HyReZ Posted May 24, 2019 Share Posted May 24, 2019 I created this 'One Page Tutorial' this morning: Plugin used: ImAGIF Here is the result: 3 Quote Link to comment Share on other sites More sharing options...
Seerose Posted May 24, 2019 Share Posted May 24, 2019 @HyReZ! I've tried. When saving there is always error message. Of course I didn't understand. Application version: paint.net 4.1.7 (α 4.107.7079.30132) System.MissingMethodException: Method not found: 'Int32 PaintDotNet.Data.Quantize.PaletteTable.FindClosestPaletteIndex(System.Drawing.Color)'. at PropertyBasedFileTypes.ImAgifFileType.OnSaveT(Document input, Stream output, PropertyBasedSaveConfigToken token, Surface scratchSurface, ProgressEventHandler progressCallback) at PaintDotNet.FileType.Save(Document input, Stream output, SaveConfigToken token, Surface scratchSurface, ProgressEventHandler callback, Boolean rememberToken) in D:\src\pdn\src\Data\FileType.cs:line 353 at PaintDotNet.Dialogs.SaveConfigDialog.<>c__DisplayClass48_0.<UpdatePreviewAsync>b__0() in D:\src\pdn\src\PaintDotNet\Dialogs\SaveConfigDialog.cs:line 604 at System.Threading.Tasks.Task.Execute() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at PaintDotNet.Dialogs.SaveConfigDialog.<UpdatePreviewAsync>d__48.MoveNext() in D:\src\pdn\src\PaintDotNet\Dialogs\SaveConfigDialog.cs:line 623 Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
HyReZ Posted May 24, 2019 Author Share Posted May 24, 2019 (edited) I am sure that I can't tell what is going on in your error log. I have not installed the current Paint.NET Alpha (α 4.107.7079.30132). I have successfully used Midora's AGIF Plugin with earlier versions of Paint.NET and with more complicated animations than the one explained in this tutorial. The plugin may have to be re-coded to perform in the newer PDN versions. My hope is that some of our forum members can help get to a solution to this problem that you are experiencing! Edited May 24, 2019 by HyReZ 1 Quote Link to comment Share on other sites More sharing options...
Pixey Posted May 24, 2019 Share Posted May 24, 2019 I am using the same version as @Seerose and it works fine. As @Seerose made it up to the point of saving - it means she must have the correct things in the correct folders? Perhaps @toe_head2001 or @BoltBait or any other computer savvy gobbledegook reader, can shed some light on the error message 😁 2 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
BoltBait Posted May 24, 2019 Share Posted May 24, 2019 Rule #1 when it comes to plugin problems: Make sure the plugin you're using is the latest version. 1 1 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Seerose Posted May 26, 2019 Share Posted May 26, 2019 @HyReZ! @Pixey! @BoltBait! Thanks to all so much for stopping by to commentAll plugins are up-to-date. Nevertheless I can not save picture. Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
Pixey Posted May 26, 2019 Share Posted May 26, 2019 18 minutes ago, Seerose said: @HyReZ! @Pixey! @BoltBait! Thanks to all so much for stopping by to commentAll plugins are up-to-date. Nevertheless I can not save picture. Just for interest @Seerose can you try to do this tutorial and see if it works. 1 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
HyReZ Posted May 26, 2019 Author Share Posted May 26, 2019 (edited) @SeeroseAre you able to save the project as a PDN file or does it only happen when saving to AGIF ? Edited May 26, 2019 by HyReZ Quote Link to comment Share on other sites More sharing options...
Pixey Posted May 26, 2019 Share Posted May 26, 2019 @HyReZ I believe @Seerose's problem is when she tries to Save As: Animated GIF (*.agif) I suggested she try the other tutorial as the settings will be different to yours. It was just an idea to see what happens. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
HyReZ Posted May 26, 2019 Author Share Posted May 26, 2019 (edited) @Pixey I changed two settings from those that are default. I dropped the amount of colors to 8 and the Threshold alpha to 255 transparency. She can reset back to default with tab at the bottom of the save option. BTW: What settings did you use? Edited May 26, 2019 by HyReZ Quote Link to comment Share on other sites More sharing options...
Pixey Posted May 26, 2019 Share Posted May 26, 2019 @HyReZ when I made the Jump Out gif, I used your settings exactly as yours and it worked just fine. So it's a mystery as to why @Seerosecan't get it to save 😨 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Pixey Posted May 26, 2019 Share Posted May 26, 2019 Also @Seerose double check you have the .dll's and the .dlc's in the File Types Folder: Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
HyReZ Posted May 26, 2019 Author Share Posted May 26, 2019 (edited) 56 minutes ago, Pixey said: I see that you have the AminGIF.dll in you Filetype folder, yet you had no problem with your project. In the readme document of the ImAGIF plugin, Midora states:"Follow the instructions carefully - Unzip the archive - Copy the two files ImAGIF.FileType.dll/.dlc to the Paint.NET\FileTypes\ folder (a typical location is C:\Program Files\paint.net\FileTypes). - To avoid conflicts with other filetype plugins which support the same extension you should remove or disable them (i.e. AnimGIF.dll). To verify the installation you should restart Paint.NET and check that in the filetype popup of the open file selector dialog is an entry starting with AGIF."The mystery persist!@welshblueNice job! BTW: ImGIF processes the project from the bottom layer up Edited May 26, 2019 by HyReZ Quote Link to comment Share on other sites More sharing options...
Pixey Posted May 26, 2019 Share Posted May 26, 2019 Yes, I know the other dll is still in there, but it doesn't affect anything. As you say - we have a conundrum going on Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
HyReZ Posted May 26, 2019 Author Share Posted May 26, 2019 (edited) I just occured to me to ask if Seerose has the ImAGIF filetype dll's in another folder by mistake? Edited May 26, 2019 by HyReZ Correcting spelling and adding more nfo! 1 Quote Link to comment Share on other sites More sharing options...
Seerose Posted May 27, 2019 Share Posted May 27, 2019 @Pixey! and @HyReZ! If I'm not mistaken, everything's correct. Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
HyReZ Posted May 27, 2019 Author Share Posted May 27, 2019 @Seerose I was trying to find out if you had the same files in two locations within Paint.NET. That could cause a conflict! I am mentally testing a variety of possiblities for your problem. 1 Quote Link to comment Share on other sites More sharing options...
Seerose Posted May 27, 2019 Share Posted May 27, 2019 @HyReZ! I checked all the paint folders. 1 Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
Seerose Posted May 27, 2019 Share Posted May 27, 2019 @HyReZ! and @Pixey! Now I've tried again. As bewitched, simply folded. Thank you very much for your effort. 1 Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
HyReZ Posted May 27, 2019 Author Share Posted May 27, 2019 (edited) I increased the frame timing to 1000ms (1 sec) so you have longer to read each frame Edited May 28, 2019 by HyReZ 1 Quote Link to comment Share on other sites More sharing options...
Seerose Posted May 29, 2019 Share Posted May 29, 2019 @welshblue! Perfect! Thank you for sharing your result! Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
