xod Posted April 22, 2014 Share Posted April 22, 2014 (edited) I don't want to be critical. I know that creating a plugin requires hard work and knowledge of programming and I want to thanks everyone who gave us their work for free. TR if I do not ask too much, please check (when you have time) the code of TR's Edge Extreme Fader. Circles seems to create a kind of rounded square (inside). Edited April 22, 2014 by xod Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted April 22, 2014 Author Share Posted April 22, 2014 (edited) XOD That is the way the code works. BoltBait, I believe, gaussian blurs the Alpha Channel - very quick and very effective. Edge fader extreme was designed to follow the contour on on irregular shapes and depletes the Alpha in a series of concentric layers. The artifact is created in the real world grid of the bitmap. If a bitmap were a fractal and infinitely divisible then in theory no artifact would appear. but since the image is depleted as concentric images there is a breakdown in the perception of roundness - which utlimately doesn't really exist in a grid. Going "extreme" shows the true nature of the grid. Also there are only 256 steps between transparent and solid, this also plays into the artifact. Here's an example that might help. - Note how charly chaplin concentrically becomes a stick figure as all illusion of roundness and details disappers. Edited August 11, 2015 by TechnoRobbo 2 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
xod Posted April 22, 2014 Share Posted April 22, 2014 Ok. I understand. Thanks for the reply. I appreciate your patience to explain these things to a newbie like me. Quote Link to comment Share on other sites More sharing options...
skullbonz Posted September 12, 2014 Share Posted September 12, 2014 I think you just explained the problem I am having but not sure. When you first came out with this plugin it seemed to fade at a smoother and even rate towards the center. Somewhere along it changed and now leaves a sort of edge further in like in these pictures. Of course I no longer have the original version of your plugin to show you the then picture. It seems to act more like KrisVDM's Edge Fader plugin now. KrisVDM's Edge Fader: TR's Edge Fader Extreme: And with a cutout such as this and TR's Edge Fader Extreme; This last one is where the problem is. It used to fade at a smoother rate and did not leave that edge in the image. Not sure what changed but it's a bit different now. Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
TechnoRobbo Posted September 12, 2014 Author Share Posted September 12, 2014 Skull, I look into it, tonight, tweak it down for you Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
TechnoRobbo Posted September 13, 2014 Author Share Posted September 13, 2014 OK Skully,I diminished the edge - see if this is what u were referring to. version 5.0.6 uploaded Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
skullbonz Posted September 13, 2014 Share Posted September 13, 2014 Much better TR, thank you. I also like the new change in the UI and it seems to work faster now. I use this plugin a lot on photos when doing overlays. Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
erickz Posted September 21, 2014 Share Posted September 21, 2014 Hi TR, I downloaded the plugin on the front page, and then copy it into the "effects" folder under paint.net. But when I try to use this feature on a photo (size about 500x800px), it doesn't seems to work. Am I missing something here or did I do some process wrongly? Do I need to select anything? I just opened the photo images, and then click the "TR EFX" button, but no effects excuted on my image. Please see this screenshot for the action I did on the image. http://screencast.com/t/1dZbEFU3n I am running this on a win7 i7-2677M notebook, 4GB, 64-bit operating system. Thanks for the help... Quote Link to comment Share on other sites More sharing options...
skullbonz Posted September 21, 2014 Share Posted September 21, 2014 Reduce the size of the image or increase the canvas size. It won't work on a full size image that fills the whole canvas. Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
erickz Posted September 21, 2014 Share Posted September 21, 2014 Hi skullbonz, thanks for your reply.. I tried again by increasing the canvas size, so now there is a white and thick borderline around the image, but it still don't work. There is no effects when I applied the "TRs EFX" option. Confused ??? Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted September 22, 2014 Author Share Posted September 22, 2014 You need a transparent border so the plugin knows what to fade, it fades from transparent into solid Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
erickz Posted September 22, 2014 Share Posted September 22, 2014 Ohh ok.. Thanks TR.. I will try again later.. Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted September 25, 2014 Author Share Posted September 25, 2014 Version 5.1.0 ready for Download 3 different Fade Curves Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
iamnoob Posted June 14, 2015 Share Posted June 14, 2015 (edited) This plugin caused my PDN to crash earlier and just now caused to hang to where I had no choice but to force-close with task manager. Sorry I'm not saying more, but not sure what info is needed. P.S. - Are there any other plugins similar to this one I can use in the meantime? Edited June 14, 2015 by iamnoob Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted June 15, 2015 Author Share Posted June 15, 2015 What the conditions were before it crashed would be nice. This way I could reproduce. Size of image , PDN version your using- what steps were made prior to crash? If a crash log was produce a copy would be great it usually points right to the problem Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
skullbonz Posted June 15, 2015 Share Posted June 15, 2015 Tr how do you get the three choices you show above in this plugin? You show a linear fade, a square root fade and a square fade but none of those choices show up for me in this plugin. And yes I downloaded the latest version and it still looks like the older version. Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
rtargo20 Posted June 15, 2015 Share Posted June 15, 2015 Where do I find the download for TR's Edge v 5.1.0 ? Tried the menu and sent me back here. Help ! Quote Is it me --or do buffalo wings taste like chicken? Link to comment Share on other sites More sharing options...
