too many of the same effects
When you download a plugin or plugin package, you need to remove the old *.dll files or overwrite them with the newer version.
Plugins effects are stored in the Paint.Net/Effects/ folder, filetypes in the Paint.Net/Filetypes/ folder.
Manually go through these folders and delete the oldest of any duplicate files. Then restart PDN. That should do the trick.
