DieselJC Posted June 20 Share Posted June 20 Been having freezing issues with PDN..it freezes to the point of I have to manually power off the PC...Cntrl/Alt/Tab does nothing. I have been monitoring PDN in task manager while I am using it and it's using high and very high power. I uninstalled and re-installed it, I also checked for plugin errors. BBChart.dll , ImPS,EPS,AI.Open File Type and ScriptLab.dll. I went in and removed those but it still freezes and uses high and very high power. Are there any settings I can use to help the performance or any ideas troubleshooting? System specs: AMD FX6300 4.1 Ghz Win 10 64Bit 32MB 1600Mhz RAM 500GB SSD (Windows and PDN are Installed here) 1TB HDD GeForce GTX 1070 8GB 1920x1080 144hz CPU is liqiud cooled so never goes above 36deg GPU is fan cooled stays around 55 deg PC is set to "Prefer Maximum Performance" Any help/tips would be appreciated. JC Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted June 20 Share Posted June 20 Please post the diagnostic information found within paint.net. Settings -> Diagnostics -> Copy to clipboard. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
DieselJC Posted June 20 Author Share Posted June 20 Application paint.net 4.3.11 (Stable 4.311.8179.42221) Build Date Tuesday, May 24, 2022 Install type Classic Hardware accelerated rendering (GPU) False Remote session False Animations False DPI 96 (1.00x scale) Language en-US OS Windows 10 Home x64 (10.0.19044.0) Runtime .NET 6.0.5 x64 Physical Memory 32,725 MB CPU AMD FX(tm)-6300 Six-Core Processor Speed ~3516 MHz Cores / Threads 3 / 6 Features SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, AVX Video Card NVIDIA GeForce GTX 1070 Dedicated Video RAM 8,088 MB Dedicated System RAM 0 MB Shared System RAM 16,362 MB Vendor ID 0x10DE Device ID 0x1B81 Subsystem ID 0x62763842 Revision 161 LUID 0x0000C4E9 Flags AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption PixelBoundary Compute Preemption DispatchBoundary Outputs 2 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Maximum Bitmap Size 16384 Video Card Microsoft Basic Render Driver Dedicated Video RAM 0 MB Dedicated System RAM 0 MB Shared System RAM 16,362 MB Vendor ID 0x1414 Device ID 0x008C Subsystem ID 0x00000000 Revision 0 LUID 0x0000D0C5 Flags Software, AcgCompatible, SupportMonitoredFences, KeyedMutexConformance Graphics Preemption InstructionBoundary Compute Preemption InstructionBoundary Outputs 0 Feature Level Direct3D_12_1 DXGI Formats A8_UNorm, B8G8R8A8_UNorm, R16G16B16A16_UNorm, R16G16B16A16_Float, R32G32B32A32_Float Buffer Precision UNorm8bpc, UNorm8bpcSrgb, UNorm16bpc, Float16bpc, Float32bpc Maximum Bitmap Size 8388608 Managed assemblies 165 System.Private.CoreLib .\System.Private.CoreLib.dll, Version=6.0.0.0, PublicKeyToken=7cec85d7bea7798e paintdotnet .\paintdotnet.dll, Version=4.311.8179.42221 System.Runtime .\System.Runtime.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Windows.Forms .\System.Windows.Forms.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 PaintDotNet.Base .\PaintDotNet.Base.dll, Version=4.311.8179.42221 System.Diagnostics.Process .\System.Diagnostics.Process.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer .\PaintDotNet.SystemLayer.dll, Version=4.311.8179.42221 TerraFX.Interop.Windows .\TerraFX.Interop.Windows.dll, Version=10.0.20348.0, PublicKeyToken=35b01b53313a6f7e System.Runtime.InteropServices.RuntimeInformation .\System.Runtime.InteropServices.RuntimeInformation.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.InteropServices .\System.Runtime.InteropServices.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.SystemLayer.Native.x64 .\PaintDotNet.SystemLayer.Native.x64.dll, Version=4.311.8179.42221 System.Threading .\System.Threading.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Extensions .\System.Runtime.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.CompilerServices.VisualC .\System.Runtime.CompilerServices.VisualC.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.NonGeneric .\System.Collections.NonGeneric.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Intrinsics .\System.Runtime.Intrinsics.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Core .\PaintDotNet.Core.dll, Version=4.311.8179.42221 System.Private.Uri .\System.Private.Uri.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.Primitives .\System.ComponentModel.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WindowsBase .\WindowsBase.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Windows.Forms.Primitives .\System.Windows.Forms.Primitives.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 PresentationFramework .\PresentationFramework.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Drawing.Primitives .\System.Drawing.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Xaml .\System.Xaml.dll, Version=6.0.2.0, PublicKeyToken=b77a5c561934e089 System.ComponentModel .\System.ComponentModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections .\System.Collections.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.TraceSource .\System.Diagnostics.TraceSource.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Thread .\System.Threading.Thread.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.Encoding.CodePages .\System.Text.Encoding.CodePages.