Splitframe Posted June 19, 2019 Share Posted June 19, 2019 (edited) What happens? When making a selection, for example a rectangular one, and you want to move the selected pixels by a fixed amount using ctrl+arrow_key a copy of the original is left behind as if you have had copied it before. What should happen? The selected pixels should just be moved without them being copied / the original being left behind unmoved. How to reproduce? See "What happens?" Edited June 19, 2019 by Splitframe Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 19, 2019 Share Posted June 19, 2019 Hi splitframe - welcome to the forum That's correct. Using the Ctrl key allows you to move a copy of the selection. REF: https://www.getpaint.net/doc/latest/MoveTools.html#12 Just use the arrow keys without the Ctrl key Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 19, 2019 Share Posted June 19, 2019 Does anyone actually rely on the “Ctrl makes a copy” behavior? This has always been weird, clumsy, and inconsistent in my mind. Can always just Ctrl C Ctrl V to do the same thing... (I suppose I can just disable it and see if anyone notices...) 1 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 20, 2019 Share Posted June 20, 2019 I find it useful now that I've become familiar with it. It is quirky because of it's similarity to this shortcut: Shift current tool 10 pixels Hold Ctrl + Arrow keys ↑ ← ↓ → (may not work with all tools) The trick is to use the arrow key first, then use Ctrl + arrow key combination to move by 10px (yes, I get it wrong often) 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 21, 2019 Share Posted June 21, 2019 I've removed this functionality for the next update Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
docnich Posted June 22, 2019 Share Posted June 22, 2019 Looks like I'm too late, but: I'm new here, but I use it and I like it. As was stated above, tap the arrow key first then use control and it does not duplicate. It works well for me. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 22, 2019 Share Posted June 22, 2019 You can use Ctrl+C (Copy), Ctrl+V (Paste) to replicate the old behavior. 1 Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
BoltBait Posted June 22, 2019 Share Posted June 22, 2019 29 minutes ago, docnich said: I'm new here, but I use it and I like it. There's always one... 🙄 😁 Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
