Rosey Posted June 23, 2015 Share Posted June 23, 2015 I am having a problem where even though I click on something once, it acts as if I double clicked it ( double new layers, new lines are made, accidentally deleting 2 layers instead of 1, etc ). This is not happening in any of my browsers and I already tried repairing and uninstalling paint.net but the problem still persists. Please help! Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 23, 2015 Share Posted June 23, 2015 Sounds like a mouse setting. Open the Mouse dialog box. In Windows 7+, click Start , type Mouse in the Search box, then click Mouse (orMicrosoft Mouse) in the Programs list. If you are prompted for an administrator password or for a confirmation, type the password, or clickAllow. Verify the button assignments in IntelliPoint software. On the Buttons tab, under Button Assignment, make sure that theLeft button setting is Click (default), and not Double-click. If this problem occurs only in specific programs, click the Settings button, choose the impacted program, and then confirm that the Left button is set to Click (default) for that program. Click OK. More info > https://support.microsoft.com/en-us/kb/266738 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Rosey Posted June 24, 2015 Author Share Posted June 24, 2015 I did everything that you listed but the problem still persists. Quote Link to comment Share on other sites More sharing options...
Eli Posted June 24, 2015 Share Posted June 24, 2015 It could be that your mouse is in a hurry. Try using an older mouse. They tend to move slower with age . Just kidding. But I did have an issue with a mouse that kept doubleclicking even after changing the mouse settings. I changed the mouse and my problems went away. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 24, 2015 Share Posted June 24, 2015 Yeah what Eli said ... have you tried using a different mouse? Yours might just be broken. Double-clicking a link in your browser doesn't really affect what happens. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