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Resources .\PaintDotNet.Resources.dll, Version=4.311.8179.42221 System.ObjectModel .\System.ObjectModel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Primitives .\Microsoft.Win32.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Data .\PaintDotNet.Data.dll, Version=4.311.8179.42221 System.Configuration.ConfigurationManager .\System.Configuration.ConfigurationManager.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Specialized .\System.Collections.Specialized.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Private.Xml .\System.Private.Xml.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 PaintDotNet.Framework .\PaintDotNet.Framework.dll, Version=4.311.8179.42221 System.Xml.ReaderWriter .\System.Xml.ReaderWriter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Net.WebClient .\System.Net.WebClient.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.ComponentModel.EventBasedAsync .\System.ComponentModel.EventBasedAsync.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.SystemEvents .\Microsoft.Win32.SystemEvents.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Memory .\System.Memory.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Text.Encoding.Extensions .\System.Text.Encoding.Extensions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.ThreadPool .\System.Threading.ThreadPool.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Drawing.Common .\System.Drawing.Common.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Collections.Immutable .\System.Collections.Immutable.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Linq .\System.Linq.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Collections.Concurrent .\System.Collections.Concurrent.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a Microsoft.Win32.Registry .\Microsoft.Win32.Registry.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Principal.Windows .\System.Security.Principal.Windows.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Security.Claims .\System.Security.Claims.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.ComponentModel.TypeConverter .\System.ComponentModel.TypeConverter.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PresentationCore .\PresentationCore.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 DirectWriteForwarder .\DirectWriteForwarder.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.Debug .\System.Diagnostics.Debug.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a UIAutomationTypes .\UIAutomationTypes.dll, Version=6.0.2.0, PublicKeyToken=31bf3856ad364e35 System.Diagnostics.FileVersionInfo .\System.Diagnostics.FileVersionInfo.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PaintDotNet.Effects .\PaintDotNet.Effects.dll, Version=4.311.8179.42221 Accessibility .\Accessibility.dll, Version=4.0.0.0, PublicKeyToken=31bf3856ad364e35 Crc32.NET .\Crc32.NET.dll, Version=1.0.0.0, PublicKeyToken=dc0b95cf99bf4e99 System.Security.Cryptography.Primitives .\System.Security.Cryptography.Primitives.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.Packaging .\System.IO.Packaging.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Threading.Tasks.Parallel .\System.Threading.Tasks.Parallel.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Reflection.MetadataLoadContext .\System.Reflection.MetadataLoadContext.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Reflection.Metadata .\System.Reflection.Metadata.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Serialization.Formatters .\System.Runtime.Serialization.Formatters.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.IO.MemoryMappedFiles .\System.IO.MemoryMappedFiles.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.CodeDom .\System.CodeDom.dll, Version=6.0.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Numerics.Vectors .\System.Numerics.Vectors.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Diagnostics.Tracing .\System.Diagnostics.Tracing.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Loader .\System.Runtime.Loader.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a PhotoShop .\FileTypes\PhotoShop.dll, Version=2.5.0.40665 mscorlib .\mscorlib.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 System.Drawing .\System.Drawing.dll, Version=6.0.2.0, PublicKeyToken=b03f5f7f11d50a3a System .\System.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 WebPFileType .\Bundled\WebPFileType\WebPFileType.dll, Version=1.3.12.0 DdsFileTypePlus .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, Version=1.10.12.0 AvifFileType .\Bundled\AvifFileType\AvifFileType.dll, Version=1.1.19.0 Mono.Cecil .\Mono.Cecil.dll, Version=0.11.4.0, PublicKeyToken=50cebf1cceb9d05e netstandard .\netstandard.dll, Version=2.1.0.0, PublicKeyToken=cc7b13ffcd2ddd51 System.Console .\System.Console.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a WaveTextSUI .\Effects\WaveTextSUI.dll, Version=1.2.4415.33440 WaveText .\Effects\WaveText.dll, Version=1.2.4415.32811 Twist .\Effects\Twist.dll, Version=4.0.5873.25056 Trail .\Effects\Trail.dll, Version=4.0.4642.26791 TextPlus .\Effects\Textplus.dll, Version=1.0.0.0 Stitch .\Effects\Stitch.dll, Version=4.0.4642.26808 Splatter .\Effects\Splatter.dll, Version=4.0.5873.25083 SpiralText .\Effects\SpiralText.dll, Version=1.4.4415.32775 SpeechBubble .