kasra Posted June 8, 2016 Share Posted June 8, 2016 (edited) Hi i wanted to put a game cover in to a 3d frame but i dont know how ?i asked this question in a nother froum and their answer was photoshopi dont know anything about it so i use paint.nethere is the frameand i want to put my picture like this one IS THERE ANY WAY THAT I CAN DO THIS THING WITHOUT PHOTOSHOP ? (sorry about the grammer&sdictation iam not english) Edited June 8, 2016 by kasra Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted June 8, 2016 Share Posted June 8, 2016 Take a look at this tutorial: http://forums.getpaint.net/index.php?/topic/12246-lets-make-a-software-box/ Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Eli Posted June 8, 2016 Share Posted June 8, 2016 Or you may have to distort your images so they fill fit in the frame. You can use distortion effects like MJW's Perspective transformation or TR's Distort this! Quote Link to comment Share on other sites More sharing options...
kasra Posted June 8, 2016 Author Share Posted June 8, 2016 (edited) nicecan you take a video for toterial PLZ @Eli Edited June 8, 2016 by kasra Quote Link to comment Share on other sites More sharing options...
Eli Posted June 8, 2016 Share Posted June 8, 2016 (edited) Sorry, I do not know how to make videos. What you need to do is place the image you want to distort below your frame. In this example I used TR's Distort this! effect. You need to move the the little circles until it (more or less) fits in your frame. Edited June 8, 2016 by Eli Quote Link to comment Share on other sites More sharing options...
kasra Posted June 9, 2016 Author Share Posted June 9, 2016 (edited) thank's IT IS FINISHED is it good ? http://vgboxart.com/boxes/PC/74975-firewatch-full.jpg Edited June 9, 2016 by Ego Eram Reputo Created thumbnail link Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 9, 2016 Share Posted June 9, 2016 Looks pretty good kasra. I'd add another line to each side of the box spine to define it a little more clearly. 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
kasra Posted June 10, 2016 Author Share Posted June 10, 2016 thanks where can i see it Quote Link to comment Share on other sites More sharing options...
IRON67 Posted June 10, 2016 Share Posted June 10, 2016 thanks where can i see it Ego Eram Reputo wrote "I'd add another line...". That means "I WOULD add ...", so this was a suggestion for you. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 10, 2016 Share Posted June 10, 2016 Correct Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
kasra Posted June 10, 2016 Author Share Posted June 10, 2016 thanks problem solved Quote Link to comment Share on other sites More sharing options...
Footpoedis Posted June 12, 2016 Share Posted June 12, 2016 Sorry, I do not know how to make videos. What you need to do is place the image you want to distort below your frame. In this example I used TR's Distort this! effect. You need to move the the little circles until it (more or less) fits in your frame. I was also looking into how to place an image to an object and this really helped. Mine was a bit difficult as I wanted to fit the image on to a cubical layout but I managed to do it. Just a little more tweaking and it should be perfect. Anyway thanks for this tip and also thanks to the poster for sharing. Quote Link to comment Share on other sites More sharing options...