Eli Posted June 15, 2015 Share Posted June 15, 2015 (edited) TR I just did get this error while using the effect: This text file was created because paint.net crashed. Please e-mail this to crashlog4@getpaint.net so we can diagnose and fix the problem. Hidden Content: Application version: paint.net 4.0.5 (Final 4.5.5454.39504) Time of crash: 6/15/2015 11:59:04 PM Application uptime: 00:02:52.3598584 Application state: Running Working set: 168,456 KiB Threads: 28 Install directory: C:\Program Files\Paint.NET Current directory: C:\Program Files\Paint.NET OS Version: 6.1.7601.65536 Service Pack 1 Workstation x86 .NET version: CLR 4.0.30319.34209 x86, FX 4.0 4.5 Processor: 4x "Intel® Core2 Quad CPU Q9550 @ 2.83GHz" @ ~2826MHz (DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1) Physical memory: 3325 MB Video card: ATI Radeon HD 2400 Pro (v:1002, d:94C1, r:0) Hardware acceleration: True (default: True) UI animations: True UI DPI: 96.00 dpi (1.00x scale) UI theme: Aero/Aero + DWM (Aero.msstyles) Updates: False, 11/28/2014 Locale: pdnr.c: en-US, hklm: en-US, hkcu: en-US, cc: en-US, cuic: en-US Flags: Exception details: System.InvalidOperationException: Bitmap region is already locked. at System.Drawing.Graphics.CheckErrorStatus(Int32 status) at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y, Int32 width, Int32 height) at System.Drawing.Graphics.DrawImage(Image image, Rectangle rect) at EdgeFaderEffect.EffectPluginConfigDialog.DrawGraphics() at EdgeFaderEffect.EffectPluginConfigDialog.PreviewPanel_Paint(Object sender, PaintEventArgs e) at System.Windows.Forms.Control.OnPaint(PaintEventArgs e) at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer) at System.Windows.Forms.Control.WmPaint(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) Managed assemblies: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscorlib.dll PaintDotNet, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.exe PaintDotNet.Core, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Core.dll PaintDotNet.Base, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Base.dll System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System\v4.0_4.0.0.0__b77a5c561934e089\System.dll System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Drawing\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Drawing.dll WindowsBase, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\WindowsBase\v4.0_4.0.0.0__31bf3856ad364e35\WindowsBase.dll System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Windows.Forms\v4.0_4.0.0.0__b77a5c561934e089\System.Windows.Forms.dll PaintDotNet.SystemLayer, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.dll System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Core\v4.0_4.0.0.0__b77a5c561934e089\System.Core.dll PresentationFramework, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\PresentationFramework\v4.0_4.0.0.0__31bf3856ad364e35\PresentationFramework.dll PresentationCore, Version=4.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35 @ C:\Windows\Microsoft.Net\assembly\GAC_32\PresentationCore\v4.0_4.0.0.0__31bf3856ad364e35\PresentationCore.dll PaintDotNet.Framework, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Framework.dll PaintDotNet.Resources, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Resources.dll PaintDotNet.Data, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Data.dll PaintDotNet.Effects, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.Effects.dll PaintDotNet.SystemLayer.Native.x86, Version=4.5.5454.39504, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x86.dll System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.dll System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xml\v4.0_4.0.0.0__b77a5c561934e089\System.Xml.dll System.Xaml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089 @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Xaml\v4.0_4.0.0.0__b77a5c561934e089\System.Xaml.dll "AA's_Assistant", Version=1.1.4329.33034, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AA's_Assistant.dll AdvancedRotate, Version=1.0.3663.28009, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AdvancedRotate.dll advcolorrep, Version=1.3.3303.27314, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\advcolorrep.dll AdvGrey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AdvGrey.dll AForge, Version=2.2.3.0, Culture=neutral, PublicKeyToken=c1db6ff4eaa06aeb @ C:\Program Files\Paint.NET\Effects\AForge.dll AForge.Imaging, Version=2.2.3.0, Culture=neutral, PublicKeyToken=ba8ddea9676ca48b @ C:\Program Files\Paint.NET\Effects\AForge.Imaging.dll AForge.Math, Version=2.2.3.0, Culture=neutral, PublicKeyToken=abba2e25397ee8c9 @ C:\Program Files\Paint.NET\Effects\AForge.Math.dll Alias, Version=2.0.3167.14578, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alias.dll AlignPlugin, Version=1.5.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlignPlugin.dll Alpha Transform, Version=1.0.3533.38380, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha Transform.dll Alpha-Displacement Mask, Version=1.4.1.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha-Displacement Mask.dll Alpha2Gray, Version=4.0.5284.36690, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha2Gray.dll AlphaBlur, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaBlur.dll AlphaContrast, Version=1.0.3813.18307, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaContrast.dll Alphalizer, Version=2.0.5434.24240, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alphalizer.dll AlphaMask, Version=2.0.3574.41943, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMask.dll AlphaMaskBrush, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaMaskBrush.dll AlphaThreshold, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaThreshold.dll AlphaToDots, Version=1.0.4675.19955, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AlphaToDots.dll Alpha_to_0, Version=1.0.4452.22746, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha_to_0.dll Alpha_to_255, Version=1.0.4452.22782, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Alpha_to_255.dll Anaglyph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Anaglyph.dll AnimGIF, Version=2.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AnimGIF.dll Anti-Alias by jsonchiu, Version=1.0.4348.36767, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Anti-Alias by jsonchiu.dll Apply Color, Version=1.0.4406.25220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Apply Color.dll Apply Texture, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Apply Texture.dll Asmageddon_Alpha works, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Alpha works.dll Asmageddon_Channel multiplier, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Channel multiplier.dll Asmageddon_Channel_Shift, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Channel_Shift.dll Asmageddon_Channel_Works_Plus, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Channel_Works_Plus.dll Asmageddon_Color_Percentage_Plus, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Color_Percentage_Plus.dll Asmageddon_From P to S Grey, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_From P to S Grey.dll Asmageddon_From P to S, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_From P to S.dll Asmageddon_HSV inversion, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_HSV inversion.dll Asmageddon_Hue Channeling multiply, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Hue Channeling multiply.dll Asmageddon_Hue Red Psychodelic, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Hue Red Psychodelic.dll Asmageddon_Image coder, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Image coder.dll Asmageddon_Inverto_pushing, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing.dll Asmageddon_Inverto_pushing_Caleidoscope, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing_Caleidoscope.dll Asmageddon_Inverto_pushing_plus, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Inverto_pushing_plus.dll Asmageddon_Multiplo uniqua, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Multiplo uniqua.dll Asmageddon_PS Mega, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_PS Mega.dll Asmageddon_PS Only, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_PS Only.dll Asmageddon_Pseudo water, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Pseudo water.dll Asmageddon_Quadro disorter B, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Quadro disorter B.dll Asmageddon_Quadro disorter, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Quadro disorter.dll Asmageddon_Render-Border, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Border.dll Asmageddon_Render-Quadro bumperoo, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro bumperoo.dll Asmageddon_Render-Quadro inverto, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro inverto.dll Asmageddon_Render-Quadro sharper, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Render-Quadro sharper.dll Asmageddon_RGB tricks, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_RGB tricks.dll Asmageddon_Strange Bulger B, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Strange Bulger B.dll Asmageddon_Strange Bulger, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Strange Bulger.dll Asmageddon_Strange_Bulger Kaleidoscope, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Asmageddon_Strange_Bulger Kaleidoscope.dll AutoChrome, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChrome.dll AutoChromeNoise, Version=1.0.3847.37353, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AutoChromeNoise.dll AverageColorHSL, Version=1.1.3689.22153, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AverageColorHSL.dll