\Effects\SpeechBubble.dll, Version=2.1.4445.42029 Smudge .\Effects\Smudge.dll, Version=4.0.5873.25097 Rotate_Zoom+ .\Effects\Rotate_Zoom+.dll, Version=1.11.5237.17779 RotateTextSUI .\Effects\RotateTextSUI.dll, Version=1.1.4415.32713 RotateText .\Effects\RotateText.dll, Version=1.1.4415.32628 Random Shape Fill .\Effects\Random Shape Fill.dll, Version=4.0.4642.26910 System.Core .\System.Core.dll, Version=4.0.0.0, PublicKeyToken=b77a5c561934e089 Random Effect .\Effects\Random Effect.dll, Version=4.0.4642.26928 pxEexpansion .\Effects\pxEexpansion.dll, Version=1.0.4437.36287 Pixelate+ .\Effects\Pixelate+.dll, Version=4.0.4642.26940 Perspective .\Effects\Perspective.dll, Version=2.1.4415.36116 OutlinedGradientText .\Effects\OutlinedGradientText.dll, Version=1.2.0.0 Outline Object .\Effects\Outline Object.dll, Version=4.0.4642.26954 OilPaintingPlus .\Effects\OilPaintingPlus.dll, Version=4.6.7358.38406 MultiThreshold .\Effects\MultiThreshold.dll, Version=1.1.4330.38982 Metallize .\Effects\Metallize.dll, Version=1.2.4415.32969 MemeMaker .\Effects\MemeMaker.dll, Version=4.5.6828.38061 Liquify .\Effects\Liquify.dll, Version=4.0.5873.25113 Jitter .\Effects\Jitter.dll, Version=4.0.4642.26986 GridCheckerboard .\Effects\GridCheckerboard.dll, Version=4.5.6828.36789 Grid Warp .\Effects\Grid Warp.dll, Version=4.0.6544.34496 Gradual Stripes .\Effects\Gradual Stripes.dll, Version=2.0.6609.35577 Gradient Grid .\Effects\Gradient Grid.dll, Version=4.0.6436.36068 Gradient Blocks .\Effects\Gradient Blocks.dll, Version=4.0.4642.26658 Gradient Bars .\Effects\Gradient Bars.dll, Version=4.0.5152.23084 GaussianBlurPlus .\Effects\GaussianBlurPlus.dll, Version=4.2.5691.27401 Flip .\Effects\Flip.dll, Version=4.6.7358.36953 Film .\Effects\Film.dll, Version=4.0.4642.26607 EOEffects .\Effects\EOEffects.dll, Version=1.10.16.12 dpyColorBalance .\Effects\dpyColorBalance.dll, Version=1.1.4330.37850 Dimensions .\Effects\Dimensions.dll, Version=1.3.6826.38472 Curves+ .\Effects\Curves+.dll, Version=4.0.6119.31044 CreativeTextPro .\Effects\CreativeTextPro.dll, Version=1.1.7358.34307 Color Match .\Effects\Color Match.dll, Version=4.2.7630.21216 CircleText .\Effects\CircleText.dll, Version=1.4.4415.32488 Calendar .\Effects\Calendar.dll, Version=4.6.7358.32649 Borders N' Shapes .\Effects\Borders N' Shapes.dll, Version=4.0.4642.26476 BlackandAlpha+ .\Effects\BlackandAlpha+.dll, Version=1.2.4329.272 BBOutlinedGradientText .\Effects\BBOutlinedGradientText.dll, Version=4.6.7358.38713 Alpha_to_255 .\Effects\Alpha_to_255.dll, Version=1.0.4452.22782 Alpha_to_0 .\Effects\Alpha_to_0.dll, Version=1.0.4452.22746 AA's_Assistant .\Effects\AA's_Assistant.dll, Version=1.1.4329.33034 ColorBalance .\Effects\ColorBalance.dll, Version=4.7.7401.17173 Alpha2Gray .\Effects\Alpha2Gray.dll, Version=4.5.6832.21862 Newtonsoft.Json .\Newtonsoft.Json.dll, Version=13.0.0.0, PublicKeyToken=30ad4fe6b2a6aeed System.Linq.Expressions .\System.Linq.Expressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Text.RegularExpressions .\System.Text.RegularExpressions.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a System.Runtime.Numerics .\System.Runtime.Numerics.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a BandWPlus .\Effects\BandWPlus.dll, Version=1.3.7359.317 Burninate .\Effects\Burninate.dll, Version=4.6.7358.31797 PaintDotNet.Plugins.Compatibility .\PaintDotNet.Plugins.Compatibility.dll, Version=4.311.8179.42221 Dream .\Effects\Dream.dll, Version=4.6.7358.35004 CombinedAdjustments .\Effects\CombinedAdjustments.dll, Version=1.1.7358.40688 System.Runtime.CompilerServices.Unsafe .\System.Runtime.CompilerServices.Unsafe.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a VignettePlus .\Effects\VignettePlus.dll, Version=4.6.7358.40027 FillFromClipboard .\Effects\FillFromClipboard.dll, Version=4.7.7358.36519 Gray2Alpha .\Effects\Gray2Alpha.dll, Version=4.5.6826.36897 HueSatPlus .\Effects\HueSatPlus.dll, Version=4.6.7359.209 System.Diagnostics.StackTrace .\System.Diagnostics.StackTrace.dll, Version=6.0.0.0, PublicKeyToken=b03f5f7f11d50a3a HSVGradients .\Effects\HSVGradients.dll, Version=4.5.6832.41864 FloydSteinbergDithering .\Effects\FloydSteinbergDithering.dll, Version=4.6.7358.37110 LevelHorizon .\Effects\LevelHorizon.dll, Version=4.6.7358.37589 Transparency .\Effects\Transparency.dll, Version=4.6.7358.39871 FillFromFile .\Effects\FillFromFile.dll, Version=4.7.7358.36581 Landscape .\Effects\Landscape.dll, Version=4.6.7358.37463 PasteAlpha .\Effects\PasteAlpha.dll, Version=4.6.7358.38804 Pastel .\Effects\Pastel.dll, Version=4.6.7358.38877 Gradient Mapping .\Effects\Gradient Mapping.dll, Version=4.0.6547.33963 RemoveDust .\Effects\RemoveDust.dll, Version=4.5.6826.37862 PhotoAdjustments .\Effects\PhotoAdjustments.dll, Version=4.6.7358.38979 Temperature .\Effects\Temperature.dll, Version=4.6.7358.39746 SeamCarving .\Effects\SeamCarving.dll, Version=4.6.7358.39596 Polygon .\Effects\Polygon.dll, Version=4.5.6828.38648 ObjectTools .\Effects\ObjectTools.dll, Version=5.0.7502.21624 SelectionTools .\Effects\SelectionTools.dll, Version=5.0.7502.22140 System.IO.Compression .\System.IO.Compression.dll, Version=6.0.0.0, PublicKeyToken=b77a5c561934e089 Native modules 238 paintdotnet.exe .