ImComingForYou Posted June 14, 2015 Share Posted June 14, 2015 I made a picture and then saved it as a pdn...Later on I accidently changed the filename extension to png.... Now when I try to open it it sais this file could not be found even though its on my desktop..... Quote Link to comment Share on other sites More sharing options...
Ishi Posted June 14, 2015 Share Posted June 14, 2015 (edited) Changing the file extension could corrupt the file. Why not try renaming the extension of the file from .png to .pdn again? Try opening it from the desktop. After you rename the extension back to .pdn you could try opening Paint.Net and on the File menu try opening the file from the "Opened Recent" list and see if it opens successfully with Paint.NET. Edited June 14, 2015 by Ishi Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 14, 2015 Share Posted June 14, 2015 If that doesn't work - have a look at the plugin that BoltBait linked to in this thread http://forums.getpaint.net/index.php?/topic/31893-i-need-help-i-cant-open-this-file/ Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Rick Brewster Posted June 15, 2015 Share Posted June 15, 2015 Well, changing the extension doesn't actually corrupt the file itself, it just means that whatever tries to open it will believe it's nonsense and then possibly claim that it's corrupt. But that's sort of a philosophical semantics discussion. Renaming it back should do the trick. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
