I want to keep left click function fixed to color pick too.
I want to keep left click function fixed to color pick tool. Can it be done in paint.net
I mean I always want to pick color  with right click. I donot want to click color pick tool again and again to copy colors.
On my computer, left click is already for the color picker function.
There is a list of functions found here:
https://www.getpaint.net/doc/latest/KeyboardMouseCommands.html
If you look under Settings (the gear wheel icon) you can change what happens after you click the color picker: 'Do not switch tool', 'switch to previous tool' or 'switch to pencil'.
I hope that is what you meant?
When using the color picker on an image a left click sets the primary color and a right click set the secondary.
However this does not apply to the palette color wheel... which personally I find annoying and irrational?... I expect there is good reason though!😉
@aijaz
What you want is not possible.
You can use the keyboard shortcut K and have
Color Picker set to Switch to previous tool.
I agree.
If so, I'd like to know that reason.