\paintdotnet.exe, version=4.311.8179.42221 ntdll.dll C:\WINDOWS\SYSTEM32\ntdll.dll, version=10.0.19041.1741 (WinBuild.160101.0800) KERNEL32.DLL C:\WINDOWS\System32\KERNEL32.DLL, version=10.0.19041.1741 (WinBuild.160101.0800) KERNELBASE.dll C:\WINDOWS\System32\KERNELBASE.dll, version=10.0.19041.1741 (WinBuild.160101.0800) USER32.dll C:\WINDOWS\System32\USER32.dll, version=10.0.19041.1 (WinBuild.160101.0800) win32u.dll C:\WINDOWS\System32\win32u.dll, version=10.0.19041.1766 (WinBuild.160101.0800) GDI32.dll C:\WINDOWS\System32\GDI32.dll, version=10.0.19041.1620 (WinBuild.160101.0800) gdi32full.dll C:\WINDOWS\System32\gdi32full.dll, version=10.0.19041.1706 (WinBuild.160101.0800) msvcp_win.dll C:\WINDOWS\System32\msvcp_win.dll, version=10.0.19041.789 (WinBuild.160101.0800) ucrtbase.dll C:\WINDOWS\System32\ucrtbase.dll, version=10.0.19041.789 (WinBuild.160101.0800) SHELL32.dll C:\WINDOWS\System32\SHELL32.dll, version=10.0.19041.964 (WinBuild.160101.0800) ADVAPI32.dll C:\WINDOWS\System32\ADVAPI32.dll, version=10.0.19041.1 (WinBuild.160101.0800) msvcrt.dll C:\WINDOWS\System32\msvcrt.dll, version=7.0.19041.546 (WinBuild.160101.0800) sechost.dll C:\WINDOWS\System32\sechost.dll, version=10.0.19041.1 (WinBuild.160101.0800) RPCRT4.dll C:\WINDOWS\System32\RPCRT4.dll, version=10.0.19041.1 (WinBuild.160101.0800) IMM32.DLL C:\WINDOWS\System32\IMM32.DLL, version=10.0.19041.546 (WinBuild.160101.0800) hostfxr.dll .\hostfxr.dll, version=6,0,522,21309 @Commit: 70ae3df4a6f3c92fb6b315afc405edd10ff38579 hostpolicy.dll .\hostpolicy.dll, version=6,0,522,21309 @Commit: 70ae3df4a6f3c92fb6b315afc405edd10ff38579 coreclr.dll .\coreclr.dll, version=6,0,522,21309 @Commit: 70ae3df4a6f3c92fb6b315afc405edd10ff38579 ole32.dll C:\WINDOWS\System32\ole32.dll, version=10.0.19041.1320 (WinBuild.160101.0800) combase.dll C:\WINDOWS\System32\combase.dll, version=10.0.19041.1320 (WinBuild.160101.0800) OLEAUT32.dll C:\WINDOWS\System32\OLEAUT32.dll, version=10.0.19041.985 (WinBuild.160101.0800) bcryptPrimitives.dll C:\WINDOWS\System32\bcryptPrimitives.dll, version=10.0.19041.1415 (WinBuild.160101.0800) System.Private.CoreLib.dll .\System.Private.CoreLib.dll, version=6.0.522.21309 clrjit.dll .\clrjit.dll, version=6,0,522,21309 @Commit: 70ae3df4a6f3c92fb6b315afc405edd10ff38579 kernel.appcore.dll C:\WINDOWS\SYSTEM32\kernel.appcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) paintdotnet.dll .\paintdotnet.dll, version=4.311.8179.42221 System.Runtime.dll .\System.Runtime.dll, version=6.0.522.21309 uxtheme.dll C:\WINDOWS\system32\uxtheme.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Windows.Forms.dll .\System.Windows.Forms.dll, version=6.0.422.16407 PaintDotNet.Base.dll .\PaintDotNet.Base.dll, version=4.311.8179.42221 System.Diagnostics.Process.dll .\System.Diagnostics.Process.dll, version=6.0.522.21309 PaintDotNet.SystemLayer.dll .\PaintDotNet.SystemLayer.dll, version=4.311.8179.42221 TerraFX.Interop.Windows.dll .\TerraFX.Interop.Windows.dll, version=10.0.20348.0 System.Runtime.InteropServices.RuntimeInformation.dll .\System.Runtime.InteropServices.RuntimeInformation.dll, version=6.0.522.21309 System.Runtime.InteropServices.dll .\System.Runtime.InteropServices.dll, version=6.0.522.21309 vcruntime140.dll .\vcruntime140.dll, version=14.32.31326.0 vcruntime140_1.dll .\vcruntime140_1.dll, version=14.32.31326.0 msvcp140.dll .\msvcp140.dll, version=14.32.31326.0 msvcp140_1.dll .\msvcp140_1.dll, version=14.32.31326.0 msvcp140_2.dll .\msvcp140_2.dll, version=14.32.31326.0 msvcp140_codecvt_ids.dll .\msvcp140_codecvt_ids.dll, version=14.32.31326.0 vcomp140.dll .\vcomp140.dll, version=14.32.31326.0 ijwhost.dll .\ijwhost.dll, version=6,0,522,21309 @Commit: 70ae3df4a6f3c92fb6b315afc405edd10ff38579 PaintDotNet.SystemLayer.Native.x64.dll .\PaintDotNet.SystemLayer.Native.x64.dll, version=4.311.8179.42221 PROPSYS.dll C:\WINDOWS\SYSTEM32\PROPSYS.dll, version=7.0.19041.1708 (WinBuild.160101.0800) gdiplus.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.19041.1706_none_919e8e54cc8d4ca1\gdiplus.dll, version=10.0.19041.1706 (WinBuild.160101.0800) WindowsCodecs.dll C:\WINDOWS\SYSTEM32\WindowsCodecs.dll, version=10.0.19041.1706 (WinBuild.160101.0800) bcrypt.dll C:\WINDOWS\System32\bcrypt.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Threading.dll .\System.Threading.dll, version=6.0.522.21309 System.Runtime.Extensions.dll .\System.Runtime.Extensions.dll, version=6.0.522.21309 System.Runtime.CompilerServices.VisualC.dll .\System.Runtime.CompilerServices.VisualC.dll, version=6.0.522.21309 System.Collections.NonGeneric.dll .\System.Collections.NonGeneric.dll, version=6.0.522.21309 System.Runtime.Intrinsics.dll .\System.Runtime.Intrinsics.dll, version=6.0.522.21309 windows.storage.dll C:\WINDOWS\SYSTEM32\windows.storage.dll, version=10.0.19041.1 (WinBuild.160101.0800) Wldp.dll C:\WINDOWS\SYSTEM32\Wldp.dll, version=10.0.19041.1 (WinBuild.160101.0800) SHCORE.dll C:\WINDOWS\System32\SHCORE.dll, version=10.0.19041.1 (WinBuild.160101.0800) shlwapi.dll C:\WINDOWS\System32\shlwapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) PaintDotNet.Core.dll .\PaintDotNet.Core.dll, version=4.311.8179.42221 System.Private.Uri.dll .\System.Private.Uri.dll, version=6.0.522.21309 System.ComponentModel.Primitives.dll .\System.ComponentModel.Primitives.dll, version=6.0.522.21309 WindowsBase.dll .\WindowsBase.dll, version=6.0.522.21509 System.Windows.Forms.Primitives.dll .