Techineer Posted August 4, 2019 Share Posted August 4, 2019 Is it possible to create a drawing element such as a line or circle using the desired coordinates of whatever measurement system is in use? I have searched the forums and haven't been able to find an answer. This would be particularly useful for line drawings. For example, if I have a canvas of 8.5x11", and I would like to specify a line to start from x=1.00", y=1.50' and end at x=7.00" and y=1.50"; or maybe a circle with a center at x,y and a radius of r (or diameter, or point on the perimeter). ...or move selected elements to a specific coordinate location, or to move them by a specified distance and direction. I know, it is possible to do this with the mouse, but it is extremely difficult to get a mouse to be precise enough and to target a location in two dimensions simultaneously. And when moving objects, you cannot identify the pixel location of any particular point on the element because the handle is outside the selected element. If the feature is not available, please consider it for a future version. The user interface might consist of a right-click on the tool image that would open a dialog box with fields to specify start, end and other options. Quote Link to comment Share on other sites More sharing options...
MJW Posted August 4, 2019 Share Posted August 4, 2019 Perhaps you could create Scalable Vector Graphics files, then use the plugin to render in in PDN. SVG files are XML based, so they can be created with a text editor. Also, read BoltBait's How to make custom shapes for paint.net. Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted August 4, 2019 Share Posted August 4, 2019 1 hour ago, Techineer said: I know, it is possible to do this with the mouse, but it is extremely difficult to get a mouse to be precise enough and to target a location in two dimensions simultaneously. Use the arrow keys for fine control of the pointer placement. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