AviFile, Version=1.0.2920.35272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AviFile.dll AVIImport, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\AVIImport.dll Axes, Version=1.0.5464.36801, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Axes.dll Backfill, Version=1.0.3420.34534, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Backfill.dll Bars, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bars.dll BaseUtility, Version=1.0.3715.42752, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BaseUtility.dll BasicPhotoAdjustments, Version=2.1.4020.485, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BasicPhotoAdjustments.dll Basic Edge Detector, Version=2.0.5346.43075, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Basic_Edge_Detector.dll BevelObject, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BevelObject.dll Bevel, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bevel_v1.4.0.0.dll Bezncurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bezncurve.dll Bidirectional Blur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bidirectional Blur.dll Bilateral, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bilateral.dll BlackAndWhiteConverter, Version=1.1.3472.36275, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Black and White Converter.dll BlackandAlpha+, Version=1.2.4329.272, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackandAlpha+.dll BlackAndWhite, Version=1.2.3526.15024, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlackAndWhite.dll BlendModesPlus, Version=2.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BlendModesPlus.dll BoltBaitOutlineSelection2, Version=1.1.3055.24444, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BoltBaitOutlineSelection.dll Border, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Border.dll "Borders N' Shapes", Version=4.0.4642.26476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Borders N' Shapes.dll Boutons, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Boutons.dll Bullet, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Bullet.dll BumpChecker, Version=1.4.4399.25606, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\BumpChecker.dll Burninate, Version=4.0.5284.36910, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Burninate.dll CalliColour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CalliColour.dll CameraTrouserFlareV3, Version=1.1.4600.41268, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CameraTrouserFlareV3.dll Cartoonize, Version=1.0.4629.37393, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cartoonize.dll CellMakerRev, Version=1.0.3626.24472, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CellMakerRev.dll CellTexture, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CellTexture.dll Centerlines, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Centerlines.dll Channel Swap, Version=1.0.4602.41418, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channel Swap.dll Channels, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channels.dll Channel Ops, Version=1.1.5347.28486, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Channel_Ops.dll ChartWhiteBalance, Version=1.1.3284.5003, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChartWhiteBalance.dll Checkboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Checkboard.dll Chequerboard, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Chequerboard.dll ChromaKeyPlugin, Version=1.0.0.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ChromaKeyPlugin.dll circleFractal2, Version=1.1.5613.38521, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\circleFractal2.dll CircleText, Version=1.4.4415.32488, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CircleText.dll CK_Plugin, Version=1.5.5345.24808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CK_Plugin.dll Clarifaction+, Version=1.0.4406.25898, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Clarifaction+.dll Clarify, Version=1.0.4349.19613, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Clarify.dll ClipWarp, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipWarp.dll ClipWarpNew, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ClipWarpNew.dll CloudEffect, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CloudEffect.dll CMY Ghost, Version=1.0.4909.35063, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CMY Ghost.dll Cobweb, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cobweb.dll CodeLab, Version=2.5.5551.39318, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CodeLab.dll Color Dimmer, Version=1.0.4658.40889, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Dimmer.dll Color Match, Version=4.0.4642.26532, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color Match.dll Color2Alpha, Version=1.0.4975.22238, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Color2Alpha.dll coloraberation, Version=1.0.3859.18981, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\coloraberation.dll ColorBalance, Version=4.0.5284.37112, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorBalance.dll ColorExchange, Version=1.1.5002.19815, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorExchange.dll ColorMixer, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorMixer.dll ColorModulo, Version=1.1.3643.38108, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorModulo.dll ColorToAlpha, Version=2.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorToAlpha.dll ColorTrimming, Version=1.0.3167.14623, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorTrimming.dll ColorZoomBlur, Version=1.1.3873.36417, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ColorZoomBlur.dll Colour Distort2, Version=1.0.3564.18753, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Colour Distort.dll colourblindsim, Version=1.0.3891.486, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\colourblindsim.dll colourchop3, Version=1.3.3877.4590, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\colourchop3.dll coltoalphaadv, Version=1.0.3100.18431, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\coltoalphaadv.dll Compotool, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Compotool.dll Compotoolguer, Version=1.0.4293.271, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Compotoolguer.dll ConditionalPen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ConditionalPen.dll Contour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Contour.dll ConvolutionKernel, Version=1.0.3715.42752, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ConvolutionKernel.dll CopyAlpha, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CopyAlpha.dll CreateImageMap, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CreateImageMap.dll Cuboids, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Cuboids.dll LightningCurve, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurlyLines.dll CurtisBlack.Common, Version=1.0.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Common.dll CurtisBlack.Effects, Version=11.1.3736.39220, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Effects.dll CurtisBlack.Resources, Version=1.0.3490.22409, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CurtisBlack.Resources.dll Curves+, Version=4.0.4642.26561, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Curves+.dll CustomBrushesMini, Version=2.1.4039.25699, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomBrushesMini.dll CustomControls, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomControls.dll CustomFrame, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CustomFrame.dll CutoutEffect.cs, Version=1.0.2404.21446, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CutoutEffect.dll CycleHSV, Version=1.0.4909.35068, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\CycleHSV.dll DesktopBackgroundPreview, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DesktopBackgroundPreview.dll Diagonal Lines, Version=2.5.3543.22117, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Diagonal Lines.dll Diffuse, Version=1.0.3254.27766, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Diffuse.dll DirectionalBlur, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DirectionalBlur.dll Displacement, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Displacement.dll DisplayColorChangeDirection, Version=2.0.5621.37825, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DisplayColorChangeDirection.dll DispMap, Version=2.0.4919.36181, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DispMap.dll DistortingMirror, Version=1.0.4281.30602, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DistortingMirror.dll DistortThis, Version=2.6.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DistortThis.dll Donut, Version=1.0.4354.32246, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Donut.dll Dot, Version=1.0.4673.202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dot.dll dpyColorBalance, Version=1.1.4330.37850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\dpyColorBalance.dll DragFrom, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DragFrom.dll Dream, Version=4.1.5307.24374, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dream.dll DrPrepper, Version=1.4.4399.25637, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\DrPrepper.dll Dryad, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dryad.dll Dull, Version=1.0.3314.38674, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Dull.dll Earths&Greys2a, Version=1.0.4041.40688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Earths&Greys.dll EarthsAndGreys, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EarthsAndGreys.dll Echo, Version=1.0.3932.34324, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Echo.dll EdgeFader, Version=5.