll, Version=2.5.0.40665
    AnimGIF                                          .\FileTypes\AnimGIF.dll, Version=2.4.4119.28305
    mscorlib                                         .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    System.Drawing                                   .\System.Drawing.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System                                           .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    DdsFileTypePlus                                  .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.11.9.0
    AvifFileType                                     .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.25.0
    Newtonsoft.Json                                  .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed
    WebPFileType                                     .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.17.0
    System.Runtime.Serialization.Formatters          .\System.Runtime.Serialization.Formatters.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Linq.Expressions                          .\System.Linq.Expressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Text.RegularExpressions                   .\System.Text.RegularExpressions.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Runtime.Numerics                          .\System.Runtime.Numerics.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Effects.Legacy                       .\PaintDotNet.Effects.Legacy.dll, Version=5.7.8575.34822
    Mono.Cecil                                       .\Mono.Cecil.dll, Version=0.11.5.0, PublicKeyToken=50cebf1cceb9d05e
    netstandard                                      .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Runtime.Intrinsics                        .\System.Runtime.Intrinsics.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    PhotoSauce.MagicScaler                           .\PhotoSauce.MagicScaler.dll, Version=0.13.2.0, PublicKeyToken=fc6b9b7b06809481
    PointerToolkit.TerraFX.Interop.Windows           .\PointerToolkit.TerraFX.Interop.Windows.dll, Version=10.0.22621.0
    System.Net.Http                                  .\System.Net.Http.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.Primitives                            .\System.Net.Primitives.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Diagnostics.DiagnosticSource              .\System.Diagnostics.DiagnosticSource.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    System.Net.Security                              .\System.Net.Security.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.Quic                                  .\System.Net.Quic.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    OilPaintingPlus                                  C:\Users\bert\Documents\paint.net App Files\Effects\OilPaintingPlus.dll, Version=4.6.7358.38406
    System.Net.Sockets                               .\System.Net.Sockets.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    PaintDotNet.Plugins.Compatibility                .\PaintDotNet.Plugins.Compatibility.dll, Version=5.7.8575.34822
    System.Console                                   .\System.Console.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Threading.Overlapped                      .\System.Threading.Overlapped.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Net.NameResolution                        .\System.Net.NameResolution.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Private.Xml.Linq                          .\System.Private.Xml.Linq.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    GridCheckerboard                                 C:\Users\bert\Documents\paint.net App Files\Effects\GridCheckerboard.dll, Version=4.5.6828.36789
    GaussianBlurPlus                                 C:\Users\bert\Documents\paint.net App Files\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401
    Flip                                             C:\Users\bert\Documents\paint.net App Files\Effects\Flip.dll, Version=4.6.7358.36953
    Dimensions                                       C:\Users\bert\Documents\paint.net App Files\Effects\Dimensions.dll, Version=1.3.6826.38472
    ComputeSharp.Core                                .\ComputeSharp.Core.dll, Version=2.0.3.0
    CreativeTextPro                                  C:\Users\bert\Documents\paint.net App Files\Effects\CreativeTextPro.dll, Version=1.1.7358.34307
    SeamCarving                                      C:\Users\bert\Documents\paint.net App Files\Effects\SeamCarving.dll, Version=4.6.7358.39596
    BBOutlinedGradientText                           C:\Users\bert\Documents\paint.net App Files\Effects\BBOutlinedGradientText.dll, Version=4.6.7358.38713
    BBChart                                          C:\Users\bert\Documents\paint.net App Files\Effects\BBChart.dll, Version=1.0.7358.33924
    ThatOtherApp                                     .\Effects\ThatOtherApp.dll, Version=2.2.0.0
    System.Windows.Forms.Legacy                      .\System.Windows.Forms.Legacy.dll, Version=1.0.0.0
    PresentationFramework-SystemXmlLinq              .\PresentationFramework-SystemXmlLinq.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    EditableText                                     .\Effects\EditableText.dll, Version=1.0.1.0
    System.Xml.XDocument                             .\System.Xml.XDocument.dll, Version=7.0.0.0, PublicKeyToken=b03f5f7f11d50a3a
    System.Xml.Linq                                  .\System.Xml.Linq.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089
    SBCommon                                         .\Effects\SBCommon.dll, Version=3.0.0.0
    PrinterPlus                                      .\Effects\PrinterPlus.dll, Version=1.5.0.0
    Olden                                            .\Effects\Olden.dll, Version=1.5.0.0
    FindEdges                                        .\Effects\FindEdges.dll, Version=1.2.0.0
