Sandsdenver Posted March 7, 2019 Share Posted March 7, 2019 I would like to just raise the bear per se, and have no background. But since the bear and the back ground (current) are the same color, I am having a rough time. I tried the magic wand and also a sight called LunaPic, but to no avail, can anyone provide some tips or push in the right direction? ty Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted March 7, 2019 Share Posted March 7, 2019 Here's a plug-in that can help. https://forums.getpaint.net/topic/26966-trs-alpha-cutter-v304-april-7th-2014/ Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 7, 2019 Share Posted March 7, 2019 Hey @Sandsdenver - Welcome to the forum 😃 Try using the Magic Wand on the background with a Tolerance of 28% Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
IHaveNoName Posted March 7, 2019 Share Posted March 7, 2019 (edited) Those ways may work better but if it had been me and not being aware of those methods I would have gone back to an old school photographic technique: a high contrast mask. You simply copy the picture into another layer then convert that copy into b/w then up the contrast/alter the brightness until you get a good clean outline. The bear in the picture has a very distinctive darker line around its border and that should mean a pretty clean outline of that would be created by such as mask. You'd probably need to flood the rest of the bear with black to create a full silhouette. Now use the Magic Wand Tool to define the silhouette's outline, swap to the original picture layer and use that to remove the background. Below is is a very crude 5 minute attempt. The transparent background will display as white posted here. The problem is that it is a very low contrast image and the difference in tone, even with the darker outline, is not clear enough to create a clean mask. That was always the trouble you had when this was done photographically, retouching the lith (high contrast b/w) mask was always necessary. If I was doing this I'd take a lot more time cleaning up the edge of the mask and the picture with background removed. I'd probably feather the edge of the picture so any replacement background blended better. But it is proof of concept if those other techniques do not satisfy. Edited March 8, 2019 by IHaveNoName typo 1 Quote Link to comment Share on other sites More sharing options...
cornemuse Posted March 9, 2019 Share Posted March 9, 2019 (edited) I remove like this: (takes a while I still use 3.5.1, old!) Line white, "all the way around" (edit: a sample here of pic.) (rec. select from above, duh!) Not showing, but Magic wand 26% (<-default for me) (edit: added blue background) White is -gone- (on my comp = checker pattern) Magic wand at "maximum without selecting everything" (for me was 68%) White is -gone- (on my comp = checker pattern) antialiasing enabled = smoother edges. (I rarely disable antialiasing) I have not added more than 1 or 2 plugins, dont even remember which ones, , , , , (edit: added blue background) Edited March 9, 2019 by cornemuse feng shui 1 Quote 'Where's my plinth?' Link to comment Share on other sites More sharing options...
IHaveNoName Posted March 10, 2019 Share Posted March 10, 2019 That is an effective alternative method for creating the contrast needed for the Magic Wand to be able to select the precise outline of the bear. It certainly gives a much cleaner outline than my attempt but hand drawing the border must have taken some time. Quote Link to comment Share on other sites More sharing options...
cornemuse Posted March 12, 2019 Share Posted March 12, 2019 If you do it a lot, you get used to it. I prolly coulda done the whole pic in 2-3 minutes. How I've always done it. (I do it a lot!) Quote 'Where's my plinth?' Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 13, 2019 Share Posted March 13, 2019 On 3/7/2019 at 6:11 PM, Ego Eram Reputo said: Hey @Sandsdenver - Welcome to the forum 😃 Try using the Magic Wand on the background with a Tolerance of 28% Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
