Honeyporter Posted March 13, 2006 Share Posted March 13, 2006 How do I lighten a dark photograph, and after I'm done fooling around with a pic, how do I save it as permanent? and when I do that, will it be saved as a second image, or will it replace the original photo that I have saved in "My Documents" ? Sorry, this is all new to me and I'm fairly computer illiterate. Link to comment Share on other sites More sharing options...
BuzzKill Posted March 13, 2006 Share Posted March 13, 2006 You can lighten an image by adjusting the brightness and contrast. Layers > Adjustments > Brightness/Contrast or by pressing Ctrl+Shift+C. When saving, you can do a "Save As". This will save your image as you see it but it will let you choose a specific name and file type. File > Save As or by pressing Ctrl+Shift+S. If you go to File > Save or press Ctrl+S you will save over the original file and keep the original file type. - DO NOT contact me asking for the .pdn of my avatar or the PDN logo. Thank you. Have a nice day. Link to comment Share on other sites More sharing options...
Darren Posted March 13, 2006 Share Posted March 13, 2006 I'll try to help, if your still confused after just reply and either I will try to make myself more clear or I'm sure someone else will do a better job. Ok, here goes. 1. How do I lighten a dark photograph? Ans: If you open the photo in paint.net, then go to Layers (in the menu bar at the very top) => Adjustments => brightness/contrast. You can then fiddle about with the sliders in that window, don't worry if you mess up, just click on the reset buttons and all will be fine. 2. After I'm done fooling around with a pic, how do I save it as permanent? Good question. Ans: When your happy with the picture go to file (again at the very top) => Save as... (make sure you click "save as..." and not "Save"). Ok, once there you will see a box similar to the one you see below. Where I have circled below, click on the arrow and you will get a list of very strange looking words, these are the different files you can save the picture as, I generaly save a permentant picture as a JPEG, though depending on what you want to do with it depends on what file you save it as. When you have choosen the file you want to save the picture as click on save. 3. When I do that, will it be saved as a second image, or will it replace the original photo that I have saved in "My Documents" ? Ans: Going on from the previous question, it will only be saved over the original picture if 1) it has the same name 2) its the same file type and 3) its in the same folder, but you will recieve a warning if those statements are true. If you want to keep the original picture, just save the new one with a different name, something as simple as 'Picture1' instead of 'Picture' will sufice. Hope that helps. Darren. Link to comment Share on other sites More sharing options...
abdoo Posted June 14, 2007 Share Posted June 14, 2007 lolllllll of the tile and sorry also Link to comment Share on other sites More sharing options...
Ash Posted June 14, 2007 Share Posted June 14, 2007 READ: This forum is reserved for Tutorial publishing ONLY All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
Bob Posted June 14, 2007 Share Posted June 14, 2007 abdoo WTF? Really. Are you going to answer to every post you'll find funny, EVEN IF IT'S TWO MONTHS OLD??? It's against the rules, and you've already warned before. No. Way. I've just seen Bob. And... *poof!*—just like that—he disappears into the mist again. ~Helio Link to comment Share on other sites More sharing options...
abdoo Posted June 15, 2007 Share Posted June 15, 2007 abdoo WTF?Really. Are you going to answer to every post you'll find funny, EVEN IF IT'S TWO MONTHS OLD??? It's against the rules, and you've already warned before. Edited by Rick: Removed profanity and stupidity Link to comment Share on other sites More sharing options...
Ash Posted June 15, 2007 Share Posted June 15, 2007 You are just asking to be ban??aren't you?? All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
Jud@s Posted June 15, 2007 Share Posted June 15, 2007 Jud@s washes abdoo's mouth out with soap Remember that this is a family forum abdoo... not nice using such language here! :evil: 100% PDN Link to comment Share on other sites More sharing options...
pyrochild Posted June 15, 2007 Share Posted June 15, 2007 EVEN IF IT'S TWO MONTHS OLD??? 1 year, 3 months actually. Someone please close this thread. And clean up abdoo's post as well. ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 15, 2007 Share Posted June 15, 2007 Sorry abdoo, you're banned. The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
