xrl Posted January 16, 2008 Share Posted January 16, 2008 (edited) MODERATORS NOTE: this plugin has been superseded by a newer version: https://forums.getpaint.net/topic/32402-sublcd-v12-jan-9-2016/ I was bored and I decided to try doing a filter for fun, so I coded a little resize plugin based on the SubLCD algorithm by Kim Øyhus. This is also the first time I try coding a plug in... Not that I spent much time with it. It's useful if you want to display your images in a LCD/Plasma screen as it gives the apearence of a little more resolution. It's what's used to render fonts nowadays. For more information check: http://oyhus.no/SubLCD.html Now following with some samples (normal resize on the left, SubLCD on the right): Some lines generated with some Paint.net line generator plugin... Text! A logo... notice the sleeves, look much sharper with SubLCD. A colour picture where it's "easy" to spot difference: look at the details in the helmet, and the holes. All pictures should at least look sharper on a LCD screen. Download it here: http://web.ist.utl.pt/tcf/rand/sublcd/sublcd.zip BTW: You should crop half of the image after using the plugin. I didn't bore to see how it's done. :oops: The source, I used CodeLab, is in the zip. Enjoy. sublcd.zip Edited July 4, 2018 by toe_head2001 Link to comment Share on other sites More sharing options...
barkbark00 Posted January 16, 2008 Share Posted January 16, 2008 Does it only resize horizontally? If so, would you be able to have the code increase the image width by 200% and then apply the effect? Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
xrl Posted January 16, 2008 Author Share Posted January 16, 2008 Does it only resize horizontally? If so, would you be able to have the code increase the image width by 200% and then apply the effect? The algorithm only resizes by half in the horizontal direction. Try reading in the page and understanding what it does and why. You should resize the image normally to the desired width*2 and height, then apply the filter, and then crop it to width x height. Link to comment Share on other sites More sharing options...
barkbark00 Posted January 16, 2008 Share Posted January 16, 2008 xrl, I see how it works. The effect's output is very nice. However, due to the excessive set up, this isn't something that I'll use often. Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Geoff Posted January 16, 2008 Share Posted January 16, 2008 Very interesting plug-in, this certainly has potential. However i am not 100% clear on what i should be doing. If you could provide some simple pointers on how to use SubLCD and what you would use it for, this would clear up my understanding a lot. Apart from that very good effort for a fist go at coding , and i'm sure it will come in handy when resizing pics once people have a better understanding. Geoff Link to comment Share on other sites More sharing options...
barkbark00 Posted January 16, 2008 Share Posted January 16, 2008 Very interesting plug-in, this certainly has potential. However i am not 100% clear on what i should be doing. If you could provide some simple pointers on how to use SubLCD and what you would use it for, this would clear up my understanding a lot. Apart from that very good effort for a fist go at coding , and i'm sure it will come in handy when resizing pics once people have a better understanding.Geoff It resizes your your image horizontally at 50% while retaining the sharpness. For this to work you need to start by resizing your image so that the height (vertical dimension) is half that of the original image. Then run the plugin. Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
xrl Posted January 16, 2008 Author Share Posted January 16, 2008 xrl, I see how it works. The effect's output is very nice. However, due to the excessive set up, this isn't something that I'll use often. It's not that excessive... all you need to do is crop it... and resize it vertically before However i am not 100% clear on what i should be doing. If you could provide some simple pointers on how to use SubLCD and what you would use it for, this would clear up my understanding a lot. I have to say that I don't really know what can you use it for... It can give you some extra detail in very small screens, like phones and portable consoles (wallpapers, images with a fixed size). The the difference between this and a normal resize isn't that big, so you should save the files in a lossless format (.png). I may update the plugin to crop after resizing, or maybe someone could do it for me (the code is in the zip) Link to comment Share on other sites More sharing options...
pyrochild Posted January 16, 2008 Share Posted January 16, 2008 Looks to me like this works in a similar manner to ClearType, in which case, while this is great for LCD monitors, when the images are viewed on non-LCDs, the picture quality will be dramatically worse than before. That's not really a big deal, though, considering how LCDs are quickly taking over the market. ambigram signature by Kemaru [i write plugins and stuff] If you like a post, upvote it! Link to comment Share on other sites More sharing options...
barkbark00 Posted January 16, 2008 Share Posted January 16, 2008 I have to say that I don't really know what can you use it for... It can give you some extra detail in very small screens, like phones and portable consoles...Or any time your images size is limited (e.g., avatars, favicons or program icons, etc.). Take responsibility for your own intelligence. -Rick Brewster Link to comment Share on other sites More sharing options...
Fisherman's Friend Posted January 17, 2008 Share Posted January 17, 2008 Well, I really like the idea, but the result is a bit... strange... Before: After: Or do I use it in a wrong way? Link to comment Share on other sites More sharing options...
Joey Posted January 17, 2008 Share Posted January 17, 2008 Ok, short explanation how this stuff works: the plugin attempts to perform ClearType on arbitrary images effectively. This basically means that the physical ordering of the red, blue and green subpixels on an LCD screen is utilized by antialiasing with colored pixels. Since the subpixels are usually ordered horizontally in R-G-B order (on most screens; some use B-G-R and then this plugin will yield pretty blurry images) you can take advantage of that and effectively triple the horizontal resolution (not exactly, there are some things that prevent you from doing so). What this algorithm does, according to its website is combining the red and blue pixels into one. This is, however, not how subpixel antialiasing works usually. You can see that the results are inferior to ClearType or similar methods by the color fringes it produces, especially in the first and third example pictures. (Also what the author states, that the perceived brightness of red and blue together is about the same as green alone is a bit away from the truth. Perception levels are (in RGB order): 30, 59, 11) What ClearType does, is not simply distributing the pixels directly on the available colored subpixels but rather distributing the available energy on adjacent pixels as well. This does indeed make the image more blurry but has the distinct advantage that we perceive it as crisp as before and we don't have the color fringes the other method produces. Also, usually you start out with an image of tripled width, since there are three subpixels Link to comment Share on other sites More sharing options...
