Iwonder_who Posted January 26, 2009 Share Posted January 26, 2009 I have searched in vain for help in achieving this look and have tried and tried with no luck so here goes! Could anyone point me to a tutorial or give instructions to get this effect please. As many others do I found this as a tutorial for another program and have tried to recreate it with paint.net as I love the program. As is common though obviously not all commands are the same and as a novice I get stuck lol. Any help would be greatly appreciated. Not worried about the masking etc more the technique in the photo Quote Link to comment Share on other sites More sharing options...
AmadeusX Posted January 26, 2009 Share Posted January 26, 2009 If i understand you correctly you want the same effect as in the picture? Let me know if im right and i'll might get you a tutorial, Or someone else post one Quote Link to comment Share on other sites More sharing options...
david.atwell Posted January 26, 2009 Share Posted January 26, 2009 No need for a tutorial. Just go into Adjustments > Hue/Saturation and turn the Saturation down. :-) Maybe add in a little bit of the Pleasantville effect, and you're golden! Quote The Doctor: There was a goblin, or a trickster, or a warrior... A nameless, terrible thing, soaked in the blood of a billion galaxies. The most feared being in all the cosmos. And nothing could stop it, or hold it, or reason with it. One day it would just drop out of the sky and tear down your world.Amy: But how did it end up in there?The Doctor: You know fairy tales. A good wizard tricked it.River Song: I hate good wizards in fairy tales; they always turn out to be him. Link to comment Share on other sites More sharing options...
Myrddin Posted January 26, 2009 Share Posted January 26, 2009 No need for a tutorial. Just go into Adjustments > Hue/Saturation and turn the Saturation down.Additionally, perhaps upping the contrast slightly will better simulate the exampled effect after desaturation (Adjustments > Brightness / Contrast, around 10-15 dependant on the image). Quote How to Save Your Images under Different File Types My dA Gallery Link to comment Share on other sites More sharing options...
Iwonder_who Posted January 26, 2009 Author Share Posted January 26, 2009 Hey guys! Thanks so much for your advice, have been trying the tips and all certainly help but not sure they achieve that soft dreamy quality the picture I posted has. I am soooo close! Most times you can translate steps from one graphics program to another but the instructions in the original tutorial used a blending process called "soft light" which from what I can see isnt available in pdn blenmding modes and this is where perhaps the final touches to this will make it closer to this dreamy look. I tried gaussian blur with limited success. Am wondering too if perhaps you also need a dreamy picture lol, perhaps mine isnt. Would love your feedbackHere is another example of it "before and after: Quote Link to comment Share on other sites More sharing options...
Blooper Posted January 27, 2009 Share Posted January 27, 2009 You can probably get similar results with Soften Portrait, under Effects > Photo [Edit] Yup. First, run Soften Portrait with on 0-20-0, then with 10-20-3. Quote http://synthastic.deviantart.com http://soundcloud.com/siderealenterprise Lockerz invites are available, PM me Link to comment Share on other sites More sharing options...
Iwonder_who Posted January 27, 2009 Author Share Posted January 27, 2009 OK using the above response gives a good result but not as soft as the result I am looking for. Using the same picture in the example I have reproduced a finished product and put it next to the finished product look using the "other" graphics program lol.... can you see the difference.... so much softer and with yet more colour in places PDN ........................................... Other Quote Link to comment Share on other sites More sharing options...
barkbark00 Posted January 27, 2009 Share Posted January 27, 2009 Iwonder, what tutorial/steps are you using in the other apps? Having another set of eyes looking that process over may help expedite the conversion to PdN... Quote Take responsibility for your own intelligence. 😉 -Rick Brewster Link to comment Share on other sites More sharing options...
Iwonder_who Posted January 27, 2009 Author Share Posted January 27, 2009 Bark this was where I saw the idea and tried to recreate in pdn as I said after lots of playing and samples I am close but yet to achieve the right look... http://www.jessicasprague.com/index.php?view=article&catid=19%3Aphoto-editing-tutorials&id=388%3Acreate-a-dreamyhandtinted-look-on-a-photo&option=com_content&Itemid=92 Thanks again for your help guys... many hands make light work! Quote Link to comment Share on other sites More sharing options...