    System.IO.Compression                            .\System.IO.Compression.dll, Version=7.0.0.0, PublicKeyToken=b77a5c561934e089
    ExtendBorder                                     .\Effects\ExtendBorder.dll, Version=1.3.0.0
    System.CodeDom                                   .\System.CodeDom.dll, Version=7.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51
    DragFrom                                         .\Effects\DragFrom.dll, Version=1.1.0.0
    Borders N' Shapes                                .\Effects\Borders N' Shapes.dll, Version=4.0.4642.26476
    K4os.Compression.LZ4                             .\K4os.Compression.LZ4.dll, Version=1.2.16.0, PublicKeyToken=2186fa9121ef231d
    CustomBrushesMini                                .\Effects\CustomBrushesMini.dll, Version=2.2.5286.39584
    FloydSteinbergDithering                          C:\Users\bert\Documents\paint.net App Files\Effects\FloydSteinbergDithering.dll, Version=4.6.7358.37110
    VignettePlus                                     C:\Users\bert\Documents\paint.net App Files\Effects\VignettePlus.dll, Version=4.6.7358.40027
    HSVGradients                                     C:\Users\bert\Documents\paint.net App Files\Effects\HSVGradients.dll, Version=4.5.6832.41864
    HueSatPlus                                       C:\Users\bert\Documents\paint.net App Files\Effects\HueSatPlus.dll, Version=4.6.7359.209
    Landscape                                        C:\Users\bert\Documents\paint.net App Files\Effects\Landscape.dll, Version=4.6.7358.37463
    Pastel                                           C:\Users\bert\Documents\paint.net App Files\Effects\Pastel.dll, Version=4.6.7358.38877
    PasteAlpha                                       C:\Users\bert\Documents\paint.net App Files\Effects\PasteAlpha.dll, Version=4.6.7358.38804
    PhotoAdjustments                                 C:\Users\bert\Documents\paint.net App Files\Effects\PhotoAdjustments.dll, Version=4.6.7358.38979
    Polygon                                          C:\Users\bert\Documents\paint.net App Files\Effects\Polygon.dll, Version=4.5.6828.38648
Native modules                                       311
    paintdotnet.exe                                  .\paintdotnet.exe, version=5.7.8575.34822
    ntdll.dll                                        C:\Windows\SYSTEM32\ntdll.dll, version=10.0.19041.2788 (WinBuild.160101.0800)
    KERNEL32.DLL                                     C:\Windows\System32\KERNEL32.DLL, version=10.0.19041.3155 (WinBuild.160101.0800)
    KERNELBASE.dll                                   C:\Windows\System32\KERNELBASE.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    SHELL32.dll                                      C:\Windows\System32\SHELL32.dll, version=10.0.19041.964 (WinBuild.160101.0800)
    msvcp_win.dll                                    C:\Windows\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800)
    ucrtbase.dll                                     C:\Windows\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800)
    USER32.dll                                       C:\Windows\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    win32u.dll                                       C:\Windows\System32\win32u.dll, version=10.0.19041.3208 (WinBuild.160101.0800)
    GDI32.dll                                        C:\Windows\System32\GDI32.dll, version=10.0.19041.2913 (WinBuild.160101.0800)
    gdi32full.dll                                    C:\Windows\System32\gdi32full.dll, version=10.0.19041.2913 (WinBuild.160101.0800)
    ole32.dll                                        C:\Windows\System32\ole32.dll, version=10.0.19041.1320 (WinBuild.160101.0800)
    RPCRT4.dll                                       C:\Windows\System32\RPCRT4.dll, version=10.0.19041.2788 (WinBuild.160101.0800)
    combase.dll                                      C:\Windows\System32\combase.dll, version=10.0.19041.1320 (WinBuild.160101.0800)
    OLEAUT32.dll                                     C:\Windows\System32\OLEAUT32.dll, version=10.0.19041.3208 (WinBuild.160101.0800)
    SHLWAPI.dll                                      C:\Windows\System32\SHLWAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    msvcrt.dll                                       C:\Windows\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800)
    VCRUNTIME140_1.dll                               .\VCRUNTIME140_1.dll, version=14.36.32532.0
    VCRUNTIME140.dll                                 .\VCRUNTIME140.dll, version=14.36.32532.0
    IMM32.DLL                                        C:\Windows\System32\IMM32.DLL, version=10.0.19041.2673 (WinBuild.160101.0800)
    shcore.dll                                       C:\Windows\System32\shcore.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    hostfxr.dll                                      .\hostfxr.dll, version=7,0,823,31807 @Commit: 4b0550942d7e38bf28dcfddb955e616290b83787
    ADVAPI32.dll                                     C:\Windows\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    sechost.dll                                      C:\Windows\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    hostpolicy.dll                                   .\hostpolicy.dll, version=7,0,823,31807 @Commit: 4b0550942d7e38bf28dcfddb955e616290b83787
    coreclr.dll                                      .\coreclr.dll, version=7,0,823,31807 @Commit: 4b0550942d7e38bf28dcfddb955e616290b83787
    bcryptPrimitives.dll                             C:\Windows\System32\bcryptPrimitives.dll, version=10.0.19041.2486 (WinBuild.160101.0800)
    System.Private.CoreLib.dll                       .\System.Private.CoreLib.dll, version=7.0.823.31807
    clrjit.dll                                       .\clrjit.dll, version=7,0,823,31807 @Commit: 4b0550942d7e38bf28dcfddb955e616290b83787