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdgeFader.dll edgemaster, Version=1.0.3880.5859, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\edgemaster.dll EdHarvey.Effects, Version=4.0.5120.42730, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.Effects.dll EdHarvey.FastFx, Version=0.1.3426.11348, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EdHarvey.FastFx.dll EditableText, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EditableText.dll Egalize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Egalize.dll EigenBlur, Version=1.3.3555.24648, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EigenBlur.dll EliminateBlack, Version=1.0.5618.24761, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EliminateBlack.dll EliminateWhite, Version=1.0.5618.24771, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EliminateWhite.dll EngraveEmboss, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EngraveEmboss.dll EnhanceDetails, Version=1.0.3581.22689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EnhanceDetails.dll EOEffects, Version=1.10.16.12, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\EOEffects.dll ErodeDilate, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ErodeDilate_v0.2.dll ExtendBorder, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ExtendBorder.dll Eyeshine, Version=1.0.3700.25905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Eyeshine.dll Facet, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Facet.dll Feather, Version=3.0.3723.26349, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Feather.dll FibonacciFill, Version=1.0.5265.30101, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FibonacciFill.dll FillFromClipboard, Version=4.0.5286.32881, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromClipboard.dll FillFromFile, Version=4.0.5286.32800, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FillFromFile.dll Film, Version=4.0.4642.26607, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Film.dll FilmNoir, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FilmNoir.dll FindEdges, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FindEdges.dll Fire, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fire.dll Fisheye, Version=2.2.5533.12794, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Fisheye.dll Flags, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flags.dll Flip, Version=4.0.5284.37716, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Flip.dll FlipPlugin, Version=1.0.2475.32074, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FlipPlugin.dll FloydSteinbergDithering, Version=1.0.5321.25313, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FloydSteinbergDithering.dll FloydSteinbergEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FloydSteinbergEffect.dll Frames, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Frame.dll FSPost, Version=1.0.4913.8979, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FSPost.dll FurBlur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\FurBlur.dll GaussianBlurPlus, Version=3.5.4315.35054, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GaussianBlurPlus.dll Gears, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gears.dll GenTree, Version=0.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GenTree.dll Gossamer, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gossamer.dll GpcDotNet.IA32, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GpcDotNet.IA32.dll GpcDotNet.Interface, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GpcDotNet.Interface.dll Gradient Bars, Version=4.0.5152.23084, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Bars.dll Gradient Blocks, Version=4.0.4642.26658, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blocks.dll GradientBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Blur.dll Gradient Mapping, Version=4.0.4642.26687, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gradient Mapping.dll GradientPlugIn, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientPlugIn.dll GradientsGalore, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GradientsGalore.dll Grain, Version=1.0.3854.25523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Grain.dll Gralpha, Version=1.0.3684.31203, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gralpha.dll GraphMaker, Version=3.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GraphMaker.dll Gravity, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gravity.dll Gray2Alpha, Version=4.0.5284.37903, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Gray2Alpha.dll Grid Warp, Version=4.0.5149.26776, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Grid Warp.dll GridCheckerboard, Version=3.0.5297.18928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridCheckerboard.dll GridMaker, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GridMaker.dll GrimColorReaper, Version=1.2.4299.5808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GrimColorReaper.dll GS_Plugin, Version=1.3.5345.24516, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\GS_Plugin.dll Helix, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Helix.dll HexaGrid, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HexaGrid.dll Highlight, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Highlight.dll highlightv2, Version=1.0.4253.28274, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\highlightv2.dll HighPass, Version=1.2.3903.27501, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HighPass.dll HsvEraser, Version=1.1.5625.39352, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HsvEraser.dll HSVGradients, Version=3.0.5299.30308, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HSVGradients.dll HueSatPlus, Version=4.1.5333.37244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\HueSatPlus.dll Hue_Saturation+, Version=1.0.3277.32208, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Hue_Saturation+.dll PluginCompilation, Version=1.1.2992.32335, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\illnabPlugins.dll ImageShackUpload, Version=2.6.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImageShackUpload.dll ImPDF.FileType, Version=1.3.4586.21062, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImPDF.FileType.dll ImZip.FileType, Version=0.2.0.176, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ImZip.FileType.dll IncreaseLocalContrast, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IncreaseLocalContrast.dll IniFile, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IniFile.dll InkSketch+, Version=1.0.4629.39900, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InkSketch+.dll InnerBevel, Version=1.0.5505.31722, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InnerBevel.dll InputToOutput+, Version=1.0.4548.20355, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InputToOutput+.dll InputToOutput, Version=1.0.3167.14695, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InputToOutput.dll IntenColor, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\IntenColor.dll Interlace, Version=1.0.0.5, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Interlace.dll Interlace.resources, Version=1.0.0.5, Culture=sv, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Interlace.resources.dll InvertAlpha, Version=1.0.3040.33378, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\InvertAlpha.dll isolate, Version=1.0.3303.3202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\isolate.dll PDNPI_IndirectUI, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\jchunn.dll Jitter, Version=4.0.4642.26986, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Jitter.dll JPEGEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JPEGEffect.dll NoiseReduction, Version=1.0.3747.24002, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\JPGNoiseReduction.dll KaleidoGen, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KaleidoGen.dll Kaleidoscope, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Kaleidoscope.dll kb_lens, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\kb_lens.dll KlumpNoiz, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\KlumpNoiz.dll Koch_Snowflake, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Koch_Snowflake.dll Landscape, Version=4.0.5284.38226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Landscape.dll LaplacianPyramidFilter, Version=1.0.0.2, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LaplacianPyramidFilter.dll LavEnt.Effects.Mosaic, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LavEnt.Effects.Mosaic.dll LavEnt.Effects.RoundedRectangle, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LavEnt.Effects.RoundedRectangle.dll Layer Cake, Version=1.0.4911.8147, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Layer Cake.dll Lens, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lens.dll LensFlare, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LensFlare.dll LevelHorizon, Version=1.3.5589.19863, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LevelHorizon.dll LightRays, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LightRays.dll Line Tracer, Version=1.0.4911.29141, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Line Tracer.dll LinesGrid, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LinesGrid_en.dll Linocut_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Linocut_en.dll Liquify, Version=4.0.4642.26973, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Liquify.dll LocalContrast, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LocalContrast.dll LocalNoise, Version=1.0.4674.29909, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LocalNoise.dll Lomography, Version=1.1.3182.31441, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Lomography.dll LowColor, Version=1.