TechnoRobbo Posted December 18, 2015 Author Share Posted December 18, 2015 try setting the fade curve to square Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
Seerose Posted December 19, 2015 Share Posted December 19, 2015 TechnoRobbo! I look forward to see you again. Welcome. Quote Live as if you were to die tomorrow. Learn as if you were to live forever. Gandhi Link to comment Share on other sites More sharing options...
ingwer Posted May 12, 2017 Share Posted May 12, 2017 Although TR hasn't been here for a while, I want to say thank you for this excellent plugin! Despite that TR has a YT channel of his own, I made a video about this plugin, but in German only. TR's Edge Fader Extreme on YT 1 Quote Link to comment Share on other sites More sharing options...
tatjana Posted September 6, 2022 Share Posted September 6, 2022 Hallo ich habe idese tool heruntergeladen aberpaint.net erkennt dieses nicht, und wenn ich die datei mit der app öffnen möchte steht da nur das das bildformat unbekannt ist und nicht geöffnet werden kann habe ich etwas flasch gemacht? würde gerne einen rat haben mfg Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 6, 2022 Share Posted September 6, 2022 2 hours ago, tatjana said: ich habe idese tool heruntergeladen aberpaint.net erkennt dieses nicht, und wenn ich die datei mit der app öffnen möchte steht da nur das das bildformat unbekannt ist und nicht geöffnet werden kann habe ich etwas flasch gemacht? würde gerne einen rat haben I'm sorry, but we must speak in English on the forum It's okay to use the Google translate. Which version of paint.net are you using - the free version, or the store-bought? If the free version, did you put the Plugin .dll (unzipped first) into the Effects Folder? Is this what you downloaded? < Found on Page 1 > Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Panchdara Posted September 10, 2022 Share Posted September 10, 2022 (edited) Actually, listed under "TRs EFX", not "TR's Edge Fader" nor "TR's EFX" (the lack of ' made it difficult to locate in Browser as it is located at the end of the "T" section). Just sayin'. Edited September 10, 2022 by Panchdara Quote Link to comment Share on other sites More sharing options...