    kernel.appcore.dll                               C:\Windows\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    paintdotnet.dll                                  .\paintdotnet.dll, version=5.7.8575.34822
    System.Runtime.dll                               .\System.Runtime.dll, version=7.0.823.31807
    uxtheme.dll                                      C:\Windows\system32\uxtheme.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    PaintDotNet.Fundamentals.dll                     .\PaintDotNet.Fundamentals.dll, version=5.7.8575.34822
    PaintDotNet.ComponentModel.dll                   .\PaintDotNet.ComponentModel.dll, version=5.7.8575.34822
    System.Windows.Forms.dll                         .\System.Windows.Forms.dll, version=7.0.823.31802
    System.Diagnostics.Tracing.dll                   .\System.Diagnostics.Tracing.dll, version=7.0.823.31807
    icu.dll                                          C:\Windows\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800)
    System.Threading.Thread.dll                      .\System.Threading.Thread.dll, version=7.0.823.31807
    PaintDotNet.Base.dll                             .\PaintDotNet.Base.dll, version=5.7.8575.34822
    PaintDotNet.Collections.dll                      .\PaintDotNet.Collections.dll, version=5.7.8575.34822
    PaintDotNet.Systrace.dll                         .\PaintDotNet.Systrace.dll, version=5.7.8575.34822
    PaintDotNet.Windows.dll                          .\PaintDotNet.Windows.dll, version=5.7.8575.34822
    TerraFX.Interop.Windows.dll                      .\TerraFX.Interop.Windows.dll, version=10.0.22621.2
    PaintDotNet.Primitives.dll                       .\PaintDotNet.Primitives.dll, version=5.7.8575.34822
    System.Collections.Concurrent.dll                .\System.Collections.Concurrent.dll, version=7.0.823.31807
    PaintDotNet.Runtime.dll                          .\PaintDotNet.Runtime.dll, version=5.7.8575.34822
    PointerToolkit.dll                               .\PointerToolkit.dll, version=1.0.0.0
    System.Threading.dll                             .\System.Threading.dll, version=7.0.823.31807
    PaintDotNet.SystemLayer.dll                      .\PaintDotNet.SystemLayer.dll, version=5.7.8575.34822
    System.Diagnostics.Process.dll                   .\System.Diagnostics.Process.dll, version=7.0.823.31807
    windows.storage.dll                              C:\Windows\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    Wldp.dll                                         C:\Windows\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    System.Private.Uri.dll                           .\System.Private.Uri.dll, version=7.0.823.31807
    BCrypt.dll                                       C:\Windows\System32\BCrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    System.ComponentModel.Primitives.dll             .\System.ComponentModel.Primitives.dll, version=7.0.823.31807
    WindowsBase.dll                                  .\WindowsBase.dll, version=7.0.823.31803
    System.Windows.Forms.Primitives.dll              .\System.Windows.Forms.Primitives.dll, version=7.0.823.31802
    PresentationFramework.dll                        .\PresentationFramework.dll, version=7.0.823.31803
    System.Runtime.InteropServices.dll               .\System.Runtime.InteropServices.dll, version=7.0.823.31807
    System.Xaml.dll                                  .\System.Xaml.dll, version=7.0.823.31803
    System.Drawing.Primitives.dll                    .\System.Drawing.Primitives.dll, version=7.0.823.31807
    System.ComponentModel.dll                        .\System.ComponentModel.dll, version=7.0.823.31807
    System.Diagnostics.TraceSource.dll               .\System.Diagnostics.TraceSource.dll, version=7.0.823.31807
    PaintDotNet.ObjectModel.dll                      .\PaintDotNet.ObjectModel.dll, version=5.7.8575.34822
    System.Collections.dll                           .\System.Collections.dll, version=7.0.823.31807
    System.Text.Encoding.CodePages.dll               .\System.Text.Encoding.CodePages.dll, version=7.0.823.31807
    Microsoft.Win32.Primitives.dll                   .\Microsoft.Win32.Primitives.dll, version=7.0.823.31807
    PresentationNative_cor3.dll                      .\PresentationNative_cor3.dll, version=7,0,23,21102 @Commit: 98cc3ac7a8399b5629d0bab7a34b999b694764a3
    PaintDotNet.Core.dll                             .\PaintDotNet.Core.dll, version=5.7.8575.34822
    PaintDotNet.Resources.dll                        .\PaintDotNet.Resources.dll, version=5.7.8575.34822
    System.Configuration.ConfigurationManager.dll    .\System.Configuration.ConfigurationManager.dll, version=7.0.823.31807
    System.ObjectModel.dll                           .\System.ObjectModel.dll, version=7.0.823.31807
    System.Collections.Specialized.dll               .\System.Collections.Specialized.dll, version=7.0.823.31807
    PaintDotNet.Data.dll                             .\PaintDotNet.Data.dll, version=5.7.8575.34822
    System.Xml.ReaderWriter.dll                      .\System.Xml.ReaderWriter.dll, version=7.0.823.31807
    PaintDotNet.Framework.dll                        .\PaintDotNet.Framework.dll, version=5.7.8575.34822
    CommunityToolkit.HighPerformance.dll             .\CommunityToolkit.HighPerformance.dll, version=8.2.0.1
    System.Private.Xml.dll                           .\System.Private.Xml.dll, version=7.0.823.31807
    System.Threading.ThreadPool.dll                  .\System.Threading.ThreadPool.dll, version=7.0.823.31807
    PaintDotNet.Windows.Framework.dll                .\PaintDotNet.Windows.Framework.dll, version=5.7.8575.34822
    Microsoft.Win32.SystemEvents.dll                 .\Microsoft.Win32.SystemEvents.dll, version=7.0.823.31807
    MSCTF.dll                                        C:\Windows\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    System.Drawing.Common.dll                        .\System.Drawing.Common.dll, version=7.0.823.31807
