Portalcow Posted April 4, 2021 Share Posted April 4, 2021 (edited) i tried to open a 90 MB PSD file with the PSD Plugin and everytime i click, Paint.Net gets an error message for not having enough memory. as far as i know, the problem does not come from the Plugin since it's working fine with other files. Error Message: https://pastebin.com/dCXTKvx1 is the file too big? Edited April 4, 2021 by Portalcow Quote Link to comment Share on other sites More sharing options...
null54 Posted April 4, 2021 Share Posted April 4, 2021 2 hours ago, Portalcow said: is the file too big? Yes, the PSD plugin is reporting that the file cannot be loaded into memory. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
Portalcow Posted April 4, 2021 Author Share Posted April 4, 2021 3 hours ago, null54 said: Yes, the PSD plugin is reporting that the file cannot be loaded into memory. Does it mean storage Memory or RAM? Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted April 4, 2021 Share Posted April 4, 2021 RAM Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
