sansuamorera Posted October 8, 2021 Share Posted October 8, 2021 Hello Everyone! I hope you are all doing good! I am a Minecraft Texture Pack Maker and I need help finding a plugin. Like Aseprite, I need a Tiling Mode, so I can make seamless blocks for textures better. Why I don't just use Aseprite? I just find it quite hideous with its interface and style of brushes and the whole UI, so I get very frustrated using it, so I prefer paint.net. I do not know if the following image explains what I'm looking for, but I'm looking for a plugin that helps me tile textures in real time, that in each square of canvas draws with every pen or brush, I don't know if I made my self clear. If you find anything very similar to this, I would greatly appreciate it! Quote Link to comment Share on other sites More sharing options...
toe_head2001 Posted October 9, 2021 Share Posted October 9, 2021 That kind of real-time tiling is not possible in paint.net. Both Krita and GIMP have the feature though. 1 Quote (September 25th, 2023) Sorry about any broken images in my posts. I am aware of the issue. My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted October 9, 2021 Share Posted October 9, 2021 Try this: 1 Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
otuncelli Posted October 9, 2021 Share Posted October 9, 2021 (edited) Hi @sansuamorera, Did you try Layers->Rotate/Zoom? (CTRL+Shift+Z) It has a Tiling option. You may need to work on a large canvas for creating the main image to get a high quality result. Then, zoom-out while Tiling option is checked. Still not realtime though. Edited October 9, 2021 by otuncelli 1 Quote Link to comment Share on other sites More sharing options...