    System.Net.WebClient.dll                         .\System.Net.WebClient.dll, version=7.0.823.31807
    PaintDotNet.UI.dll                               .\PaintDotNet.UI.dll, version=5.7.8575.34822
    System.ComponentModel.EventBasedAsync.dll        .\System.ComponentModel.EventBasedAsync.dll, version=7.0.823.31807
    dxgi.DLL                                         C:\Windows\SYSTEM32\dxgi.DLL, version=10.0.19041.2311 (WinBuild.160101.0800)
    profapi.dll                                      C:\Windows\SYSTEM32\profapi.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    System.Linq.dll                                  .\System.Linq.dll, version=7.0.823.31807
    System.Collections.Immutable.dll                 .\System.Collections.Immutable.dll, version=7.0.823.31807
    System.Diagnostics.FileVersionInfo.dll           .\System.Diagnostics.FileVersionInfo.dll, version=7.0.823.31807
    version.dll                                      C:\Windows\SYSTEM32\version.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    System.Memory.dll                                .\System.Memory.dll, version=7.0.823.31807
    Microsoft.Win32.Registry.dll                     .\Microsoft.Win32.Registry.dll, version=7.0.823.31807
    d3d11.DLL                                        C:\Windows\SYSTEM32\d3d11.DLL, version=10.0.19041.2913 (WinBuild.160101.0800)
    igd10iumd64.dll                                  C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_51f685305808e3a5\igd10iumd64.dll, version=31.0.101.2111
    apphelp.dll                                      C:\Windows\SYSTEM32\apphelp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    igd10um64gen11.DLL                               C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_51f685305808e3a5\igd10um64gen11.DLL, version=31.0.101.2111
    CRYPT32.dll                                      C:\Windows\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    ncrypt.dll                                       C:\Windows\SYSTEM32\ncrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    NTASN1.dll                                       C:\Windows\SYSTEM32\NTASN1.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    System.Text.Encoding.Extensions.dll              .\System.Text.Encoding.Extensions.dll, version=7.0.823.31807
    igdgmm64.dll                                     C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_51f685305808e3a5\igdgmm64.dll, version=31.0.101.2111
    igc64.dll                                        C:\Windows\System32\DriverStore\FileRepository\iigd_dch.inf_amd64_51f685305808e3a5\igc64.dll, version=31.0.101.2111
    System.Security.Principal.Windows.dll            .\System.Security.Principal.Windows.dll, version=7.0.823.31807
    dxcore.dll                                       C:\Windows\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    cfgmgr32.dll                                     C:\Windows\System32\cfgmgr32.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    ComputeSharp.D2D1.dll                            .\ComputeSharp.D2D1.dll, version=2.0.3.0
    System.Security.Claims.dll                       .\System.Security.Claims.dll, version=7.0.823.31807
    System.ComponentModel.TypeConverter.dll          .\System.ComponentModel.TypeConverter.dll, version=7.0.823.31807
    PaintDotNet.Windows.Core.dll                     .\PaintDotNet.Windows.Core.dll, version=5.7.8575.34822
    d2d1.DLL                                         C:\Windows\SYSTEM32\d2d1.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    clbcatq.dll                                      C:\Windows\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800)
    UIAnimation.dll                                  C:\Windows\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    PaintDotNet.PropertySystem.dll                   .\PaintDotNet.PropertySystem.dll, version=5.7.8575.34822
    XmlLite.dll                                      C:\Windows\SYSTEM32\XmlLite.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    gdiplus.dll                                      C:\Windows\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.2251_none_91a40448cc8846c1\gdiplus.dll, version=10.0.19041.2251 (WinBuild.160101.0800)
    WindowsCodecs.dll                                C:\Windows\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1706 (WinBuild.160101.0800)
    PresentationCore.dll                             .\PresentationCore.dll, version=7.0.823.31803
    PaintDotNet.Effects.Core.dll                     .\PaintDotNet.Effects.Core.dll, version=5.7.8575.34822
    dwrite.DLL                                       C:\Windows\SYSTEM32\dwrite.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    System.IO.Packaging.dll                          .\System.IO.Packaging.dll, version=7.0.823.31807
    comctl32.dll                                     C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800)
    DirectWriteForwarder.dll                         .\DirectWriteForwarder.dll, version=7,0,823,31803 @Commit: b10173d88dc484c1462d387c131bdd4c639927e9
    Accessibility.dll                                .\Accessibility.dll, version=7.0.823.31802
    System.Runtime.Extensions.dll                    .\System.Runtime.Extensions.dll, version=7.0.823.31807
    System.Diagnostics.Debug.dll                     .\System.Diagnostics.Debug.dll, version=7.0.823.31807
    System.Runtime.CompilerServices.VisualC.dll      .\System.Runtime.CompilerServices.VisualC.dll, version=7.0.823.31807
    System.Collections.NonGeneric.dll                .\System.Collections.NonGeneric.dll, version=7.0.823.31807
    System.Numerics.Vectors.dll                      .\System.Numerics.Vectors.dll, version=7.0.823.31807
    UIAutomationTypes.dll                            .\UIAutomationTypes.dll, version=7.0.823.31803