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\LowColor.dll Magnifier, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Magnifier.dll Majority, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Majority.dll Manual Color Correction, Version=1.0.4314.41440, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ManualColorCorrection.dll MarkupRenderer, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MarkupRenderer.dll Matrice, Version=1.0.3810.11744, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Matrice.dll MeasureSelection, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MeasureSelection.dll Metallize, Version=1.2.4415.32969, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Metallize.dll Mexican Hat Edge Detect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Mexican Hat Edge Detect.dll Mirror, Version=1.0.5250.35399, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Mirror.dll MirrorRotate, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotate.dll MirrorRotateMenu, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MirrorRotateMenu.dll MismatchEraser, Version=1.0.5641.31839, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MismatchEraser.dll Moire, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Moire.dll MosaicManiac, Version=1.0.906.8, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MosaicManiac.dll MotionSharpen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MotionSharpen.dll MultiThreshold, Version=1.1.4330.38982, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\MultiThreshold.dll Nebulous, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Nebulous.dll NeonEdges_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NeonEdges_en.dll NewtonFractal, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NewtonFractal.dll NoiseBleach, Version=1.0.4909.35542, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NoiseBleach.dll NoiseChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NoiseChoice.dll Normalize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Normalize.dll Normalizer, Version=1.8.4399.25698, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Normalizer.dll NormalMapPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\NormalMapPlus.dll Norm_Render, Version=7.3.4484.27012, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Norm_Render.dll Object2Colour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Object2Colour.dll ObjectEdge, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Objectedge.dll ObjectTools, Version=4.1.5513.37206, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ObjectTools.dll Oblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Oblique.dll Offset, Version=1.0.4914.19410, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Offset.dll Olden, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Olden.dll OptionBasedLibrary v0.6, Version=0.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OptionBasedLibrary v0.6.dll OptiPngFileType, Version=8.11.30.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OptiPngFileType.dll OtherFarmColorReplacer, Version=1.1.3263.11631, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OtherFarmColorReplacer.dll Outline Object, Version=4.0.4642.26954, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Outline Object.dll OutlineSelection, Version=1.0.3055.21360, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\OutlineSelection.dll Overblur, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overblur.dll Overliner, Version=1.2.3888.29226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Overliner.dll PageCurl, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PageCurl.dll Panelling, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Panelling.dll PaperKaleidocycles, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PaperKaleidocycles.dll ParallelLines.Effect, Version=1.5.0.549, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ParallelLines.Effect.dll PasteAlpha, Version=4.0.5284.38515, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteAlpha.dll PasteFill, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PasteFill.dll Pastel, Version=4.0.5284.38621, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pastel.dll PathTools.Effect, Version=0.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PathTools.Effect.dll PdnColorInpaintingFilter, Version=1.0.3704.35070, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PdnColorInpaintingFilter.dll PdnGaborFilter, Version=1.0.3715.42752, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PdnGaborFilter.dll PdnManualColorFilter, Version=1.0.3704.35071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PdnManualColorFilter.dll PDNWatermark, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PDNWatermark.dll PerlinTexture, Version=1.1.3857.30918, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerlinTexture.dll Perspective, Version=2.1.4415.36116, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Perspective.dll PerspectiveLines1_2, Version=1.2.3679.1005, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerspectiveLines1_2.dll PerspectiveTransformation, Version=1.1.5517.38750, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PerspectiveTransformation.dll phips_fill_gaps, Version=1.0.3307.18956, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_fill_gaps.dll phips_kill_color, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_kill_color.dll phips_selective_enhancer, Version=1.1.3302.33189, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\phips_selective_enhancer.dll Photo Alignment Tool, Version=1.0.4270.27021, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Photo Alignment Tool.dll PhotoAdjustments, Version=4.0.5284.38689, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoAdjustments.dll PhotoFloodFillPlugIn, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PhotoFloodFillPlugIn.dll Pixelate+, Version=4.0.4642.26940, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Pixelate+.dll PixelatedFrame, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PixelatedFrame.dll Planetoid, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Planetoid.dll PlugInData, Version=1.0.2.10493, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PlugInData.dll PNGSpriteMatrix, Version=1.0.0.11174, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PNGSpriteMatrix.dll PNG Preprocessor, Version=1.0.3876.32360, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PNG_Preprocessor.dll PointBlur, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PointBlur.dll Polar, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polar.dll PolariodFrame, Version=1.0.3171.27990, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PolariodFrame.dll Polygon Tool, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon Tool.dll Polygon, Version=4.0.5284.38954, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygon.dll Polygones, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Polygones.dll posterize+, Version=1.0.4629.2600, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\posterize+.dll PosterizeAlpha, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PosterizeAlpha.dll PowerStretch20Beta, Version=1.9.3045.14671, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PowerStretch.dll PrinterPlus, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PrinterPlus.dll PSFilterPdn, Version=1.0.5.3, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\PSFilterPdn.dll Psychocolour, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Psychocolour.dll pxEexpansion, Version=1.0.4437.36287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pxEexpansion.dll pyrochild.effects.REQUIRED, Version=3.6.3742.39840, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\pyrochild.effects.REQUIRED.dll quarterizer, Version=1.0.5459.32288, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\quarterizer.dll Quick Gravity, Version=1.0.4408.25818, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Quick Gravity.dll RadialBlurDeluxe, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadialBlurDeluxe_v0.1.dll Radialcolors, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Radialcolors.dll RadialFade, Version=1.3.5401.38798, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadialFade.dll RadiusFillCorners, Version=1.3.5537.9144, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RadiusFillCorners.dll rainball, Version=1.0.4907.41850, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\rainball.dll rainbow loom, Version=3.0.3530.27322, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\rainbow loom.dll Rainbow-Splitter, Version=1.0.4639.2372, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rainbow-Splitter.dll RainbowTwist, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RainbowTwist.dll Random Effect, Version=4.0.4642.26928, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Effect.dll RandLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random lines.dll RandMaze1, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze1.dll RandMaze2, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Maze2.dll Random Shape Fill, Version=4.0.4642.26910, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Random Shape Fill.dll RecolourChoice, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RecolourChoice.dll RectangleEraser, Version=1.0.5630.22007, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RectangleEraser.dll