\System.Windows.Forms.Primitives.dll, version=6.0.422.16407 PresentationFramework.dll .\PresentationFramework.dll, version=6.0.522.21509 System.Drawing.Primitives.dll .\System.Drawing.Primitives.dll, version=6.0.522.21309 System.Xaml.dll .\System.Xaml.dll, version=6.0.522.21509 System.ComponentModel.dll .\System.ComponentModel.dll, version=6.0.522.21309 System.Collections.dll .\System.Collections.dll, version=6.0.522.21309 System.Diagnostics.TraceSource.dll .\System.Diagnostics.TraceSource.dll, version=6.0.522.21309 System.Threading.Thread.dll .\System.Threading.Thread.dll, version=6.0.522.21309 System.Text.Encoding.CodePages.dll .\System.Text.Encoding.CodePages.dll, version=6.0.522.21309 PaintDotNet.Resources.dll .\PaintDotNet.Resources.dll, version=4.311.8179.42221 System.ObjectModel.dll .\System.ObjectModel.dll, version=6.0.522.21309 Microsoft.Win32.Primitives.dll .\Microsoft.Win32.Primitives.dll, version=6.0.522.21309 PaintDotNet.Data.dll .\PaintDotNet.Data.dll, version=4.311.8179.42221 System.Configuration.ConfigurationManager.dll .\System.Configuration.ConfigurationManager.dll, version=6.0.422.16404 icu.dll C:\WINDOWS\SYSTEM32\icu.dll, version=64, 2, 0, 0 (WinBuild.160101.0800) System.Collections.Specialized.dll .\System.Collections.Specialized.dll, version=6.0.522.21309 PresentationNative_cor3.dll .\PresentationNative_cor3.dll, version=6,0,22,21304 @Commit: 3510f88911e3fea61a4eeb481d7a1fbae9795c7b System.Private.Xml.dll .\System.Private.Xml.dll, version=6.0.522.21309 PaintDotNet.Framework.dll .\PaintDotNet.Framework.dll, version=4.311.8179.42221 System.Xml.ReaderWriter.dll .\System.Xml.ReaderWriter.dll, version=6.0.522.21309 System.Net.WebClient.dll .\System.Net.WebClient.dll, version=6.0.522.21309 System.ComponentModel.EventBasedAsync.dll .\System.ComponentModel.EventBasedAsync.dll, version=6.0.522.21309 Microsoft.Win32.SystemEvents.dll .\Microsoft.Win32.SystemEvents.dll, version=6.0.422.16404 System.Memory.dll .\System.Memory.dll, version=6.0.522.21309 System.Text.Encoding.Extensions.dll .\System.Text.Encoding.Extensions.dll, version=6.0.522.21309 System.Threading.ThreadPool.dll .\System.Threading.ThreadPool.dll, version=6.0.522.21309 System.Drawing.Common.dll .\System.Drawing.Common.dll, version=6.0.422.16404 System.Collections.Immutable.dll .\System.Collections.Immutable.dll, version=6.0.522.21309 dxgi.dll C:\WINDOWS\SYSTEM32\dxgi.dll, version=10.0.19041.1741 (WinBuild.160101.0800) System.Linq.dll .\System.Linq.dll, version=6.0.522.21309 System.Collections.Concurrent.dll .\System.Collections.Concurrent.dll, version=6.0.522.21309 MSCTF.dll C:\WINDOWS\System32\MSCTF.dll, version=10.0.19041.1 (WinBuild.160101.0800) Microsoft.Win32.Registry.dll .\Microsoft.Win32.Registry.dll, version=6.0.522.21309 System.Security.Principal.Windows.dll .\System.Security.Principal.Windows.dll, version=6.0.522.21309 System.Security.Claims.dll .\System.Security.Claims.dll, version=6.0.522.21309 System.ComponentModel.TypeConverter.dll .\System.ComponentModel.TypeConverter.dll, version=6.0.522.21309 PresentationCore.dll .\PresentationCore.dll, version=6.0.522.21509 DirectWriteForwarder.dll .\DirectWriteForwarder.dll, version=6,0,522,21509 @Commit: 14bf2e54800ba75bfd06cbb4f2e470cbfffc9a5b System.Diagnostics.Debug.dll .\System.Diagnostics.Debug.dll, version=6.0.522.21309 dwrite.dll C:\WINDOWS\SYSTEM32\dwrite.dll, version=10.0.19041.1 (WinBuild.160101.0800) UIAutomationTypes.dll .\UIAutomationTypes.dll, version=6.0.522.21509 System.Diagnostics.FileVersionInfo.dll .\System.Diagnostics.FileVersionInfo.dll, version=6.0.522.21309 PaintDotNet.Effects.dll .\PaintDotNet.Effects.dll, version=4.311.8179.42221 profapi.dll C:\WINDOWS\SYSTEM32\profapi.dll, version=10.0.19041.844 (WinBuild.160101.0800) Accessibility.dll .\Accessibility.dll, version=6.0.422.16407 clbcatq.dll C:\WINDOWS\System32\clbcatq.dll, version=2001.12.10941.16384 (WinBuild.160101.0800) UIAnimation.dll C:\WINDOWS\System32\UIAnimation.dll, version=10.0.19041.746 (WinBuild.160101.0800) Crc32.NET.dll .\Crc32.NET.dll, version=1.2.0.5 System.Security.Cryptography.Primitives.dll .\System.Security.Cryptography.Primitives.dll, version=6.0.522.21309 System.IO.Packaging.dll .\System.IO.Packaging.dll, version=6.0.422.16404 System.Threading.Tasks.Parallel.dll .\System.Threading.Tasks.Parallel.dll, version=6.0.522.21309 version.dll C:\WINDOWS\SYSTEM32\version.dll, version=10.0.19041.546 (WinBuild.160101.0800) System.Reflection.MetadataLoadContext.dll .\System.Reflection.MetadataLoadContext.dll, version=6.0.21.52210 System.Reflection.Metadata.dll .\System.Reflection.Metadata.dll, version=6.0.522.21309 System.Runtime.Serialization.Formatters.dll .\System.Runtime.Serialization.Formatters.dll, version=6.0.522.21309 System.IO.MemoryMappedFiles.dll .\System.IO.MemoryMappedFiles.dll, version=6.0.522.21309 comctl32.dll C:\WINDOWS\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.19041.1110_none_60b5254171f9507e\comctl32.dll, version=6.10 (WinBuild.160101.0800) System.CodeDom.dll .\System.CodeDom.dll, version=6.0.422.16404 System.Numerics.Vectors.dll .\System.Numerics.Vectors.dll, version=6.0.522.21309 d2d1.dll C:\WINDOWS\SYSTEM32\d2d1.dll, version=10.0.19041.1 (WinBuild.160101.0800) System.Diagnostics.Tracing.dll .\System.Diagnostics.Tracing.dll, version=6.0.522.21309 TextShaping.dll C:\WINDOWS\SYSTEM32\TextShaping.dll, version= System.Runtime.Loader.dll .