msh Posted September 28, 2020 Share Posted September 28, 2020 I have the following image: and as you can see there are transparent lines between the circles. I want to fill them so they'll match the border (either the outer or the inner, doesn't matter). How can I do that? Quote Link to comment Share on other sites More sharing options...
Djisves Posted September 28, 2020 Share Posted September 28, 2020 This should help you fill the gap without much fuss: Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 28, 2020 Share Posted September 28, 2020 Sadly @msh your background on this image is not really transparent, so @MJW's Edge Expander will not work properly on this. The best thing would be to have a layer below the image, with the color you want, and then flatten it. However I've tried to remove the background on this site, https://www.remove.bg/ but it removes most of the gray gradient. Hopefully someone will have an idea of how to do this. I will keep thinking too 🧐 Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
LoudSilence Posted September 28, 2020 Share Posted September 28, 2020 (edited) Duplicate layer, on the lower one, select the image and make it smaller, fill remaining gaps with the line tool, use magic wand to select the transparency, invert selection, and fill selection with the border color you want. A little confusing since its hard to word, but i hope this helps Edited September 28, 2020 by LoudSilence Quote Unofficial PDN Discord Server Link to comment Share on other sites More sharing options...
msh Posted September 28, 2020 Author Share Posted September 28, 2020 @Pixey I'm not sure what you mean by the background is not really transparent. The image I showed is a screenshot and the bakground contains colors because the transparent pixels aren't really transparent in a ss, but rather the actual cube paint.net renders on transparent pixels. but thx anyway! @Djisves I actually tried the plugin and it worked - thanks! Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 28, 2020 Share Posted September 28, 2020 2 minutes ago, msh said: The image I showed is a screenshot Aah - I copied and saved it and it had a checkered background. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
