thanhsai Posted April 23, 2019 Share Posted April 23, 2019 (edited) Hi, everyone!!! Problem 1: I have a problem with the picture I want to edit (https://imgur.com/a/gk5lkyF) The first picture is the one I have The second picture is that I open paint.net, do nothing, then save it, and it has lots of NOISE (is many tiny dots) Problem 2: Paint.net can "vertical", "rotate", "stroke" text??? Everyone help me Thank you!!! Edited April 23, 2019 by thanhsai Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted April 23, 2019 Share Posted April 23, 2019 Looks like JPEG compression artifacts. I suggest you use the PNG format, as it uses lossless compression. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 23, 2019 Share Posted April 23, 2019 Hello thanhsai. Welcome to the forum 😃 Problem 2 is usually solved by using a plugin (except rotation which paint.net does quite well natively). Go to the the Plugin Index and search using text as the search term. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
thanhsai Posted April 24, 2019 Author Share Posted April 24, 2019 10 hours ago, Ego Eram Reputo said: Hello thanhsai. Welcome to the forum 😃 Problem 2 is usually solved by using a plugin (except rotation which paint.net does quite well natively). Go to the the Plugin Index and search using text as the search term. Thankyou, but i don't know how to stroke... like this Quote Link to comment Share on other sites More sharing options...
thanhsai Posted April 24, 2019 Author Share Posted April 24, 2019 12 hours ago, toe_head2001 said: Looks like JPEG compression artifacts. I suggest you use the PNG format, as it uses lossless compression. THANKYOU!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
BoltBait Posted April 24, 2019 Share Posted April 24, 2019 53 minutes ago, thanhsai said: Thankyou, but i don't know how to stroke... like this Try this plugin: Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
thanhsai Posted April 24, 2019 Author Share Posted April 24, 2019 2 hours ago, BoltBait said: THANKYOU!!! Quote Link to comment Share on other sites More sharing options...
