oma Posted September 3, 2008 Share Posted September 3, 2008 so I'm having a brain sneeze here folks. holding control key down and hitting the arrow key with the move tool active after multiple hits of arrow key splits my image or shall I say looks like it will continue repeating my image as I move up the screen? Is this normal behaviour? I never noticed it before. Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
toe_head2001 Posted September 3, 2008 Share Posted September 3, 2008 Yes, It's supposed to do that. Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
oma Posted September 3, 2008 Author Share Posted September 3, 2008 you are sure? I can't recall this happening before. could explain why I always have to go back and clean up those pesky stray pixels..... so is there a current list of the shortcuts somewhere I've been all thru using search and can't find it. (so I know its somewhere real easy to find and I'm just not using the correct word) thanks Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
toe_head2001 Posted September 3, 2008 Share Posted September 3, 2008 Never mind, I read your post incorrectly. :oops: Quote My Gallery | My Plugin Pack Layman's Guide to CodeLab Link to comment Share on other sites More sharing options...
oma Posted September 3, 2008 Author Share Posted September 3, 2008 saw that one I was looking more for the list that has something like hold Shift while rotating etc will contain it to certain angles and moving more than one space at a time left right up or down requires use of shift? or is it control? + arrow keys. that list I can not find and I know I've seen one. ciao Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
bEPIK Posted September 3, 2008 Share Posted September 3, 2008 Is this the list? And what I do so that I don't Have a duplicate of my moved image is press just the arrow key and then press ctrl+arrow how ever many times I want. Quote Water, Wood and Hair Tutorial Link to comment Share on other sites More sharing options...
Max Power Posted September 3, 2008 Share Posted September 3, 2008 if you hold down ctrl the image will move 5 pixels per click on an arrow key, and the image will be copied. If you don't press ctrl your image will move only 1 pixel per click. If you want to move the image 5 pixels without copying it, reset the selection every now and then. The image will only appear outside of the selection, so just make the selection bigger. Quote - My Gallery | My Deviant - Link to comment Share on other sites More sharing options...
Max Power Posted September 3, 2008 Share Posted September 3, 2008 Often it's easier to move the whole image with the mouse and apply the Align Object plugin after that. Quote - My Gallery | My Deviant - Link to comment Share on other sites More sharing options...
oma Posted September 3, 2008 Author Share Posted September 3, 2008 perhaps if you want to align to the 9 points upper left, upper mid, upper right, mid left, middle, mid lrightt, lower left, lower mid, and lower right most times I'm tilting it and looking for more precise placement.... Quote My Deviant Art Gallery Oma's Paint.Net gallery Link to comment Share on other sites More sharing options...
Ash Posted September 3, 2008 Share Posted September 3, 2008 Paneling plugin Quote All creations Ash + Paint.NET [ Googlepage | deviantArt | Club PDN | PDN Fan ] Link to comment Share on other sites More sharing options...
