pstein Posted December 6, 2022 Share Posted December 6, 2022 (edited) How can I define into which directory a (new/changed) picture should be saved by default (e.g. "same as original" or "absolute D:\mypics\")? How can I setup the save (compression) quality for *.jpg pictures (e.g. 97%)? Edited December 6, 2022 by pstein Link to comment Share on other sites More sharing options...
null54 Posted December 6, 2022 Share Posted December 6, 2022 41 minutes ago, pstein said: How can I define into which directory a (new/changed) picture should be saved by default (e.g. "same as original" or "absolute D:\mypics\")? The save dialog is handled by the OS, I think that it defaults to the last folder that was used to open or save an image. As far as I'm aware there is no other way to override the save dialog location from within Paint.NET. 46 minutes ago, pstein said: How can I setup the save (compression) quality for *.jpg pictures (e.g. 97%)? The JPEG save configuration dialog should remember its last used settings between Paint.NET sessions, so you can just set it to whatever values you want Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
pstein Posted December 6, 2022 Author Share Posted December 6, 2022 Ok, and where in the save configuration dialog can I specify the default compression level? I can select only target directory Link to comment Share on other sites More sharing options...
AlexDolmatov Posted December 7, 2022 Share Posted December 7, 2022 After selecting a folder, click save and adjust the settings in the browser window on the left. If you change them again, they will become default again. Link to comment Share on other sites More sharing options...
pstein Posted December 25, 2022 Author Share Posted December 25, 2022 That means: I cannot define default compression level independent from a SAVE operation? Users MUST save at least one *.jpg No way of finding the current level without changing? Sounds not very sophisticated and thoughtful Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 26, 2022 Share Posted December 26, 2022 15 hours ago, pstein said: Sounds not very sophisticated and thoughtful You need to improve your constructive criticism skills. Just because something doesn't work exactly the way you want it to, doesn't mean it is "not very sophisticated" or "not thoughtful." You've got your answer. I'm locking this thread. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