RectToPolar, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RectToPolar.dll RedEyeQuickFix, Version=1.1.3161.39688, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RedEyeQuickFix.dll RefocusingSDe, Version=1.0.3760.21016, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RefocusingSDe.dll RemoveBrightDark, Version=1.1.3063.36415, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveBrightDark.dll RemoveDust, Version=4.0.5284.39560, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveDust.dll RemoveWhite, Version=1.0.3305.41952, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RemoveWhite.dll Reticulation, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Reticulation.dll ReverseColors, Version=1.0.4121.15722, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseColors.dll ReverseFisheye, Version=1.0.5146.26176, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ReverseFisheye.dll Rosaces, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rosaces.dll RotateText, Version=1.1.4415.32628, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateText.dll RotateTextSUI, Version=1.1.4415.32713, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotateTextSUI.dll Rotate_Zoom+, Version=1.11.5237.17779, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Rotate_Zoom+.dll RotationBilinear, Version=1.1.3594.29946, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\RotationBilinear.dll SaturationRGB_en, Version=1.0.5395.16586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SaturationRGB_en.dll Saturation to Alpha, Version=1.0.5346.26026, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Saturation_to_Alpha.dll SBCommon, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SBCommon.dll ScanLines, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScanLines.dll Scintillate, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Scintillate.dll ScreenPixel, Version=1.1.5534.1997, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScreenPixel.dll Scribble, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Scribble.dll ScriptLab, Version=4.0.5146.23014, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ScriptLab.dll SeamlessHelper, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessHelper.dll SeamlessMove, Version=1.0.4690.40795, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessMove.dll SeamlessTextureMaker, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SeamlessTextureMaker.dll SegmentImage, Version=1.1.3674.15788, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SegmentImage.dll Selection2Clear, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Selection2Clear.dll SelectionInnerContour, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionInnerContour.dll SelectionObscure, Version=1.1.4602.34476, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionObscure.dll SelectionTools, Version=4.1.5513.37153, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SelectionTools.dll Self-Negation, Version=1.0.4590.5558, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Self-Negation.dll ShadowEffect, Version=1.3.0.23429, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowEffect.dll ShadowHighlight, Version=3.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ShadowHighlight.dll Shape3D, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape3D.dll shapegradient, Version=1.5.3886.6574, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\shapegradient.dll Shapes, Version=1.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shapes.dll Shape_umabob, Version=3.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Shape_umabob.dll Sharpen+, Version=4.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sharpen+.dll silhouetteplus, Version=1.1.3131.17586, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\silhouetteplus.dll SinWaves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SinWaves.dll Slinky, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Slinky.dll SmartSharpen, Version=1.5.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SmartSharpen.dll Smooth, Version=2.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smooth.dll Smudge, Version=4.0.4642.26844, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Smudge.dll Sparkles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkles.dll Sparkle, Version=2.6.0.78, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkle_Glitter.dll Sparkle_Stars, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sparkle_Stars.dll Specular, Version=1.0.3254.27778, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Specular.dll SpeechBubble, Version=2.1.4445.42029, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpeechBubble.dll Spiral, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Spiral.dll SpiralText, Version=1.4.4415.32775, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiralText.dll SpiritLevel.Effect, Version=0.8.0.968, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiritLevel.Effect.dll SpiroGraph, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroGraph.dll SpiroShapes, Version=2.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SpiroShapes.dll Splashes, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splashes.dll Splatter, Version=4.0.4642.26829, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Splatter.dll Sponge_en, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Sponge_en.dll Squirkle, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Squirkle.dll SquirkleWarp, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SquirkleWarp.dll SR, Version=1.0.3371.38258, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SR.dll StarGlow, Version=1.0.3839.21249, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StarGlow.dll Starry, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Starry.dll Stars, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stars.dll Steganography, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Steganography.dll SteganographyDecodeBW, Version=2.0.5303.25592, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SteganographyDecodeBW.dll SteganographyDecodeColor, Version=2.0.5303.25093, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SteganographyDecodeColor.dll SteganographyEncode, Version=3.0.5306.34590, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SteganographyEncode.dll StewienFilters, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StewienFilters.dll Stipple, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stipple.dll Stitch, Version=4.0.4642.26808, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Stitch.dll StockLibrary, Version=1.5.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StockLibrary.dll StringAndPin, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\StringAndPin.dll SubtleEffect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SubtleEffect.dll SVGImport, Version=2.4.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\SVGImport.dll Table, Version=1.1.5635.43080, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Table.dll TextPlus, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Textplus.dll TextPro, Version=1.0.3614.36023, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TextPro.dll Texture, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texture.dll Texturize, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Texturize.dll ThatOtherApp, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThatOtherApp.dll ThreadsMarker, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ThreadsMarker.dll TileFillFromClipboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TileFillFromClipboard.dll TileImageFileType, Version=1.0.0.1, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TileImageFileType.dll Tiles, Version=1.1.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tiles.dll Tint-Splitter, Version=1.0.4636.5475, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tint-Splitter.dll TJacksonEffects, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TJacksonEffects.dll "TR's Pixel Push", Version=1.0.4954.37564, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TR's Pixel Push.dll "TR'sColorizerHMS", Version=1.0.4937.30626, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TR'sColorizerHMS.dll Trail, Version=4.0.4642.26791, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Trail.dll trail3d, Version=1.0.3902.32071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\trail3d.dll Transitional Brush, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transitional Brush.dll Transparency, Version=4.0.5284.39911, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Transparency.dll TreeGen, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TreeGen.dll TRs Scatter, Version=1.3.4949.23250, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRs Scatter.dll TRsAlphaCutter, Version=3.0.4.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsAlphaCutter.dll TRsBokeh, Version=2.0.5457.42261, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBokeh.dll TRsBrushStrokes, Version=1.0.6.11937, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBrushStrokes.dll TRsBWPhoto, Version=1.0.4949.38907, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsBWPhoto.dll TRsCloudControl, Version=2.0.4968.34489, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCloudControl.dll TRsContourFiller, Version=1.5.