Floating window plugin - help
Gregos
Hi guys,
I recently started writing a filetype plugin of mine for personal use, exporting multiple txt files(based on pixel data) in a single zip. Thanks to the grate info in the forum it's coming together nicely.
However, I would like to complement it with another plugin that adds a floating window like the Colors/Layers/Tools window(basically containing multiple icons with hard-coded presets for primary and secondary colors... however silly it may sound).
I found 1-2 old threads that mention it is possible but nothing concrete. Is that still possible? Are there any VS templates I might use? I saw in one thread an alternative colorwheel plugin but could not find sources.
Sorry, plugins can't do that; never could.
Here's some more information on the matter:
https://forums.getpaint.net/topic/14566-what-is-and-isnt-possible-when-writing-plugins/
Thanks for the response. I was referring to this old post:
 https://forums.getpaint.net/topic/9121-new-floating-window-disappears/?tab=comments#comment-148730
but I guess it might be from back when PDN was still open.
Anyway... Forgive my noobishness... from what I read in the post you linked I guess it's not possible to create a non-modal effects window. Is that correct?
Also, is there some form class/interface that can be inherited to achieve similar look to the floating windows? Or code examples maybe?
On a somewhat different note(so I know I'm not wasting my time)... I assume there are some application-wide properties to change the primary and secondary colors from within the plugin?
Thanks again for the help. :)
Plugins can not change the primary and secondary colors.
