pielago Posted February 11, 2012 Share Posted February 11, 2012 Hi can someone tell me if there is a plug in that can help me make sprite sheet? like a smart guide that can help me put in place the stuff i make.. so i can have an easy way to make sprite sheet... if anybody knows a plug-in pLzzzz tell me... where to download it. and also how to use it or install it Thank you .. Quote Link to comment Share on other sites More sharing options...
yellowman Posted February 11, 2012 Share Posted February 11, 2012 (edited) Oops, this thread is for plugins publishing only, sorry mods. Try this thread: And for installation: Edit: or you need to know how to create the sheet? never mind, maybe someone has an idea. Edited February 11, 2012 by yellowman Quote My GalleryMy YouTube Channel "PDN Tutorials" Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted February 12, 2012 Share Posted February 12, 2012 yellowman had the right idea. There are actually two plugins which help with sprite sheets: 1. SpriteSheet Animation v1.3 2. Animation Helper v0.81 As for installing plugins, you should find all the help you need here: Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