\System.Runtime.Loader.dll, version=6.0.522.21309 ucrtbase.dll .\ucrtbase.dll, version=10.0.22000.194 (WinBuild.160101.0800) PhotoShop.dll .\FileTypes\PhotoShop.dll, version=2.5.0.0 mscorlib.dll .\mscorlib.dll, version=6.0.522.21309 System.Drawing.dll .\System.Drawing.dll, version=6.0.422.16407 System.dll .\System.dll, version=6.0.522.21309 mfplat.dll C:\WINDOWS\SYSTEM32\mfplat.dll, version=10.0.19041.1 (WinBuild.160101.0800) cfgmgr32.dll C:\WINDOWS\System32\cfgmgr32.dll, version=10.0.19041.1620 (WinBuild.160101.0800) RTWorkQ.DLL C:\WINDOWS\SYSTEM32\RTWorkQ.DLL, version=10.0.19041.1 (WinBuild.160101.0800) CompPkgSup.DLL C:\WINDOWS\SYSTEM32\CompPkgSup.DLL, version=10.0.19041.746 (WinBuild.160101.0800) WebPFileType.dll .\Bundled\WebPFileType\WebPFileType.dll, version=1.3.12.0 DdsFileTypePlus.dll .\Bundled\DDSFileTypePlus\DdsFileTypePlus.dll, version=1.10.12.0 Windows.StateRepositoryPS.dll C:\Windows\System32\Windows.StateRepositoryPS.dll, version=10.0.19041.1466 (WinBuild.160101.0800) AvifFileType.dll .\Bundled\AvifFileType\AvifFileType.dll, version=1.1.19.0 WinTypes.dll C:\Windows\System32\WinTypes.dll, version=10.0.19041.1320 (WinBuild.160101.0800) wtsapi32.dll C:\WINDOWS\SYSTEM32\wtsapi32.dll, version=10.0.19041.546 (WinBuild.160101.0800) WINSTA.dll C:\WINDOWS\SYSTEM32\WINSTA.dll, version=10.0.19041.546 (WinBuild.160101.0800) d3d11.dll C:\WINDOWS\SYSTEM32\d3d11.dll, version=10.0.19041.1741 (WinBuild.160101.0800) D3D10Warp.dll C:\WINDOWS\SYSTEM32\D3D10Warp.dll, version=10.0.19041.546 (WinBuild.160101.0800) dxcore.dll C:\WINDOWS\SYSTEM32\dxcore.dll, version=10.0.19041.546 (WinBuild.160101.0800) UIAutomationCore.dll C:\WINDOWS\SYSTEM32\UIAutomationCore.dll, version=7.2.19041.1 (WinBuild.160101.0800) sxs.dll C:\WINDOWS\SYSTEM32\sxs.dll, version=10.0.19041.1 (WinBuild.160101.0800) Mono.Cecil.dll .\Mono.Cecil.dll, version=0.11.4.0 netstandard.dll .\netstandard.dll, version=6.0.522.21309 System.Console.dll .\System.Console.dll, version=6.0.522.21309 WaveTextSUI.dll .\Effects\WaveTextSUI.dll, version=1.2.4415.33440 WaveText.dll .\Effects\WaveText.dll, version=1.2.4415.32811 Twist.dll .\Effects\Twist.dll, version=4.0.5873.25056 Trail.dll .\Effects\Trail.dll, version=4.0.4642.26791 Textplus.dll .\Effects\Textplus.dll, version=1.0.0.0 Stitch.dll .\Effects\Stitch.dll, version=4.0.4642.26808 Splatter.dll .\Effects\Splatter.dll, version=4.0.5873.25083 SpiralText.dll .\Effects\SpiralText.dll, version=1.4.4415.32775 SpeechBubble.dll .\Effects\SpeechBubble.dll, version=2.1.4445.42029 Smudge.dll .\Effects\Smudge.dll, version=4.0.5873.25097 Rotate_Zoom+.dll .\Effects\Rotate_Zoom+.dll, version=1.11.5237.17779 RotateTextSUI.dll .\Effects\RotateTextSUI.dll, version=1.1.4415.32713 RotateText.dll .\Effects\RotateText.dll, version=1.1.4415.32628 Random Shape Fill.dll .\Effects\Random Shape Fill.dll, version=4.0.4642.26910 System.Core.dll .\System.Core.dll, version=6.0.522.21309 Random Effect.dll .\Effects\Random Effect.dll, version=4.0.4642.26928 pxEexpansion.dll .\Effects\pxEexpansion.dll, version=1.0.4437.36287 Pixelate+.dll .\Effects\Pixelate+.dll, version=4.0.4642.26940 Perspective.dll .\Effects\Perspective.dll, version=2.1.4415.36116 OutlinedGradientText.dll .\Effects\OutlinedGradientText.dll, version=1.2.0.0 Outline Object.dll .\Effects\Outline Object.dll, version=4.0.4642.26954 OilPaintingPlus.dll .\Effects\OilPaintingPlus.dll, version=4.6.7358.38406 MultiThreshold.dll .\Effects\MultiThreshold.dll, version=1.1.4330.38982 Metallize.dll .\Effects\Metallize.dll, version=1.2.4415.32969 MemeMaker.dll .\Effects\MemeMaker.dll, version=4.5.6828.38061 Liquify.dll .\Effects\Liquify.dll, version=4.0.5873.25113 Jitter.dll .\Effects\Jitter.dll, version=4.0.4642.26986 GridCheckerboard.dll .\Effects\GridCheckerboard.dll, version=4.5.6828.36789 Grid Warp.dll .\Effects\Grid Warp.dll, version=4.0.6544.34496 Gradual Stripes.dll .\Effects\Gradual Stripes.dll, version=2.0.6609.35577 Gradient Grid.dll .\Effects\Gradient Grid.dll, version=4.0.6436.36068 Gradient Blocks.dll .\Effects\Gradient Blocks.dll, version=4.0.4642.26658 Gradient Bars.dll .\Effects\Gradient Bars.dll, version=4.0.5152.23084 GaussianBlurPlus.dll .\Effects\GaussianBlurPlus.dll, version=4.2.5691.27401 Flip.dll .\Effects\Flip.dll, version=4.6.7358.36953 Film.dll .\Effects\Film.dll, version=4.0.4642.26607 EOEffects.dll .\Effects\EOEffects.dll, version=1.10.16.12 dpyColorBalance.dll .\Effects\dpyColorBalance.dll, version=1.1.4330.37850 Dimensions.dll .\Effects\Dimensions.dll, version=1.3.6826.38472 Curves+.dll .\Effects\Curves+.dll, version=4.0.6119.31044 CreativeTextPro.dll .\Effects\CreativeTextPro.dll, version=1.1.7358.34307 Color Match.dll .\Effects\Color Match.dll, version=4.2.7630.21216 CircleText.dll .\Effects\CircleText.dll, version=1.4.4415.32488 Calendar.dll .\Effects\Calendar.dll, version=4.6.7358.32649 Borders N' Shapes.dll .\Effects\Borders N' Shapes.dll, version=4.0.4642.26476 BlackandAlpha+.dll .\Effects\BlackandAlpha+.dll, version=1.2.4329.272 dwmapi.DLL C:\WINDOWS\SYSTEM32\dwmapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) BBOutlinedGradientText.dll .\Effects\BBOutlinedGradientText.dll, version=4.6.7358.38713 Alpha_to_255.dll .\Effects\Alpha_to_255.dll, version=1.0.4452.22782 Alpha_to_0.dll .