Ropey Posted January 1, 2013 Share Posted January 1, 2013 Hi I have a map using multiple layers with different textures/colours/etc on each one. I now want to create a new map but use the same layer settings. Is it possible to export or copy the first map's layer settings to use on the second? Quote Link to comment Share on other sites More sharing options...
Orgonster Posted January 1, 2013 Share Posted January 1, 2013 (edited) Hi, I am new in Paint net, how can I go to see next image from the folder list in situatiom when I opened some picture, and looking at it? There is no arow for "next image"? As i see, I must open all pictures from sam folder, and then I can use ctrl-tab to go to see any one picture from the folder list. Thanks in advance. Edited January 2, 2013 by Orgonster Quote Link to comment Share on other sites More sharing options...
pdnnoob Posted January 2, 2013 Share Posted January 2, 2013 @Orgonster make a new thread for a separate topic @Ropey There isn't a direct way to do it, but if you save the file as a .pdn, then make a copy of it (copy and paste outside of paint.net), that gets you essentially the same effect, though you have to delete the contents of each layer (shortcut: ctrl+a and delete) Quote No, Paint.NET is not spyware...but, installing it is an IQ test. ~BoltBait Blend modes are like the filling in your sandwich. It's the filling that can change your experience of the sandwich. ~Ego Eram Reputo Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted January 2, 2013 Share Posted January 2, 2013 Yup. File > Save As... specify a new filename and/or location (retain the *.pdn filetype) and you'll have the copy you want. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