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsContourFiller.dll TRsCoquin, Version=1.0.4960.31131, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCoquin.dll TRsCroquis, Version=1.4.5634.10354, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCroquis.dll TRsCustomPaletteMatch, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCustomPaletteMatch.dll TRsCustomRandomFill, Version=1.5.1.31287, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsCustomRandomFill.dll TRsDoodleMatic, Version=1.4.5045.31846, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDoodleMatic.dll TRsDrumSkin, Version=1.0.5196.38052, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsDrumSkin.dll TRsExportSelection, Version=1.1.5363.24631, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsExportSelection.dll TRsFilaments, Version=1.0.15.11399, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilaments.dll TRsFilmStock, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFilmStock.dll TRsFireWorks, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFireWorks.dll TRsFreeWarp, Version=1.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFreeWarp.dll TRsFuego, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsFuego.dll TRsGlassVignette, Version=1.1.5239.30797, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsGlassVignette.dll TRsHalfTone, Version=1.0.4937.7773, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsHalfTone.dll TRsHDRish, Version=1.0.5198.15558, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsHDRish.dll TRsIntenseFilteration, Version=1.1.5389.33758, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIntenseFilteration.dll TRsIntensityWarp, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIntensityWarp.dll TRsiPollock, Version=1.0.3.11944, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIPollock.dll TRsIsopleth, Version=1.0.1.15855, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsIsopleth.dll TRsKaboom, Version=1.0.5118.21464, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsKaboom.dll TRsPanoPDN, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPanoPDN.dll TRsPasteFrame, Version=1.3.10.13270, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPasteFrame.dll TRsPasteWarp, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPasteWarp.dll TRsPixelPuller, Version=1.1.4994.29625, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPixelPuller.dll TRsPixelSharp, Version=2.0.5467.31590, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPixelSharp.dll TRsPlasmatix, Version=1.0.5220.31660, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPlasmatix.dll TRsPSnap, Version=1.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsPSnap.dll TRsRadialExtruder, Version=1.2.5609.8244, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsRadialExtruder.dll TRsSelfeez, Version=1.0.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSelfeez.dll TRsSimpleLight, Version=1.0.5388.10259, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSimpleLight.dll TRsSmudger, Version=2.2.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSmudger.dll TRsSnowFlakeMaker, Version=1.0.1.1701, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSnowFlakeMaker.dll TRsSphereCuber, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSphereCuber.dll TRsSplineMaster, Version=1.4.2.18310, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsSplineMaster.dll TRsStarFilter, Version=1.0.4930.9612, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStarFilter.dll TRsStr8Edge, Version=1.1.5045.31905, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStr8Edge.dll TRsStrangeAttractor, Version=1.1.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStrangeAttractor.dll TRsStrobeMotion, Version=1.2.4962.30523, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsStrobeMotion.dll TRsTeslaCoil, Version=1.0.4935.18219, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTeslaCoil.dll TRsThirdDimension, Version=1.7.9.12090, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsThirdDimension.dll TRsTiledPixels, Version=1.2.4942.13226, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTiledPixels.dll TRsTiltShift, Version=1.0.4957.12341, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTiltShift.dll TRsTreeMaker, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsTreeMaker.dll TRsZigZag, Version=1.1.4929.6773, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TRsZigZag.dll Truncate resolution, Version=1.0.5346.33759, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Truncate_resolution.dll TubeOblique, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TubeOblique.dll TurbulentCircles, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TurbulentCircles.dll TurbulentLines, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TurbulentLines.dll Tweakedges, Version=1.0.4252.39711, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tweakedges.dll Tweaktrans2, Version=2.0.4252.27152, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Tweaktrans2.dll Twist, Version=4.0.4642.26767, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Twist.dll TwistZ, Version=1.1.2.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwistZ.dll TwoColorMixer, Version=1.0.5616.24071, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwoColorMixer.dll TwoToneThreshold, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\TwoToneThreshold.dll UnAlpha-03, Version=3.0.5049.38134, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\UnAlpha-03.dll Unblend v1, Version=1.0.5176.26202, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Unblend.dll Vandermotten.PaintDotNetEffects.Blurs, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Blurs.dll Vandermotten.PaintDotNetEffects.ColorAccent, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ColorAccent.dll Vandermotten.PaintDotNetEffects, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.dll Vandermotten.PaintDotNetEffects.DropShadow, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.DropShadow.dll Vandermotten.PaintDotNetEffects.Duotones, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Duotones.dll Vandermotten.PaintDotNetEffects.FadeEdge, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.FadeEdge.dll Vandermotten.PaintDotNetEffects.Gradient, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Gradient.dll Vandermotten.PaintDotNetEffects.Grid, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Grid.dll Vandermotten.PaintDotNetEffects.Monochromes, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.Monochromes.dll Vandermotten.PaintDotNetEffects.ObjectAlign, Version=3.8.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vandermotten.PaintDotNetEffects.ObjectAlign.dll Vibration, Version=1.0.4407.34043, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibration.dll Vibrato, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vibrato.dll Vignette1, Version=1.0.3538.14367, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Vignette1.dll VignettePlus, Version=4.0.5284.40018, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\VignettePlus.dll Volutes, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Volutes.dll WaterReflection, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaterReflection.dll Waves, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Waves.dll WaveText, Version=1.2.4415.32811, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveText.dll WaveTextSUI, Version=1.2.4415.33440, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WaveTextSUI.dll WetFloor, Version=1.1.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WetFloor.dll WhichSymbolRedux, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WhichSymbolRedux.dll Whitepoint, Version=1.0.4412.42187, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\Whitepoint.dll WMF2WPF, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WMF2WPF.dll WPFGDI, Version=1.0.1.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\WPFGDI.dll X Rainbow bars, Version=1.0.3536.37632, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\X Rainbow bars.dll xmario_cut_color_en, Version=1.0.3769.28056, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\xmario_cut_color_en.dll XYCoords, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\XYCoords.dll ZoomBlurDeluxe, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\Effects\ZoomBlurDeluxe_v0.2.dll System.Configuration.Install, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Configuration.Install\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Configuration.Install.dll System.Design, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\System.Design\v4.0_4.0.0.0__b03f5f7f11d50a3a\System.Design.dll Microsoft.VisualBasic, Version=10.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Microsoft.VisualBasic\v4.0_10.0.0.0__b03f5f7f11d50a3a\Microsoft.VisualBasic.dll OptionBasedLibrary v0.7.8, Version=0.7.0.1491, Culture=neutral, PublicKeyToken=null @ C:\Program Files\Paint.NET\OptionBasedLibrary v0.7.8.dll Accessibility, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a @ C:\Windows\Microsoft.Net\assembly\GAC_MSIL\Accessibility\v4.0_4.0.0.0__b03f5f7f11d50a3a\Accessibility.dll Native modules: C:\Program Files\Paint.NET\PaintDotNet.exe, version=4.5.5454.39504 C:\Windows\SYSTEM32\ntdll.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\SYSTEM32\MSCOREE.DLL, version=4.0.40305.0 (Main.040305-0000) C:\Windows\system32\KERNEL32.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432) C:\Windows\system32\KERNELBASE.dll, version=6.1.7601.18015 (win7sp1_gdr.121129-1432) C:\Windows\system32\ADVAPI32.dll, version=6.1.7601.18869 (win7sp1_gdr.150525-0603) C:\Windows\system32\msvcrt.dll, version=7.0.7601.17744 (win7sp1_gdr.111215-1535) C:\Windows\SYSTEM32\sechost.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\RPCRT4.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\SHLWAPI.