Stefan_l_01 Posted July 25, 2018 Share Posted July 25, 2018 Hi There is an issue saving custom tiff tags: "double" array changes to "undefined" (see "orig" tag attach to "saved"). Note: Double Arrays are saved with field_passcount = TRUE, first param before data is fieldcount! (e.g. libtiff: TIFFSetField(PTiff, MY_CUSTOM_DATA, 5, Data)) I can not say whether it happens also for a single double or other Array data types. I added a tiff with custom tags so you can try out. Best regards Stefan test.zip Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 25, 2018 Share Posted July 25, 2018 On 7/11/2011 at 12:14 PM, Ego Eram Reputo said: TIF support in paint.net is minimal and provided on a "Gee if it works - that's great" basis ( http://forums.getpaint.net/index.php?/topic/19468-lab-color-space/page__view__findpost__p__330287) This means that there is unlikely to be a change in the way PDN handles TIF images. Especially since you're using custom tags. Do you really, really, really need to use TIF? Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Stefan_l_01 Posted July 27, 2018 Author Share Posted July 27, 2018 Of course I need tif. It would be ok ( for me at least) to ignore the custom tags when saving (save without them), but saving them WRONG what gives me errors trying to load the tif is an issue. Quote Link to comment Share on other sites More sharing options...
Rick Brewster Posted December 2, 2019 Share Posted December 2, 2019 BTW this probably works a lot better in the latest version (currently 4.2.7). I've put in a whole bunch of metadata related work into the 4.2 series of updates. Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
