G'MIC (09-04-2024)
null54
2 minutes ago, mackenzieh said:
The G'MIC site's download for paint.net is verson 2.9.9, not 3.0.
See here - https://discuss.pixls.us/t/release-of-gmic-3-0/17226/516
That's where I got the release number.
G'MIC Filter Developer
I am away from this forum for undetermined amount of time: If you really need anything related to my PDN plugin or my G'MIC filter within G'MIC plugin, then you can contact me via Paint.NET discord, and mention me.
I know the release number is 3.0. but when going the site itself and clicking on paint.net's download, it's not 3.0. it's the previous version 2.9.9.
Edited by mackenzieh
  • null54 changed the title to G'MIC (2021-12-09)
Release version 3.0.0.
Changes:
  • Updated to G'MIC version 3.0.0.
  • Updated the plugin for Paint.NET 4.3.4 and .NET 6.0.
  • Like 2
  • null54 changed the title to G'MIC (2022-01-14)
Release version 3.0.1.
Changes:
  • Updated to G'MIC version 3.0.1.
  • The G'MIC filter name is now included in the file name of the external PNG files.
  • Like 3
I found a few especially useful filters here, so thanks for making this plugin. It would be nice if it didn't recalculate the plugin when panning the image, right-clicking things in the list, opening after having used the plugin once before, or left-clicking the same filter in the list that's already selected. Basically, if the filter was only run when altering settings or switching filters.
I have no control over the G'MIC-Qt UI behavior, but you could open an issue on GitHub to see what its developer has to say about those issues.
  • null54 changed the title to G'MIC (2022-01-19)
  • 3 months later...
@null54 G'MIC 3.1.0 has finally arrived.
Also, since @lynxster4 asked when it's going to released before. Pinging just to let @lynxster4 know.
  • null54 changed the title to G'MIC (2022-04-26)
Release version 3.1.0
Changes:
  • Updated G'MIC to version 3.1.0
Added installation instructions for the ARM64 versions of Windows 10/11, the x86 or x64 version of G'MIC-Qt will be run under emulation.
  • Like 3
13 minutes ago, AndrewDavid said:
I get 3.0.2
Fixed, I forgot to update the download links in the first post.
  • Like 2
  • Thanks 1
  • null54 changed the title to G'MIC (2022-05-10)
Release version 3.1.1.
Changes:
  • Updated G'MIC to version 3.1.1
  • Changed the plugin icon to the G'MIC-Qt application icon.
  • Like 2
8 hours ago, Rle said:
Gmic_win32 version 3.1.0 and 3.1.1 are not working.
It looks like something changed with G'MIC-Qt.
I fixed that error, but the 32-bit version still exits with an error code when I attempt to run it.
I am currently building the 32-bit version is Visual Studio so I can debug it.
G'MIC-Qt is crashing due to an unhandled exception, caused by an integer overflow bug in the CImg library.
I reported the issue in the CImg repository, and will probably be filing a related issue in the G'MIC-Qt repository.
G'MIC-QT should probably catch and report those exceptions, instead of letting it crash the application.
  • Thanks 1
  • Upvote 2
  • null54 changed the title to G'MIC (2022-05-11)
Release version 3.1.2.
Changes:
  • Updated G'MIC to version 3.1.2
  • Fixed a crash in the 32-bit version.
G'MIC-Qt was changed to generate the translations at build time, using bash scripts and Makefiles that are not compatible with a MinGW build environment.
See https://github.com/c-koi/gmic-qt/issues/150.
I am trying to figure out a way to generate the required files manually.
  • Like 2
  • null54 changed the title to G'MIC (2022-06-16)
