Pattern for string art
Go to solution Solved by Red ochre,
There is a feature in G'MIC > Artistic > Stringify that does something similar, but you would have to play with it, I reckon
Brian
  • Thanks 1
Good result @Welsh Yellow Cheddar
Cobweb: This draws lines (or stars) based on the direction of how the tone of the image changes (tone gradient)... Draws tangents to any obvious lines on the source image.
Gossamer: This works in two stages - first it finds points (shown as red dots on a black background. Aim to get a recognisable image at this stage but not too many dots).
Second stage (remember to check the box) will join these found dots with straight lines.
The only way to really understand these effects is to play with them!. Start with something simple eg. a black circle on a white background.
Good luck!
