spaceowl Posted July 8, 2020 Share Posted July 8, 2020 (edited) Hello, I am writing this message to the creator of PaintDotNet I am using window blinds and have customized my system appearance, as you can see in the first screenshot with some software examples. The problem is, PaintDotNet don’t uses the system colors, but has its three preinstalled schemes. And that makes me sad, because, it doesn’t fit into my system appearance and makes me every time sad, when I work with it. The second screenshot shows Gimp with “system color scheme” and it looks great (besides the gray font in the menu). But I don’t want use Gimp. Is it possible, that you could enable PaintDotNet to use system colors as an optional color scheme please? I have seen in another thread, that it was possible once. Greetings Paul Edited July 8, 2020 by spaceowl Link to comment Share on other sites More sharing options...
3dgamerman Posted July 14, 2020 Share Posted July 14, 2020 Dude, you making your whole PC look like Morrowind. That's tight. 1 Link to comment Share on other sites More sharing options...
BoltBait Posted July 14, 2020 Share Posted July 14, 2020 On 7/8/2020 at 7:19 AM, spaceowl said: I am using window blinds... Paint.NET is not compatible with Window Blinds at all. Sorry. Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 14, 2020 Share Posted July 14, 2020 It's not that PDN isn't compatible with WindowBlinds, it's more like WindowBlinds isn't compatible with Windows. I'm not going to put any work into making Paint.NET work better with WindowBlinds. It's a basket full of hacks, it causes system instability, hardly anybody uses it. It'd be a total waste of time. Sorry. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
spaceowl Posted July 28, 2020 Author Share Posted July 28, 2020 Hello But it is possible to enable this again or made it optional, that paint uses the system color (which has nothing to do with Window Blinds) for the background, like it was in old Paint 3.35 like in this screenshots? Or at least, enabling this registry value again? Link to comment Share on other sites More sharing options...
spaceowl Posted July 28, 2020 Author Share Posted July 28, 2020 I downloaded Version 3.35 and the Colours look great! I would be happy if it could be enabled back. But strange that the background is still grey. Maybe it is only changeable by the registry value mentioned above. Link to comment Share on other sites More sharing options...
null54 Posted July 28, 2020 Share Posted July 28, 2020 4 hours ago, spaceowl said: But strange that the background is still grey. That is actually version 3.36, the background was changed to #c0c0c0 in that version. Paint.NET 3.36 is almost 12 years old, it is no longer supported. Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 28, 2020 Share Posted July 28, 2020 3.36 is old as dirt and nowhere near as good as modern versions The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 28, 2020 Share Posted July 28, 2020 If you're willing to make your system unstable for the sake of customizing its appearance, that's your choice. In any case you have your answer and our recommendations (DON'T DO THAT), so I'm going to close this thread. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
