Pouletic Posted October 5, 2010 Share Posted October 5, 2010 Greetings I have been retouching scans of 50+-year-old photographs recently for family members. One of the most labor intensive parts of this is fixing scratches. I generally use a clone tool to manually fill in the scratch with nearby data, but this process seems amenable to automation. Nevertheless, i haven't been able to find any plugins to assist. How are people accomplishing this kind of task? Any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Jordan4762 Posted October 5, 2010 Share Posted October 5, 2010 I Might Be Able To, Can You Upload A File? Quote Jordan4762 - ROBLOX Link to comment Share on other sites More sharing options...
Drgrit Posted October 5, 2010 Share Posted October 5, 2010 Hm. Well, if the scratchs are small, you may be able to partly remove them... Quote Link to comment Share on other sites More sharing options...
Pouletic Posted October 5, 2010 Author Share Posted October 5, 2010 Here's an example. As i said, i've had really good results using the clone tool by hand, but it seems that better results and/or some automation could be obtained with a special tool. Quote Link to comment Share on other sites More sharing options...
Jordan4762 Posted October 5, 2010 Share Posted October 5, 2010 Ouch Thats Big... Sorry, Cant Fix That Quote Jordan4762 - ROBLOX Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 5, 2010 Share Posted October 5, 2010 Fixing A Damaged Photo advocates the patient use of the Clone Stamp tool, but there are other very useful tips as well. Edit: found this excellent post: http://forums.getpaint.net/index.php?/topic/18129-fixing-a-damaged-color-photo/page__view__findpost__p__310475 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
BoltBait Posted October 5, 2010 Share Posted October 5, 2010 Far from perfect, but if you want some sort of "automatic" fix: Use a selection tool to select the scratch. Doesn't have to be perfect--you could even use a square selection fairly tight around the scratch. Run the Effects > Noise > Median Blur. Leave the second slider alone, adjust the top slider to taste. Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
Sarkut Posted October 5, 2010 Share Posted October 5, 2010 This is not automated, but you might want to give the method in this tutorial a try. There is a simplified set of steps in the first Hidden Content section at the end of the tutorial. http://img715.imageshack.us/img715/1240/photofx01.png Quote Link to comment Share on other sites More sharing options...
Pouletic Posted October 6, 2010 Author Share Posted October 6, 2010 Thanks. I actually came up with similar techniques to these (blur between edges, shift and feather image behind and erase top scratch) but my implementation didn't work as well as the ones you described, and i ended up getting best results until now with clone stamp. I guess it'll have to be more or less as it has been for the previous photos but i can definitely see some cases where the blur will be very useful. The time is mostly in selecting all the scratched area--it is irregular and i can't get it with the magic wand. Are there some tricks for selecting narrow, jagged areas more easily? Typically i also need to include a few pixels on either side because it is the bunched up print. I don't know how to select something like that. I did a lot of searching on this and actually didn't find much in the way of tools for any app. It surprises me with how common the task must be but it seems it's a pretty tough thing to automate. I'll let you know if i come up with any refinements on the technique. Quote Link to comment Share on other sites More sharing options...
