Kokain Posted March 19, 2017 Share Posted March 19, 2017 (edited) I can't understand what's causing this, some times when I paste (for better word) the WordArt text from this plugin I'm using, it appears all broken with lines running across and it's random on every single paste. So if I was to fix this I would spam Ctrl + F the repeat/paste function over and over until it covers up the font and looks solid. How I see it and how it should be. I'm not sure if it's a bug in the plugin or the paint program. So why is spamming not a good fix? Well if I wanted opacity, spamming the text over and over will just make it solid white, adding other art effects and repeating them will also not give me the desired effect. I tried in different layers, solid background color....the only time it doesn't seems to do it is when the text is small like 8-18pt. It's almost as if the process didn't render completely. Anybody know what the issue might be and what I could do on my end to experiment http://i.imgur.com/vWHhNPm.png Edited March 19, 2017 by Kokain Quote Link to comment Share on other sites More sharing options...
Eli Posted March 19, 2017 Share Posted March 19, 2017 (edited) What plugin are you using? Edit. I see it now it is TextPro. Sorry, I do not have that one. It would be best to post your question in the author's post. An update may be needed. The same problem was reported for another plugin made by @romein : Multi Color Gradient. Edited March 19, 2017 by Eli Quote Link to comment Share on other sites More sharing options...
AndrewDavid Posted March 19, 2017 Share Posted March 19, 2017 (edited) Hers my 2 cents. Keep in mind that plugin is one of the rare ones that asks for payment. You might be using a feature that can only be used properly after you pay the registration fee. The author hasn't been around for quite awhile. We still have the watermarks on basic text functions. So I would think those strikeouts are along the same lines. A way of getting your registration and payment for the plugin. Edited April 14, 2018 by AndrewDavid Deleted attachment Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted March 19, 2017 Share Posted March 19, 2017 Please post your question in the TextPro thread: http://forums.getpaint.net/index.php?/topic/17056-text-pro-plugin-free-trial/ Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Pixey Posted March 19, 2017 Share Posted March 19, 2017 (edited) It's working fine for me in v 4.0.13 . P.S. Although it's no longer showing up in the Render sub menu - it's now in the main Effects window. Edited March 19, 2017 by Pixey added P.S. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
