TheKoolKid1O1 Posted August 10 Share Posted August 10 I'm trying to use the add noise effect to randomly generate unique pixels, however i want the specify the range of colors it can randomize from, nothing too specific, just something like "0,0,0 to 200,200,200", in which it would not be able to add any colors above the rgb value of 200,200,200. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 10 Share Posted August 10 If you want 0-200, I think you can do it in two steps: 1. Run Add Noise. Might need to set saturation to max value. You should verify it's generating values across the full 0-255 range. 2. Use Adjustments -> Curves, and move the top-right node down until it reaches y=200, like this Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 10 Share Posted August 10 Might also be able to do it with two layers, which would avoid the need to use Curves. On the bottom layer, it should be filled with black. The top layer, where you run Add Noise, should have its Opacity set to 200. The top layer will still have values in the 0-255 range, but if you Merge Layer Down, or Flatten, you should be left with values in the 0-200 range. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Rick Brewster Posted August 10 Share Posted August 10 btw, @toe_head2001, this is something that the node editor would be great for. The first node would be the PdnAddNoiseEffect, which would then pipe into an HlslBinaryOperatorEffect with Parameter1=Input, Input1=PdnAddNoiseEffect, Operator=Multiply, Parameter2=Value, Value2=Vector4Float(200.0f / 255.0f ~= 0.784313) Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 11 Share Posted August 11 Aside: Add Noise doesn't work on a transparent layer, correct? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
