KoboldBluw2 Posted April 20, 2022 Share Posted April 20, 2022 How can i make a texture like this HELP! Quote Link to comment Share on other sites More sharing options...
MJW Posted April 20, 2022 Share Posted April 20, 2022 For the green and beige textures, if you want something simple, try: Create a new image (which will be white) (I used a 600x600 image, and I think you'll need to create one about that size then scale it down when done to match the examples.) Noise>Add Noise -- Color Saturation: 0 Repeat Add Noise twice more Blur>Gaussian Blur -- Radius 2 (default) Stylize>Relief -- Angle -45 One way to color it: Add a new layer above the texture layer Set the new layer's Blending Mode to Multiply. Set the Primary Color to the desired color Use Select All followed by Fill Selection to fill the layer with the Primary Color Deselect and Merge the layers Use Brightness/Contrast and Hue/Saturation to tweak the colors That looks pretty similar to me, but you'll probably want to adjust the amount of noise and the amount (and perhaps type) of blurring. If you want something fancier, you could use the Texture Shader in place of Relief. Something like: (Following the Gaussian Blur . . .) Use Invert Colors to invert the grayscale image Set the Primary Color to the desired color Run Texture Shader Image: Primary Color Texture Height Scale: 6 Directional Light Direction: 0, -130, 45 Specularity: 0 (to match your examples -- non-zero will produce a shiny look) There are many, many possible variations. EDIT: I think instead of using Relief, it's better to use Emboss (with the same -45 angle), However, that should be followed by Brightness/Contrast, with Brightness around 82, and Contrast around -27. 2 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 20, 2022 Share Posted April 20, 2022 Alternatives: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Tactilis Posted April 21, 2022 Share Posted April 21, 2022 10 hours ago, KoboldBluw2 said: How can i make a texture like this HELP! Do people not ask politely and say "please" now when seeking assistance? A lot of the new posters on this excellent forum seem to be VERY DEMANDING! Hats off to MJW, EER, and others who always respond so helpfully despite the questioner's tone. 2 1 Quote Link to comment Share on other sites More sharing options...
Pixey Posted April 21, 2022 Share Posted April 21, 2022 Also, you could try this mini tutorial: Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted April 22, 2022 Share Posted April 22, 2022 17 hours ago, Tactilis said: Do people not ask politely and say "please" now when seeking assistance? Username contains Kobold 1 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
