problems with madjiks effects
im having problems with installing madgiks effects. i wanted the water reflection but it doesnt seem to show up. ive done everything that i do to all the others and they seem to work but this on dusnt. do u have any way to help me out a little?
:D
psn id: R3V-fiR3
:D
Go into File > Plugin Load Errors. Is the water reflection effect listed there?
What is the version number, as stated on the title bar when the program is open?
Why do you start a new topic as you already rise the (your) problem of Water reflection in the plugins' topic and by PM?
Why the title says problemS with effectS?
Could you explain the about otherS!
1.This period of year doesn't give me a lot of free time for PDN, be patient...
2.Could you ask someone around you (friends/family/neighbour/...) to help you to install the DLL?
3.See tatinha77 viewtopic.php?p=129291#p129291 first post and no problem with this plugin!
4.Could you provide a screenshoot of your Paint with the Effect/Distort menu open?
5.This is an old version DLL that works with PDN v3.22beta as well. Test it! http://jcljay.free.fr/pdn/Water.zip