\Effects\Alpha_to_0.dll, version=1.0.4452.22746 dataexchange.dll C:\WINDOWS\system32\dataexchange.dll, version=10.0.19041.1387 (WinBuild.160101.0800) dcomp.dll C:\WINDOWS\system32\dcomp.dll, version=10.0.19041.1741 (WinBuild.160101.0800) twinapi.appcore.dll C:\WINDOWS\system32\twinapi.appcore.dll, version=10.0.19041.1 (WinBuild.160101.0800) AA's_Assistant.dll .\Effects\AA's_Assistant.dll, version=1.1.4329.33034 amsi.dll C:\WINDOWS\SYSTEM32\amsi.dll, version=10.0.19041.1620 (WinBuild.160101.0800) USERENV.dll C:\WINDOWS\SYSTEM32\USERENV.dll, version=10.0.19041.1 (WinBuild.160101.0800) MpOav.dll C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.2203.5-0\MpOav.dll, version=4.18.2203.5 (WinBuild.160101.0800) MPCLIENT.DLL C:\ProgramData\Microsoft\Windows Defender\Platform\4.18.2203.5-0\MPCLIENT.DLL, version=4.18.2203.5 (WinBuild.160101.0800) CRYPT32.dll C:\WINDOWS\System32\CRYPT32.dll, version=10.0.19041.1 (WinBuild.160101.0800) WINTRUST.dll C:\WINDOWS\System32\WINTRUST.dll, version=10.0.19041.1741 (WinBuild.160101.0800) MSASN1.dll C:\WINDOWS\System32\MSASN1.dll, version=10.0.19041.546 (WinBuild.160101.0800) gpapi.dll C:\WINDOWS\SYSTEM32\gpapi.dll, version=10.0.19041.1 (WinBuild.160101.0800) textinputframework.dll C:\WINDOWS\SYSTEM32\textinputframework.dll, version=10.0.19041.1741 (WinBuild.160101.0800) CoreUIComponents.dll C:\WINDOWS\System32\CoreUIComponents.dll, version=10.0.19041.546 CoreMessaging.dll C:\WINDOWS\System32\CoreMessaging.dll, version=10.0.19041.746 WS2_32.dll C:\WINDOWS\System32\WS2_32.dll, version=10.0.19041.1081 (WinBuild.160101.0800) ntmarta.dll C:\WINDOWS\SYSTEM32\ntmarta.dll, version=10.0.19041.1 (WinBuild.160101.0800) Newtonsoft.Json.dll .\Newtonsoft.Json.dll, version=13.0.1.25517 System.Linq.Expressions.dll .\System.Linq.Expressions.dll, version=6.0.522.21309 powrprof.dll C:\WINDOWS\SYSTEM32\powrprof.dll, version=10.0.19041.1 (WinBuild.160101.0800) UMPDC.dll C:\WINDOWS\SYSTEM32\UMPDC.dll, version= System.Text.RegularExpressions.dll .\System.Text.RegularExpressions.dll, version=6.0.522.21309 System.Runtime.Numerics.dll .\System.Runtime.Numerics.dll, version=6.0.522.21309 winmm.DLL C:\WINDOWS\SYSTEM32\winmm.DLL, version=10.0.19041.1 (WinBuild.160101.0800) PaintDotNet.Plugins.Compatibility.dll .\PaintDotNet.Plugins.Compatibility.dll, version=4.311.8179.42221 System.Runtime.CompilerServices.Unsafe.dll .\System.Runtime.CompilerServices.Unsafe.dll, version=6.0.522.21309 oleacc.dll C:\WINDOWS\SYSTEM32\oleacc.dll, version=7.2.19041.746 (WinBuild.160101.0800) System.Diagnostics.StackTrace.dll .\System.Diagnostics.StackTrace.dll, version=6.0.522.21309 Microsoft.DiaSymReader.Native.amd64.dll .\Microsoft.DiaSymReader.Native.amd64.dll, version=14.28.29715.1 built by: vcwrkspc System.IO.Compression.dll .\System.IO.Compression.dll, version=6.0.522.21309 setupapi.DLL C:\WINDOWS\System32\setupapi.DLL, version=10.0.19041.1 (WinBuild.160101.0800) DEVOBJ.dll C:\WINDOWS\SYSTEM32\DEVOBJ.dll, version=10.0.19041.1620 (WinBuild.160101.0800) cryptnet.dll C:\WINDOWS\SYSTEM32\cryptnet.dll, version=10.0.19041.906 (WinBuild.160101.0800) drvstore.dll C:\WINDOWS\SYSTEM32\drvstore.dll, version=10.0.19041.1566 (WinBuild.160101.0800) cryptbase.dll C:\WINDOWS\SYSTEM32\cryptbase.dll, version=10.0.19041.546 (WinBuild.160101.0800) imagehlp.dll C:\WINDOWS\System32\imagehlp.dll, version=10.0.19041.1415 (WinBuild.160101.0800) CRYPTSP.dll C:\WINDOWS\System32\CRYPTSP.dll, version=10.0.19041.546 (WinBuild.160101.0800) rsaenh.dll C:\WINDOWS\system32\rsaenh.dll, version=10.0.19041.1 (WinBuild.160101.0800) nvspcap64.dll C:\WINDOWS\system32\nvspcap64.dll, version=3.25.1.27 Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 20 Share Posted June 20 Possibly this? Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 20 Share Posted June 20 Also why do you have Hardware Accelerated Rendering disabled? You have a perfectly good GPU, you're destroying performance by disabling that. This will become very important in the next big update. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 20 Share Posted June 20 It's also very important to know the size (in pixels) of images you're working with, and how many layers. As far as we know you're working with images that are just way too big for your CPU to handle (the AMD FX processors are actually very slow). Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
DieselJC Posted June 20 Author Share Posted June 20 Thanks for the reply Rick, I went into defender and allowed PDN...it wasn't on the list so I added it manually to allow it. I'll try tomorrow as I have some work I need to do and see what happens. Thanks again for the reply. I'll post back what happens and if that helped/solved the issue. JC Quote Link to comment Share on other sites More sharing options...
DieselJC Posted June 20 Author Share Posted June 20 11 minutes ago, Rick Brewster said: Also why do you have Hardware Accelerated Rendering disabled? You have a perfectly good GPU, you're destroying performance by disabling that. This will become very important in the next big update. I disabled that thinking it might help and of course it didn't so I will re-enable it. Yeah a new MB RAM and CPU are on my wish list. Anything else in that list I should leave off or turn on? Quote Link to comment Share on other sites More sharing options...