    Crc32.NET.dll                                    .\Crc32.NET.dll, version=1.2.0.5
    System.Security.Cryptography.dll                 .\System.Security.Cryptography.dll, version=7.0.823.31807
    PaintDotNet.Effects.Gpu.dll                      .\PaintDotNet.Effects.Gpu.dll, version=5.7.8575.34822
    PaintDotNet.Effects.dll                          .\PaintDotNet.Effects.dll, version=5.7.8575.34822
    System.Threading.Tasks.Parallel.dll              .\System.Threading.Tasks.Parallel.dll, version=7.0.823.31807
    System.Reflection.Metadata.dll                   .\System.Reflection.Metadata.dll, version=7.0.823.31807
    System.IO.MemoryMappedFiles.dll                  .\System.IO.MemoryMappedFiles.dll, version=7.0.823.31807
    System.Reflection.MetadataLoadContext.dll        .\System.Reflection.MetadataLoadContext.dll, version=7.0.22.51805
    System.Runtime.Loader.dll                        .\System.Runtime.Loader.dll, version=7.0.823.31807
    TextShaping.dll                                  C:\Windows\SYSTEM32\TextShaping.dll, version=
    wtsapi32.dll                                     C:\Windows\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    WINSTA.dll                                       C:\Windows\SYSTEM32\WINSTA.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    UIAutomationCore.dll                             C:\Windows\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.1 (WinBuild.160101.0800)
    PROPSYS.dll                                      C:\Windows\SYSTEM32\PROPSYS.dll, version=7.0.19041.1708 (WinBuild.160101.0800)
    D3D10Warp.dll                                    C:\Windows\SYSTEM32\D3D10Warp.dll, version=10.0.19041.2788 (WinBuild.160101.0800)
    PhotoShop.dll                                    .\FileTypes\PhotoShop.dll, version=2.5.0.0
    AnimGIF.dll                                      .\FileTypes\AnimGIF.dll, version=2.4.4119.28305
    mscorlib.dll                                     .\mscorlib.dll, version=7.0.823.31807
    System.Drawing.dll                               .\System.Drawing.dll, version=7.0.823.31802
    System.dll                                       .\System.dll, version=7.0.823.31807
    mfplat.dll                                       C:\Windows\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    RTWorkQ.DLL                                      C:\Windows\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    CompPkgSup.DLL                                   C:\Windows\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800)
    dwmapi.DLL                                       C:\Windows\SYSTEM32\dwmapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    dataexchange.dll                                 C:\Windows\system32\dataexchange.dll, version=10.0.19041.1387 (WinBuild.160101.0800)
    dcomp.dll                                        C:\Windows\system32\dcomp.dll, version=10.0.19041.2913 (WinBuild.160101.0800)
    twinapi.appcore.dll                              C:\Windows\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    textinputframework.dll                           C:\Windows\SYSTEM32\textinputframework.dll, version=10.0.19041.3086 (WinBuild.160101.0800)
    CoreUIComponents.dll                             C:\Windows\System32\CoreUIComponents.dll, version=10.0.19041.546
    CoreMessaging.dll                                C:\Windows\System32\CoreMessaging.dll, version=10.0.19041.2193
    WS2_32.dll                                       C:\Windows\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800)
    ntmarta.dll                                      C:\Windows\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    wintypes.dll                                     C:\Windows\SYSTEM32\wintypes.dll, version=10.0.19041.1320 (WinBuild.160101.0800)
    DdsFileTypePlus.dll                              .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.11.9.0
    powrprof.dll                                     C:\Windows\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    UMPDC.dll                                        C:\Windows\SYSTEM32\UMPDC.dll, version=
    AvifFileType.dll                                 .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.25.0
    Newtonsoft.Json.dll                              .\Newtonsoft.Json.dll, version=13.0.3.27908
    WebPFileType.dll                                 .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.17.0
    System.Runtime.Serialization.Formatters.dll      .\System.Runtime.Serialization.Formatters.dll, version=7.0.823.31807
    System.Linq.Expressions.dll                      .\System.Linq.Expressions.dll, version=7.0.823.31807
    System.Text.RegularExpressions.dll               .\System.Text.RegularExpressions.dll, version=7.0.823.31807
    System.Runtime.Numerics.dll                      .\System.Runtime.Numerics.dll, version=7.0.823.31807
    PaintDotNet.Effects.Legacy.dll                   .\PaintDotNet.Effects.Legacy.dll, version=5.7.8575.34822
    winmm.DLL                                        C:\Windows\SYSTEM32\winmm.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    Mono.Cecil.dll                                   .\Mono.Cecil.dll, version=0.11.5.0
    PaintDotNet.SystemLayer.Native.x64.dll           .\PaintDotNet.SystemLayer.Native.x64.dll, version=5.7.8575.34822
    netstandard.dll                                  .\netstandard.dll, version=7.0.823.31807
    System.Runtime.Intrinsics.dll                    .\System.Runtime.Intrinsics.dll, version=7.0.823.31807
    PhotoSauce.MagicScaler.dll                       .\PhotoSauce.MagicScaler.dll, version=0.13.2.0
    explorerframe.dll                                C:\Windows\system32\explorerframe.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    Cabinet.dll                                      C:\Windows\SYSTEM32\Cabinet.dll, version=5.00 (WinBuild.160101.0800)
