Sign in to follow this
Rickenbacker
How to "posterize"?
Although Avedon used solarization and CMYK layering, the Beatles graphic contains a bunch of manipulation and most of it is subjective to the artist and the process and will not be easily achieved with a few settings to a plugin in. It was an artistic endeavor that took time and subjective choices, just as you are now discovering. My advice is not to do Avedon, but to do you!
Don't worry about Avedon! He was working in a different mediums, photography and commercial printing technology of the late 1960's. CMYK is about preparing works to be commercially printed. Play with the image and software and make something personal and special. Your work in RGB can be converted to CYMK when it is ready to go to print.
Edited by HyReZ
inserting additional information
Share this post
Link to post
Well, I was making a new cli command that does modulo operations for the g'mic plugin (which is available here), and I experimented. I think I got close to the OP needs. I forgot some of the steps though. But I"ll probably remember. All done with G'MIC. If I do remember the step, I'll definitely recreate what I did and turn it into a G'MIC filter. I think it is just solarization of channels and a little bit more manipulation for the most part. Solarization is available here.
Also, saving this for later. This is just a reference for later use.
rgb2lch8
mod_ops 3,255,{(128/2)/255},1
lch82rgb
Edited by Reptillian
Share this post
Link to post
Definitely harder than it looks this.  Got it more posterised than solarised 🙄😕
Share this post
Link to post
@welshblue
After over a dozen layers and about a half dozen effects plugins; this what I came up with after 8 iterations and about 2.5 hours of experimentation and editing down to the pixel level.
This is iteration 8. I liked the colors in iteration 7 but the face was not as recognizable. To get this; I used the built-in Adjustments/Hue /  Saturation  effect on iteration 7, and adjusted the Hue slider by tiny increments to find this final color range.
(I am looking for an easier method. This project helped! 🙂)
Edited by HyReZ
Correcting spelling and adding more nfo!
Share this post
Link to post
29 minutes ago, HyReZ said:
(I am looking for an easier method. This project helped! 🙂 )
If you haven't tried pyrochild's Gradient Mapping plugin, you might want to experiment with it. It lets you map image intensity levels (among other things) to colors. If you already have it, as part of pyrochild's plugin pack, it will be in the Adjustments menu.
Share this post
Link to post
@MJW
I had it installed but was not aware of its use. I have just tried it. I does give me an additional set of options. Thanks for the information!
Edited by HyReZ
Share this post
Link to post
I placed my image that I just posted above over the 7th iteration and erased the jersey so that the bottom layer image jersey was revealed. I then feathered the edges of top layer and merged it down to get this new iteration number 9.
Edited by HyReZ
Share this post
Link to post
