How to start a fire with Paint.NET
Tom Jackson
I made that one the first time a tried using a different gradient for this tut and I accidentally did something different with the curves, but I think it came out alright then if it wasn't the desired result
and a sig I made for a friend of mine in a forum of his
Thanks for a really good and easy to follow tutorial.
You can make it looks smooth easily - you could make a big piece of clouds and cut it out part-by-part working top-down and use that instead of semi-random clouds for each new frame.. I feel like it'll work, but if not, sorry
edit: actually it won't, only if you'd put every cloud in a different layer and do all blending in smaller pictures (the actual frames) and that's going to be a lot of work
edit2: that works, but it takes a lot of time..
steps followed (in case anyone is curious):
1 Make a new image with the same width as your target picture but a much bigger height
2 Run Clouds, make new layer, run Clouds again (I made 7 layers but only ever used 3 to save time)
3 In the target picture, draw the gradient and duplicate it for every frame you want
4 Select the highest part of the clouds-image that is exactly the same size as your "target" picture (fixed size is handy)
5 copy
6 Select the first layer of your target picture, create a new layer above it, set it's blend mode to Overlay and paste the clouds onto it
7 Merge
8 Repeat steps 6 and 7 for every Clouds layer you have (oh and select the layer you want otherwise it will all be the same)
9 Move to the next layer in your target picture and go back to step 4, BUT this time select a piece of clouds a bit further down
10 use Curves on all layer of the target picture
11 save all layers of target picture and unfreeze? <- I was too lazy for that
I would write plugins, if I knew what kind of plugins were needed.. :(