    d3dcompiler_47.dll                               C:\Windows\SYSTEM32\d3dcompiler_47.dll, version=10.0.19041.868 (WinBuild.160101.0800)
    CRYPTSP.dll                                      C:\Windows\SYSTEM32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    PointerToolkit.TerraFX.Interop.Windows.dll       .\PointerToolkit.TerraFX.Interop.Windows.dll, version=10.0.22621.0
    System.Net.Http.dll                              .\System.Net.Http.dll, version=7.0.823.31807
    System.Net.Primitives.dll                        .\System.Net.Primitives.dll, version=7.0.823.31807
    System.Diagnostics.DiagnosticSource.dll          .\System.Diagnostics.DiagnosticSource.dll, version=7.0.823.31807
    System.Net.Security.dll                          .\System.Net.Security.dll, version=7.0.823.31807
    iphlpapi.dll                                     C:\Windows\SYSTEM32\iphlpapi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    DNSAPI.dll                                       C:\Windows\SYSTEM32\DNSAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    NSI.dll                                          C:\Windows\System32\NSI.dll, version=10.0.19041.610 (WinBuild.160101.0800)
    dhcpcsvc6.DLL                                    C:\Windows\SYSTEM32\dhcpcsvc6.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    dhcpcsvc.DLL                                     C:\Windows\SYSTEM32\dhcpcsvc.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    WINNSI.DLL                                       C:\Windows\SYSTEM32\WINNSI.DLL, version=10.0.19041.546 (WinBuild.160101.0800)
    winhttp.dll                                      C:\Windows\SYSTEM32\winhttp.dll, version=10.0.19041.2075 (WinBuild.160101.0800)
    System.Net.Quic.dll                              .\System.Net.Quic.dll, version=7.0.823.31807
    msquic.dll                                       .\msquic.dll, version=2.1.1.293818
    Secur32.dll                                      C:\Windows\SYSTEM32\Secur32.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    SspiCli.dll                                      C:\Windows\SYSTEM32\SspiCli.dll, version=10.0.19041.2130 (WinBuild.160101.0800)
    OilPaintingPlus.dll                              C:\Users\bert\Documents\paint.net App Files\Effects\OilPaintingPlus.dll, version=4.6.7358.38406
    System.Net.Sockets.dll                           .\System.Net.Sockets.dll, version=7.0.823.31807
    mswsock.dll                                      C:\Windows\system32\mswsock.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    wshunix.dll                                      C:\Windows\system32\wshunix.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    PaintDotNet.Plugins.Compatibility.dll            .\PaintDotNet.Plugins.Compatibility.dll, version=5.7.8575.34822
    System.Console.dll                               .\System.Console.dll, version=7.0.823.31807
    System.Threading.Overlapped.dll                  .\System.Threading.Overlapped.dll, version=7.0.823.31807
    System.Net.NameResolution.dll                    .\System.Net.NameResolution.dll, version=7.0.823.31807
    winrnr.dll                                       C:\Windows\System32\winrnr.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    rasadhlp.dll                                     C:\Windows\System32\rasadhlp.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    NLAapi.dll                                       C:\Windows\system32\NLAapi.dll, version=10.0.19041.3031 (WinBuild.160101.0800)
    wshbth.dll                                       C:\Windows\system32\wshbth.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    DEVOBJ.dll                                       C:\Windows\SYSTEM32\DEVOBJ.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    pnrpnsp.dll                                      C:\Windows\system32\pnrpnsp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    napinsp.dll                                      C:\Windows\system32\napinsp.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    GridCheckerboard.dll                             C:\Users\bert\Documents\paint.net App Files\Effects\GridCheckerboard.dll, version=4.5.6828.36789
    fwpuclnt.dll                                     C:\Windows\System32\fwpuclnt.dll, version=10.0.19041.2913 (WinBuild.160101.0800)
    GaussianBlurPlus.dll                             C:\Users\bert\Documents\paint.net App Files\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401
    Flip.dll                                         C:\Users\bert\Documents\paint.net App Files\Effects\Flip.dll, version=4.6.7358.36953
    Dimensions.dll                                   C:\Users\bert\Documents\paint.net App Files\Effects\Dimensions.dll, version=1.3.6826.38472
    ComputeSharp.Core.dll                            .\ComputeSharp.Core.dll, version=2.0.3.0
    CreativeTextPro.dll                              C:\Users\bert\Documents\paint.net App Files\Effects\CreativeTextPro.dll, version=1.1.7358.34307
    BBOutlinedGradientText.dll                       C:\Users\bert\Documents\paint.net App Files\Effects\BBOutlinedGradientText.dll, version=4.6.7358.38713
    BBChart.dll                                      C:\Users\bert\Documents\paint.net App Files\Effects\BBChart.dll, version=1.0.7358.33924
    ThatOtherApp.dll                                 .\Effects\ThatOtherApp.dll, version=2.2.0.0
    amsi.dll                                         C:\Windows\SYSTEM32\amsi.dll, version=10.0.19041.2075 (WinBuild.160101.0800)
    USERENV.dll                                      C:\Windows\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    MpOav.dll                                        C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.23050.5-0\MpOav.dll, version=4.18.23050.5 (b79513656627928b5505482e6c59e640a77adba5)
