SilverDragon82 Posted June 10, 2018 Share Posted June 10, 2018 Is there a way to find plugin packs with installer available? ones that have a lot of effects to it? I am haveing difficulties adding the plugins I down load and the ones that work the best are the ones with the installers. Would anyone have any suggestions with the packs? Also I used to have over 100 on my last computer and now i cant even have as many cause I cant extract what i need to paint or even copy to paint.net file folder. Quote Link to comment Share on other sites More sharing options...
Pixey Posted June 10, 2018 Share Posted June 10, 2018 @SilverDragon82 Welcome to the forum You say you're having trouble adding Plugins to your folder? Do you have the Store bought Paint.net? If so, you have to make the Folders yourself. " You just have to install them in a different location. Go to your Documents folder, create a folder called “paint.net App Files” (no quotes though), and then create a folder for each plugin type: Effects, FileTypes, and Shapes. And then put your plugins into each folder just like you’re used to with the Classic release." As for Plugin packs with the installer - that will depend on who uses the installer. Older packs will probably not have that option. Quote How I made Jennifer & Halle in Paint.net My Gallery | My Deviant Art "Rescuing one animal may not change the world, but for that animal their world is changed forever!" anon. Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted June 10, 2018 Share Posted June 10, 2018 5 hours ago, SilverDragon82 said: Is there a way to find plugin packs with installer available? Go here >> Plugin Pack forum << and look for the threads with a star. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
