Tuckeroo Posted September 6, 2019 Share Posted September 6, 2019 I am having problems when I attempt to change the resolution from 300 to 150 when I resize an image. I can change the resolution in the box and hit the ok button. But if I go back into resize, the resolution is back to 300. Quote Link to comment Share on other sites More sharing options...
IHaveNoName Posted September 6, 2019 Share Posted September 6, 2019 I not been able to recreate that problem. Whatever resolution you chose in Resize should save and be applied to all layers when you click OK. What version of PDN are you using? Quote Link to comment Share on other sites More sharing options...
Tuckeroo Posted September 6, 2019 Author Share Posted September 6, 2019 (edited) Hmmm. I still can't get it to work. I have version 4.2.1 The same thing happens (or doesn't happen!) when I try to change the resolution under canvas size. Edited September 6, 2019 by Tuckeroo tried canvas size Quote Link to comment Share on other sites More sharing options...
Pixey Posted September 7, 2019 Share Posted September 7, 2019 I too cannot recreate the problem you are having. Please try this, if you have the Classic version of Paint.net. OS (C:) – Program Files – Paint.net – scroll down to the PdnRepair.exe and run it. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Tuckeroo Posted September 8, 2019 Author Share Posted September 8, 2019 Thanks so much Pixey for taking the time to answer. I ran PdnRepair.exe but unfortunately, that didn't work either. But it does seem to apply only to some of my files. Just in case anyone gets the same problem, I did find a workaround. I created a new image with the right resolution and dragged the pdn file to open as new layer(s) on top of that. Then I could save in the correct resolution. Quote Link to comment Share on other sites More sharing options...