    MPCLIENT.DLL                                     C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.23050.5-0\MPCLIENT.DLL, version=4.18.23050.5 (b79513656627928b5505482e6c59e640a77adba5)
    WINTRUST.dll                                     C:\Windows\System32\WINTRUST.dll, version=10.0.19041.2913 (WinBuild.160101.0800)
    MSASN1.dll                                       C:\Windows\System32\MSASN1.dll, version=10.0.19041.2251 (WinBuild.160101.0800)
    gpapi.dll                                        C:\Windows\SYSTEM32\gpapi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    System.Windows.Forms.Legacy.dll                  .\System.Windows.Forms.Legacy.dll, version=1.0.0.0
    schannel.DLL                                     C:\Windows\system32\schannel.DLL, version=10.0.19041.1 (WinBuild.160101.0800)
    mskeyprotect.dll                                 C:\Windows\SYSTEM32\mskeyprotect.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    ncryptsslp.dll                                   C:\Windows\system32\ncryptsslp.dll, version=10.0.19041.2846 (WinBuild.160101.0800)
    PrinterPlus.dll                                  .\Effects\PrinterPlus.dll, version=1.5.0.0
    Olden.dll                                        .\Effects\Olden.dll, version=1.5.0.0
    FindEdges.dll                                    .\Effects\FindEdges.dll, version=1.2.0.0
    ExtendBorder.dll                                 .\Effects\ExtendBorder.dll, version=1.3.0.0
    DragFrom.dll                                     .\Effects\DragFrom.dll, version=1.1.0.0
    Borders N' Shapes.dll                            .\Effects\Borders N' Shapes.dll, version=4.0.4642.26476
    comdlg32.dll                                     C:\Windows\System32\comdlg32.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    DUI70.dll                                        C:\Windows\System32\DUI70.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    DUser.dll                                        C:\Windows\System32\DUser.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    tiptsf.dll                                       C:\Program Files\Common Files\microsoft shared\ink\tiptsf.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    edputil.dll                                      C:\Windows\SYSTEM32\edputil.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    thumbcache.dll                                   C:\Windows\System32\thumbcache.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    Windows.UI.FileExplorer.dll                      C:\Windows\System32\Windows.UI.FileExplorer.dll, version=10.0.19041.1741 (WinBuild.160101.0800)
    OLEACC.dll                                       C:\Windows\System32\OLEACC.dll, version=7.2.19041.746 (WinBuild.160101.0800)
    StructuredQuery.dll                              C:\Windows\System32\StructuredQuery.dll, version=7.0.19041.867 (WinBuild.160101.0800)
    atlthunk.dll                                     C:\Windows\SYSTEM32\atlthunk.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    Windows.FileExplorer.Common.dll                  C:\Windows\System32\Windows.FileExplorer.Common.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    iertutil.dll                                     C:\Windows\System32\iertutil.dll, version=11.00.19041.1 (WinBuild.160101.0800)
    MPR.dll                                          C:\Windows\SYSTEM32\MPR.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    wkscli.dll                                       C:\Windows\System32\wkscli.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    cscapi.dll                                       C:\Windows\SYSTEM32\cscapi.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    netutils.dll                                     C:\Windows\System32\netutils.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    twinapi.dll                                      C:\Windows\System32\twinapi.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    dlnashext.dll                                    C:\Windows\System32\dlnashext.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    DevDispItemProvider.dll                          C:\Windows\System32\DevDispItemProvider.dll, version=10.0.19041.1708 (WinBuild.160101.0800)
    MrmCoreR.dll                                     C:\Windows\System32\MrmCoreR.dll, version=10.0.19041.1566 (WinBuild.160101.0800)
    windows.staterepositorycore.dll                  C:\Windows\SYSTEM32\windows.staterepositorycore.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    PhotoMetadataHandler.dll                         C:\Windows\SYSTEM32\PhotoMetadataHandler.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    NetworkExplorer.dll                              C:\Windows\system32\NetworkExplorer.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    coml2.dll                                        C:\Windows\System32\coml2.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    LINKINFO.dll                                     C:\Windows\SYSTEM32\LINKINFO.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    ActXPrxy.dll                                     C:\Windows\System32\ActXPrxy.dll, version=10.0.19041.2546 (WinBuild.160101.0800)
    wpdshext.dll                                     C:\Windows\system32\wpdshext.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    policymanager.dll                                C:\Windows\SYSTEM32\policymanager.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    msvcp110_win.dll                                 C:\Windows\SYSTEM32\msvcp110_win.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    SETUPAPI.dll                                     C:\Windows\System32\SETUPAPI.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    PortableDeviceTypes.dll                          C:\Windows\System32\PortableDeviceTypes.dll, version=10.0.19041.746 (WinBuild.160101.0800)