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\GDI32.dll, version=6.1.7601.18778 (win7sp1_gdr.150304-1507) C:\Windows\system32\USER32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\LPK.dll, version=6.1.7601.18768 (win7sp1_gdr.150219-1512) C:\Windows\system32\USP10.dll, version=1.0626.7601.18454 (win7sp1_gdr.140424-1533) C:\Windows\system32\IMM32.DLL, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\MSCTF.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\MSVCR120_CLR0400.dll, version=12.00.51689.34249 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\d1265d6159ea876f9d63ea4c1361b587\mscorlib.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\ole32.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\CRYPTBASE.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\uxtheme.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNet.Base\69c0ed4738dc2006b334af2afe0c3155\PaintDotNet.Base.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_32\System\d18e2115a3270f89663fce831547f534\System.ni.dll, version=4.0.30319.34238 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Drawing\dd2f9ea99ac0f984b9dc430824638c9f\System.Drawing.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\WindowsBase\efd34838fa44da246b78328f4432eac7\WindowsBase.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\CRYPTSP.dll, version=6.1.7601.18741 (win7sp1_gdr.150202-1526) C:\Windows\system32\rsaenh.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\a0b4e6b92d9c147d801a6f2e3a15080b\System.Windows.Forms.ni.dll, version=4.0.30319.34251 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Core\c61bafa9d029e3f2bf83bd5af3f1f5ac\System.Core.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNet500b2e4f#\7aa3213d2ad71d517a5dece1d9e1307f\PaintDotNet.SystemLayer.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_32\PresentationCore\f6fee9c78602505e874ec0807e3b1a51\PresentationCore.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\Presentatio5ae0f00f#\dba6e73775e7b823a02925f063bd2983\PresentationFramework.ni.dll, version=4.0.30319.34209 C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNet.Core\ce31a1beb10254da3b6b126305615f41\PaintDotNet.Core.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNet26779e70#\0d049e0ceef13ad7924ae38e45123e99\PaintDotNet.Resources.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNet7afaaa15#\4da711897e1ade09104929b1eb6a8a5b\PaintDotNet.Framework.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNet.Data\db3a84cd0b8cf483c5b3ca58fd85c684\PaintDotNet.Data.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNet.Effects\ccc6c2334530df2ecb17673324f2f57e\PaintDotNet.Effects.ni.dll, version=4.5.5454.39504 C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNet\4b9e5f8e3881af0e55da89d2617cb70a\PaintDotNet.ni.exe, version=4.5.5454.39504 C:\Windows\system32\dwrite.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\wpfgfx_v0400.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\OLEAUT32.dll, version=6.1.7601.18679 C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationNative_v0400.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\shell32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\Microsoft.NET\Framework\v4.0.30319\nlssorting.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\version.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\PaintDotNetc8826738#\736e2615fc1f0b0bd2186daf17460d17\PaintDotNet.SystemLayer.Native.x86.ni.dll, version=4.5.5454.39504 C:\Program Files\Paint.NET\PaintDotNet.SystemLayer.Native.x86.dll, version=4.5.5454.39504 C:\Windows\system32\MSVCR120.dll, version=12.00.21005.1 built by: REL C:\Windows\system32\VCOMP120.DLL, version=12.00.21005.1 built by: REL C:\Windows\system32\MSVCP120.dll, version=12.00.21005.1 built by: REL C:\Windows\system32\PROPSYS.dll, version=7.00.7600.16385 (win7_rtm.090713-1255) C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.18834_none_72d38c5186679d48\gdiplus.dll, version=6.1.7601.18834 (win7sp1_gdr.150419-1507) C:\Windows\system32\dxgi.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\dwmapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\WINTRUST.dll, version=6.1.7601.18741 (win7sp1_gdr.150202-1526) C:\Windows\system32\CRYPT32.dll, version=6.1.7601.18741 (win7sp1_gdr.150202-1526) C:\Windows\system32\MSASN1.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\profapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\CLBCatQ.DLL, version=2001.12.8530.16385 (win7_rtm.090713-1255) C:\Windows\System32\UIAnimation.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.18837_none_41e855142bd5705d\comctl32.dll, version=6.10 (win7_rtm.090713-1255) C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18837_none_ec86b8d6858ec0bc\comctl32.dll, version=6.10 (win7_rtm.090713-1255) C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Configuration\908075c4922acdf834c67ac802814c9d\System.Configuration.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xml\3d6ee4ffbd9a86ac1e7b01800b6fe9c7\System.Xml.ni.dll, version=4.0.30319.34234 built by: FX452RTMGDR C:\Windows\system32\WindowsCodecs.dll, version=6.2.9200.17251 (win8_gdr.150128-1514) C:\Windows\system32\wtsapi32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\WINSTA.dll, version=6.1.7601.18540 (win7sp1_gdr.140716-1508) C:\Windows\system32\d2d1.dll, version=6.2.9200.16492 (win8_gdr_oobssr.130113-0015) C:\Windows\system32\d3d11.dll, version=6.2.9200.16570 (win8_gdr.130327-1526) C:\Windows\system32\D3D10Warp.dll, version=6.2.9200.17033 (win8_gdr.140615-1509) C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Xaml\1196cc375887ce75f134047505fe19bf\System.Xaml.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\RpcRtRemote.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\aticfx32.dll, version=8.17.10.1107 C:\Windows\system32\atiuxpag.dll, version=8.14.01.6243 C:\Windows\system32\atidxx32.dll, version=8.17.10.0405 C:\Windows\system32\winmm.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\explorerframe.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\DUser.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\DUI70.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Program Files\Paint.NET\Effects\GpcDotNet.IA32.dll, version= C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\MSVCR90.dll, version=9.00.30729.6161 C:\Windows\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6161_none_50934f2ebcb7eb57\msvcm90.dll, version=9.00.30729.6161 C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Confe64a9051#\55285f4d071d4b06488a4d61a4899170\System.Configuration.Install.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll, version=12.0.51209.34209 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\System.Design\16f2fde71220bb50e22cadaaf75d6648\System.Design.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\Microsoft.V9921e851#\57a0233323e1e6a18f5fcc2c51422ec3\Microsoft.VisualBasic.ni.dll, version=12.0.51209.34209 built by: FX452RTMGDR C:\Windows\assembly\NativeImages_v4.0.30319_32\Accessibility\d9ef873b190c9df202c3f9f8a5d38c48\Accessibility.ni.dll, version=4.0.30319.34209 built by: FX452RTMGDR C:\Windows\system32\SetupApi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\CFGMGR32.dll, version=6.1.7601.17514 (win7sp1_rtm.101119-1850) C:\Windows\system32\DEVOBJ.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) C:\Windows\system32\psapi.dll, version=6.1.7600.16385 (win7_rtm.090713-1255) ------------------------------------------------------------------------------ Edited June 15, 2015 by Ego Eram Reputo Added Hide tags Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted June 15, 2015 Author Share Posted June 15, 2015 TR's EdgefaderExtreme was renamed TR's EFX - I may have uploaded the wrong version, Sorry I just posted version 5.3 - please check for crash 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
Eli Posted June 16, 2015 Share Posted June 16, 2015 TR, 5.3 is working smoothly for me. Thanks Quote Link to comment Share on other sites More sharing options...
iamnoob Posted June 16, 2015 Share Posted June 16, 2015 (edited) What the conditions were before it crashed would be nice. This way I could reproduce. Size of image , PDN version your using- what steps were made prior to crash? If a crash log was produce a copy would be great it usually points right to the problem I know you just uploaded a new version, but I'll still post the crash logs if you want. I just need to know where they're located; can't find them. Gonna try the new version and will report back if any issues. Edit: Same issue as before. Will PM you. Edited June 16, 2015 by iamnoob 1 Quote Link to comment Share on other sites More sharing options...
TechnoRobbo Posted June 16, 2015 Author Share Posted June 16, 2015 Iamnoob - thank you for your PM, the image was a great help. As I had suspected, the bug had to do with the dimensions of the image itself. Since neither height nor width was larger than 255 pixels it caused an overflow while the plugin tried to achieve a 255 Alpha (full opacity). V.5.3.5 ready for download "small image" bug fixed!!!! hopefully I uploaded the right version 1 Quote Go out there and be amazing. Have Fun, TRSome Pretty Pictures Some Cool Plugins Link to comment Share on other sites More sharing options...
iamnoob Posted June 16, 2015 Share Posted June 16, 2015 ^ Yay, seems to work fine now. =D Quote Link to comment Share on other sites More sharing options...
Maximilian Posted June 16, 2015 Share Posted June 16, 2015 So far so good for me too! Quote Link to comment Share on other sites More sharing options...
bitKoder Posted December 16, 2015 Share Posted December 16, 2015 Is there any way to make the feathering even weaker than 1? Because even level 1 is too strong for me at times. Quote Link to comment Share on other sites More sharing options...
