tamificko909 Posted September 25, 2021 Share Posted September 25, 2021 I try to open dds format file on 4.3, I try to reinstall but doesnt work. Here the log file [https://pastebin.com/vLsbKvUS] Quote Link to comment Share on other sites More sharing options...
BoltBait Posted September 25, 2021 Share Posted September 25, 2021 You'll need to zip up the DDS file and share it here as well. (Just be sure it is "family friendly".) Quote Click to play: Download: BoltBait's Plugin Pack | CodeLab | and how about a Computer Dominos Game Link to comment Share on other sites More sharing options...
tamificko909 Posted September 25, 2021 Author Share Posted September 25, 2021 Im uploaded to drive because is too large.https://drive.google.com/file/d/1UqM9byA0ERYJp7mmmUGrEcnc87_3uEtM/view?usp=sharing And I have many many bus templates in dds format it used to be good but now none open. Quote Link to comment Share on other sites More sharing options...
null54 Posted September 25, 2021 Share Posted September 25, 2021 12 minutes ago, tamificko909 said: I have many many bus templates in dds format That file is a BMP file with a DDS extension, it opens in Paint.NET if you change the file extension to BMP. 1 Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