    IconCodecService.dll                             C:\Windows\system32\IconCodecService.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    EhStorShell.dll                                  C:\Windows\System32\EhStorShell.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    FileSyncShell64.dll                              C:\Program Files\Microsoft OneDrive\23.132.0625.0001\FileSyncShell64.dll, version=23.132.0625.0001
    WININET.dll                                      C:\Windows\SYSTEM32\WININET.dll, version=11.00.19041.2075 (WinBuild.160101.0800)
    CRYPTBASE.DLL                                    C:\Windows\SYSTEM32\CRYPTBASE.DLL, version=10.0.19041.546 (WinBuild.160101.0800)
    drivefsext.dll                                   C:\Program Files\Google\Drive File Stream\78.0.1.0\drivefsext.dll, version=78.0.1.0
    dbghelp.dll                                      C:\Windows\SYSTEM32\dbghelp.dll, version=10.0.19041.867 (WinBuild.160101.0800)
    GROOVEEX.DLL                                     C:\Program Files\Microsoft Office\root\Office16\GROOVEEX.DLL, version=16.0.15601.20118
    MSVCP140.dll                                     C:\Program Files\Microsoft Office\root\Office16\MSVCP140.dll, version=14.29.30135.0 built by: vcwrkspc
    wer.dll                                          C:\Windows\SYSTEM32\wer.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    msi.dll                                          C:\Windows\SYSTEM32\msi.dll, version=5.0.19041.3208
    GrooveIntlResource.dll                           C:\Program Files\Microsoft Office\root\Office16\1033\GrooveIntlResource.dll, version=
    cscui.dll                                        C:\Windows\System32\cscui.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    ntshrui.dll                                      C:\Windows\SYSTEM32\ntshrui.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    srvcli.dll                                       C:\Windows\SYSTEM32\srvcli.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
    windowscodecsext.dll                             C:\Windows\system32\windowscodecsext.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    mscms.dll                                        C:\Windows\SYSTEM32\mscms.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    ColorAdapterClient.dll                           C:\Windows\SYSTEM32\ColorAdapterClient.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    System.Private.Xml.Linq.dll                      .\System.Private.Xml.Linq.dll, version=7.0.823.31807
    sxs.dll                                          C:\Windows\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    PresentationFramework-SystemXmlLinq.dll          .\PresentationFramework-SystemXmlLinq.dll, version=7.0.823.31803
    System.Xml.XDocument.dll                         .\System.Xml.XDocument.dll, version=7.0.823.31807
    System.Xml.Linq.dll                              .\System.Xml.Linq.dll, version=7.0.823.31807
    System.IO.Compression.dll                        .\System.IO.Compression.dll, version=7.0.823.31807
    System.CodeDom.dll                               .\System.CodeDom.dll, version=7.0.823.31807
    K4os.Compression.LZ4.dll                         .\K4os.Compression.LZ4.dll, version=1.2.16
    urlmon.dll                                       C:\Windows\SYSTEM32\urlmon.dll, version=11.00.19041.2546 (WinBuild.160101.0800)
    MLANG.dll                                        C:\Windows\SYSTEM32\MLANG.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    pcacli.dll                                       C:\Windows\SYSTEM32\pcacli.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    sfc_os.dll                                       C:\Windows\System32\sfc_os.dll, version=10.0.19041.2311 (WinBuild.160101.0800)
    drprov.dll                                       C:\Windows\System32\drprov.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    ntlanman.dll                                     C:\Windows\System32\ntlanman.dll, version=10.0.19041.1826 (WinBuild.160101.0800)
    davclnt.dll                                      C:\Windows\System32\davclnt.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    DAVHLPR.dll                                      C:\Windows\System32\DAVHLPR.dll, version=10.0.19041.546 (WinBuild.160101.0800)
    dfscli.dll                                       C:\Windows\System32\dfscli.dll, version=10.0.19041.1 (WinBuild.160101.0800)
    browcli.dll                                      C:\Windows\SYSTEM32\browcli.dll, version=10.0.19041.3155 (WinBuild.160101.0800)
Posted (edited)
59 minutes ago, toe_head2001 said:
You also tried Ctrl+Shift+F8?
No I didn't, but I just did. And it worked.  As did the same trick with F7.  And what's more, after I closed both windows, just clicking on the icons opened them again, as did both F7 and F8.  As I final test I closed the program then ran it again.  The icons and the function keys worked perfectly.
I'm very grateful to you.  Do you know what was preventing the proper operation?  If it could have been something I did, it would be valuable to know just what it might have been.
Many thanks.
Most likely scenario is that the windows were active but dragged offscreen (another monitor entirely, or so that just one edge was visible on the monitor)
Posted (edited)
That's it:  I have my PC display extended over two monitors, one in landscape orientation one in portrait.  Working on the portrait screen I must have dragged the Layers and Colour Wheel beyond the edge of the main program window - then when I dragged that window back to the main landscape screen to close it, I didn't notice that the two smaller windows had stayed where they were.   And as I now know, that configuration stays set when the program is reopened.  Today I only had the landscape monitor switched on...
Thank you so much!  And thanks too to everyone else who responded.
  • Thanks 1
