lordofeverything Posted February 29, 2016 Share Posted February 29, 2016 Hi I'm having problems installing the latest version 4.0.9 I'm using a new Acer laptop with Windows 10, 8gb ram (I don't know much more) The installation seems to hang on the installation of .NET 4.6.1 - it stays there for hours with just a small part of the bar turned green, and it won't go any further Registry Editor shows I have .NET 4.5.51641 installed Control Panel > Programs > Turn Windows features on or off shows: .NET Framework 3.5 (includes .NET 2.0 and 3.0) .NET Framework 4.5 Advanced Services Installation of .NET 4.6.1 hangs from the Paint.net installer I tried installing .NET 4.6.1 directly from the web - computer isn't having any of it. I downloaded .NET 4.6.1 to install offline - computer still isn't having any of it. I have disabled anti-virus software / firewalls etc (McAfee / Windows Defender) but sitll no luck It seems if I can't install .NET 4.6.1 then I can't run Paint.net Is there a trick to getting the installer to run? Or an older version of Paint.net I can download and use? Is it not possible to have Paint.net working independently of specific versions of .NET? Quote Link to comment Share on other sites More sharing options...
skullbonz Posted February 29, 2016 Share Posted February 29, 2016 I fear that the day I get forced into having windows 10 will be my last day of paint.net but filehippo still has the older version here; edit by Rick: don't link to older versions. you should know this by now Quote http://forums.getpaint.net/index.php?/topic/21233-skullbonz-art-gallery Link to comment Share on other sites More sharing options...
toe_head2001 Posted February 29, 2016 Share Posted February 29, 2016 Have you tried installing the .Net Framework while in Windows' Safe Mode? Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
IRON67 Posted February 29, 2016 Share Posted February 29, 2016 Any error messages after you tried to install NET-Framework 4.6? Quote Link to comment Share on other sites More sharing options...
dipstick Posted March 1, 2016 Share Posted March 1, 2016 What I find interesting, is I never needed to install DotNet v4.6.1 on my Win10 system for PDN v4.0.9. It's running the default DotNet v4.0.30319.42000. This goes for my Desktop as well as Laptop. I simply ran the installer without any issue or need for installation of DotNet v4.6.1. I wonder why that is? Here is my system info according to PDN: Hidden Content: specs Application paint.net 4.0.9 (Final 4.9.5848.30436)Build Date Tuesday, January 5, 2016Hardware accelerated rendering (GPU) TrueAnimations TrueDPI 96.00 (1.00x scale)Language en-USOS Windows 10 (10.0.10240.0).NET Runtime 4.0.30319.42000Physical Memory 12,097 MBCPU Intel® Core i7-4790 CPU @ 3.60GHzArchitecture x64 (64-bit)Process Mode 64-bitSpeed ~3592 MHzCores / Threads 8Features DEP, SSE, SSE2, SSE3, SSSE3, SSE4_1, SSE4_2, XSAVEVideo Card Intel® HD Graphics 4600Dedicated Video RAM 112 MBDedicated System RAM 0 MBShared System RAM 6,048 MBVendor ID 0x8086Device ID 0x0412Subsystem ID 0x07501025Revision 6LUID 0x00004DC3Flags NoneOutputs 1Video Card Microsoft Basic Render DriverDedicated Video RAM 0 MBDedicated System RAM 0 MBShared System RAM 6,048 MBVendor ID 0x1414Device ID 0x008CSubsystem ID 0x00000000Revision 0LUID 0x00005030Flags SoftwareOutputs 0 Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted March 1, 2016 Share Posted March 1, 2016 4.6 is required, but Paint.NET includes the 4.6.1 installer. No need to bundle 4.6 and just have everyone also pull down 4.6.1 via automatic Windows Updates. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
lordofeverything Posted March 1, 2016 Author Share Posted March 1, 2016 Thanks for advice guys .NET 4.6.1 would not install in safe mode - I've had a lot of problems with Windows 10 and this is a clean install of Windows 10, apart from a lot of rubbish installed as part of the Acer bundle But skullbonz has saved the day with filehippo - a quick search and 10 minutes later, Paint.net 4.0.5 is running happily I'm no expert with paint packages, but Paint.net is very easy to use. Since setting up 4.0.5 this morning, I've grabbed some clipart and have printed some clockfaces and pictures to help the kids learn to tell the time. Very quick, very easy, just what I need! Quote Link to comment Share on other sites More sharing options...
IRON67 Posted March 1, 2016 Share Posted March 1, 2016 .NET 4.6.1 would not install in safe mode - I've had a lot of problems with Windows 10 ... Paint.net 4.0.5 is running happily But this is only a temporary solution or you have to stay on 4.0.5 and cancelling all following updates. This is not a good idea in any case. You should fix your NET-problem - because maybe other applications will stop working properly in the future. I have solved a similar problem on Win 7 with NET-installation by editing the registry. If you interested, ask me, how. Quote Link to comment Share on other sites More sharing options...
lordofeverything Posted March 1, 2016 Author Share Posted March 1, 2016 You'd think that in 2016, companies could build computers with operating systems that don't need constant updates and that software would be effortless to install ..... Life is too short to constantly mess around trying to install things and learn the ins and outs of the Windows registry ..... when this laptop is a couple of years old and too slow, the kids will get it and I'll just get a new one and install software again .... I can live with 4.0.5 for a couple of years, it does everything I need .... Quote Link to comment Share on other sites More sharing options...
IRON67 Posted March 1, 2016 Share Posted March 1, 2016 (edited) You'd think that in 2016, companies could build computers with operating systems that don't need constant updates and that software would be effortless to install No. You have completely misunderstood me. That's why I said "This is not a good idea in any case". I'm " a little bit" familiar with such problems and solutions since I use computers for about 20 years or so and I am willing to "learn the ins and outs". Therefore I can help you but if you don't want - be happy. Edited March 1, 2016 by IRON67 Quote Link to comment Share on other sites More sharing options...
