TopHATslash Posted December 18, 2008 Share Posted December 18, 2008 Hello everybody. It has been a while since my latest tutorial. First off, I would like to address everyone to verndewd's chrome 101 tutorial and verndewd's siggy tutorial. In this he shows you how to make shiny chrome tube caps and then shows how to make a basic tube. In this tutorial, I will be going more in depth with the actual tube and background, rather then the chrome itself. So once you have read and followed those tutorials to get a feel for designing chrome and designing your sig, then let us begin. First off, lets place our caps. Be sure to give a good 40 pixels or so around the sig itself and the edge of the workspace. This ensures us to have a good view of our background, which is coming up soon. Also, remember that curves and gradients are your friend. Gradients with a few well placed notches on your curve's luminosity and blending modes will create the most awesome effect. Here are my caps: (Yes, I know they look dreadfully awful, but I am working on my mom's lap top. Its hard to steady anything without a mouse.) Now choose a good color for the tube. This can be any color, but keep it not too dark and not too bright. Then grab your rounded rectangle tool and, on a layer below the caps, draw your rectangle. Make sure draw with filled shape is selected. Now lets refer back to verndewd's siggy tutorial. Go back to the part where he adds shading to the tube and a (round effect) by using linear reflected gradients with secondary color set to 0 transparency - alpha. Just play with these settings until you are happy. Don't worry too much about the actual tube color/pattern yet. We'll go over that in a sec. Look at the color wheel now and decide on a color either more clockwise around the wheel or counterclockwise. I chose a blue-ish/green so for this color I am choosing now I am choosing a more blue-er blue. Now just use a reflected linear gradients on the center to start giving it a curved look. Now for the next part I added a radial gradient inside the tube with a blending mode to reflect or overlay. I also added a layer and filled it with diagonal lines and lowered the opacity. Finally, I added a cloud layer and played with blend bodes and erased around the tube. Then I added another radial gradient and set it to overlay to bring out the central colors in the tube. Now add some wires using jake2k's wire tutorial. At this point, my caps are very.. irregular. So I used the steps above when making my chrome caps to make an object behind the caps. This would be the connector. Now, again just add some more clouds and gradients to the tube to bring out the energy effect we have going on. Make it look.. dangerous. Save as whatever you wish. Then flatten, but make sure you have a transparent background. Now make a new layer on the very bottom of your signature. Make sure your colors are set light grey and a tad darker grey. (I will be using #E0E0E0 and #8E8E8E). Make a gradient. Your darker color should be the upper part of the gradient. Now, using the rectangle tool, make a dark grey (#404040) rectangle from the bottom up to about an inch above the bottom of the tube caps. (It may be more or less then an inch, but its just to give you a good idea.) Now duplicate your merged tube layer. Go to layer - flip vertically. Move it to where the top is touching the bottom of the regular tube. Then take your linear gradient tool and set it to :AlphaChannel:. Now hold your left mouse button and drag the notch up so that you achieve the basic Web 2.0 logo effect. Then lower the opacity on this layer until it looks like a good reflection. Now on your original tube layer again. Grab your magic wand tool. Hold shift and click anywhere on the layer where there are no pixels (click the transparent part). Then hit [ctrl]+. Make a new layer with your selection still active and then fill it with a dark grey (#404040). Then go to Effects-Blurs-Gaussian Blur and blur it from 6 to 10 pixels. You decide. Then move this layer below the other tube layers (even the reflection) and take the top notch and grab it and drag it down. This will virtually compress the grey blur into a shorter but same width blur. Then move it to where it looks like a shadow of the tube and play with opacity. Now repeat the past couple steps to achieve the same reflection and shadow effect with the text, but use a smaller setting for the gaussian blur on the shadow. Add a nifty border and your done! All feedback is welcome. Please let me know if there are any errors or anything. I know my edges are choppy for the caps, but oh well. This could have been easily fixed with feather (from BoltBait's plug in pack) but I was too lazy. Link to comment Share on other sites More sharing options...
pipp92 Posted December 18, 2008 Share Posted December 18, 2008 the blue thing is cool, but the metallic ends are really bad drawn (sorry^^) (why not use the line/curve tool) the tut is well written (maybe some here and there :LinearGradient: ) Personal Gallery Link to comment Share on other sites More sharing options...
TopHATslash Posted December 18, 2008 Author Share Posted December 18, 2008 Honestly? Wow. (Yes, I know they look dreadfully awful, but I am working on my mom's lap top. Its hard to steady anything without a mouse.) Link to comment Share on other sites More sharing options...
iKid Posted December 19, 2008 Share Posted December 19, 2008 Other than the edges being all :AntiAliasingOff: 'ed, nice job! Link to comment Share on other sites More sharing options...
TopHATslash Posted December 19, 2008 Author Share Posted December 19, 2008 Like I said, I was rushing to get it done at midnight last night. Post your results! Link to comment Share on other sites More sharing options...
pipp92 Posted December 19, 2008 Share Posted December 19, 2008 had a quick try :oops: the reflection is from my first try Personal Gallery Link to comment Share on other sites More sharing options...
PyroTechniques Posted December 19, 2008 Share Posted December 19, 2008 Why not use the Wet Floor Reflections plugin for the reflections? Photobucket Sucks! Link to comment Share on other sites More sharing options...
TopHATslash Posted December 19, 2008 Author Share Posted December 19, 2008 Because then its a wet floor reflection. Pipp, flatten your ijmage with transparent background and copy the whole tube and then unflatten and make a new layer then do the reflection. Using a different tube for the reflection doesn't make sense. Also, try messing with the caps. Right now they are very.. basic. Link to comment Share on other sites More sharing options...
mustang2500 Posted December 19, 2008 Share Posted December 19, 2008 I love the tube part, but for some reason the metal parts don't look right to me... But good work none the less! Link to comment Share on other sites More sharing options...
Goonfella Posted December 19, 2008 Share Posted December 19, 2008 This is my first go. I forgot to use selection for the reflection so its not as good as it could be and I need to practice my chrome. Â Â Please feel free to visit my Gallery on PDNFans And my Alternatives to PDN Link to comment Share on other sites More sharing options...
pipp92 Posted December 24, 2008 Share Posted December 24, 2008 Because then its a wet floor reflection.Pipp, flatten your ijmage with transparent background and copy the whole tube and then unflatten and make a new layer then do the reflection. Using a different tube for the reflection doesn't make sense. Also, try messing with the caps. Right now they are very.. basic. yeah i know it makes no sense, but hey it was a quick one i know they are basic but what is this Personal Gallery Link to comment Share on other sites More sharing options...
TopHATslash Posted December 25, 2008 Author Share Posted December 25, 2008 It could be realistic if I put effort into it. I was rushing to get it done because I was driving across the country. >.> Link to comment Share on other sites More sharing options...
LRT Posted December 26, 2008 Share Posted December 26, 2008 How do you make those caps? Anyway, good tutorial. Link to comment Share on other sites More sharing options...
K_I_N_G Posted January 2, 2009 Share Posted January 2, 2009 He posted a link to the tutorial that shows you how...read carefully. Bloody Tentacles Tut (fixed link) My gallery Link to comment Share on other sites More sharing options...
K_I_N_G Posted March 1, 2009 Share Posted March 1, 2009 I am surprised there isnt any more posts on this. Really good tutorial, well-written and exactly what I needed. Thanks. Bloody Tentacles Tut (fixed link) My gallery Link to comment Share on other sites More sharing options...
TopHATslash Posted April 6, 2009 Author Share Posted April 6, 2009 No problemo. Link to comment Share on other sites More sharing options...
