How to retouch "sky" in a photo with a spot?
Just to clarify the differences between the two tools,
The Clone Stamp tool :CloneStampTool: "clones" samples of the actual picture, then uses those samples to color with.
The Color Picker tool :ColorPickerTool:  lets you "pick" a color from your image, then you can color with that color using drawing tools like the paintbrush, pencil, line/curve tool, etc. :)
Edited by Cc4FuzzyHuggles
Skullbonz & Cc4,
I was just coming here to say that I tried fixing the sky with the color picker and found that to be much easier for me.  I used it in conjunction with the paint brush.
Thanks for posting and helping me out!   ;)
Erg,
I did not understand the shortcut = k
Now I see that K is the shortcut for the color picker tool.
I found that zooming in on my photo and then dragging the tool box over near the spot in the sky that I need to remove then I can easily switch back and forth between the color picker and the paint brush with my mouse.
Thanks again to everyone!
:D