DieselJC Posted June 20 Author Share Posted June 20 This is what I am working with 4096x4096 Its a template for a 3d in game model and I just "skin" it. This one wil be a Kwik Trip Fuel Tanker skin for the game American Truck Simulator.I hide the template then flatten it and save it as a dds so the game can read it. Quote Link to comment Share on other sites More sharing options...
AndrewDavid Posted June 20 Share Posted June 20 Hi @DieselJC Are you missing DdsFileTypePlusIO_x64.dll ? Download the Filetype plugin to see the three files required for DDS files. Hope this helps Quote Link to comment Share on other sites More sharing options...
DieselJC Posted June 20 Author Share Posted June 20 9 hours ago, AndrewDavid said: Hi @DieselJC Are you missing DdsFileTypePlusIO_x64.dll ? Download the Filetype plugin to see the three files required for DDS files. Hope this helps Sorry where would I find that plugin? JC Quote Link to comment Share on other sites More sharing options...
ReMake Posted June 20 Share Posted June 20 https://forums.getpaint.net/topic/111731-dds-filetype-plus-04-11-2022/ 1 Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 20 Share Posted June 20 I don't think the DDS files have anything to do with this, @AndrewDavid @ReMake Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 21 Share Posted June 21 If you're still having freezing / high CPU usage, you can capture something called a "performance trace": https://forums.getpaint.net/topic/113249-how-to-submit-a-performance-trace/ It's a little involved, but it should show me exactly where in my code the CPU usage is happening. From there I should be able to tell you if it's "normal" or if there's something wrong that I need to fix. (those performance traces are no joke -- it's what Microsoft uses for their own performance telemetry/analysis systems, like for Windows) Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
DieselJC Posted June 21 Author Share Posted June 21 6 hours ago, Rick Brewster said: I don't think the DDS files have anything to do with this, @AndrewDavid @ReMake Yeah I checked that forum post about the dds file type and it says that the newer versions include that so I didn't download it. Quote Link to comment Share on other sites More sharing options...
DieselJC Posted June 21 Author Share Posted June 21 1 hour ago, Rick Brewster said: If you're still having freezing / high CPU usage, you can capture something called a "performance trace": https://forums.getpaint.net/topic/113249-how-to-submit-a-performance-trace/ It's a little involved, but it should show me exactly where in my code the CPU usage is happening. From there I should be able to tell you if it's "normal" or if there's something wrong that I need to fix. (those performance traces are no joke -- it's what Microsoft uses for their own performance telemetry/analysis systems, like for Windows) I'm doing some stuff tonight with PDN so I will keep an eye on it. I did allow it through Microsoft defender so it definitely seems to start up faster. Thats weird that defender would hamper that isn't it? You'd think if it flagged the program I would get a notification or it just wouldn't allow it to start. Also should I run PDN as an administrator? JC Quote Link to comment Share on other sites More sharing options...
BoltBait Posted June 21 Share Posted June 21 1 hour ago, DieselJC said: should I run PDN as an administrator? No 2 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
DieselJC Posted June 21 Author Share Posted June 21 20 hours ago, Rick Brewster said: If you're still having freezing / high CPU usage, you can capture something called a "performance trace": https://forums.getpaint.net/topic/113249-how-to-submit-a-performance-trace/ It's a little involved, but it should show me exactly where in my code the CPU usage is happening. From there I should be able to tell you if it's "normal" or if there's something wrong that I need to fix. (those performance traces are no joke -- it's what Microsoft uses for their own performance telemetry/analysis systems, like for Windows) I'll run that performance trace this week if I have time and get back to you as I'm still having issues. Thanks for the reply. JC Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 22 Share Posted June 22 @DieselJC, I didn't see anything out of the ordinary in the performance trace you sent me. It looks like PDN is using a lot of memory, at least 15GB, so it's probably the case that the image(s) you're working with are just too much for your CPU to comfortably handle. The AMD FX processors are notorious for having very poor performance. They had a weird architecture where every 2 cores shares a single floating point "core". So performance for many things related to graphics, gaming, rendering, etc. are significantly hampered. If I remember my history correctly, AMD was betting on those kinds of workloads moving to the GPU, and they just made the wrong bet (many things did move to the GPU, but the CPU still remained very important, even more so). That's why Intel was able to basically destroy them for much of the 2010s until Ryzen finally showed up. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
DieselJC Posted June 23 Author Share Posted June 23 9 hours ago, Rick Brewster said: @DieselJC, I didn't see anything out of the ordinary in the performance trace you sent me. It looks like PDN is using a lot of memory, at least 15GB, so it's probably the case that the image(s) you're working with are just too much for your CPU to comfortably handle. The AMD FX processors are notorious for having very poor performance. They had a weird architecture where every 2 cores shares a single floating point "core". So performance for many things related to graphics, gaming, rendering, etc. are significantly hampered. If I remember my history correctly, AMD was betting on those kinds of workloads moving to the GPU, and they just made the wrong bet (many things did move to the GPU, but the CPU still remained very important, even more so). That's why Intel was able to basically destroy them for much of the 2010s until Ryzen finally showed up. Thanks for the heads up on the WPR, yeah I'm shopping for a new MB RAM and CPU at the moment but it may by a bit before I can get the set up I want. Thanks again for the reply much appreciated. JC Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 23 Share Posted June 23 Well the good news is that the current crop of CPUs are all quite capable. Both AMD and Intel have very strong offerings. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
DieselJC Posted June 28 Author Share Posted June 28 On 6/22/2022 at 10:28 PM, Rick Brewster said: Well the good news is that the current crop of CPUs are all quite capable. Both AMD and Intel have very strong offerings. I am looking at a new MB and CPU..an AMD Ryzen 5 5000 series 4.2 Ghz. and an MSI MB. Would 16GB of RAM be good to run PDN on or do I need to go to 32? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 28 Share Posted June 28 If you can comfortably afford 32GB then definitely get 32GB. You're already using a lot of RAM for your Paint.NET needs, and you already have 32GB in your current system. Going to 16GB would be a step down, and invite further performance issues even with the new CPU and other parts. My general advice for RAM is to buy as much as you can comfortably afford. 64GB would give you more room to grow, it's just about whether you can justify the cost. You can also get 2 x 16GB memory DIMMs now which should enable you to add another 2 x 16GB DIMMs later on (assuming the motherboard has 4 DIMM slots, which most do, unless they're ITX (small)). 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
