flamerboy67664 Posted April 6, 2016 Share Posted April 6, 2016 So I am a repainter for planes in Microsoft Flight Simulator X. I am creating a bare metal texture for an airplane and I need to do something like a "transparent alpha mask" For example this Quote Link to comment Share on other sites More sharing options...
IRON67 Posted April 6, 2016 Share Posted April 6, 2016 (edited) Every new layer is transparent and you can change the opacity of every layer by using "Layer Properties" (F4). Where exact is your problem by doing this? Notice: Save your image as PNG to preserve the Alpha-Channel. Edited April 6, 2016 by IRON67 Quote Link to comment Share on other sites More sharing options...
flamerboy67664 Posted April 6, 2016 Author Share Posted April 6, 2016 I need to use DDS or FSX won't recognize the files Quote Link to comment Share on other sites More sharing options...
IRON67 Posted April 6, 2016 Share Posted April 6, 2016 You should explain it better. I don't know, what DDS means. A short Google trip brings it together with TGA files. This filetype uses Alpha Channel too. Quote Link to comment Share on other sites More sharing options...
NinthDesertDude Posted April 6, 2016 Share Posted April 6, 2016 (edited) I'm not sure if the image is displaying what you have, what you want, or both. Here are some plugins that might (or might not) help. The Alpha Mask plugin uses a file as an alpha map for the current drawing. The Channel Ops plugin lets you perform basic operations with channels, including the alpha channel. It can set alpha or map channels to alpha, namely. The Alpha Threshold plugin lets you change gradients of alpha, in case you go with the previous two methods but want the image to be proportionately more opaque/transparent. Edited April 6, 2016 by AnthonyScoffler Quote Link to comment Share on other sites More sharing options...
null54 Posted April 6, 2016 Share Posted April 6, 2016 The easiest way to edit FSX textures with Paint.NET would be to load the texture with DXTBmp and export the color image to Paint.NET. This would allow you to edit the texture separately from the DDS alpha channel, which Paint.NET merges with the main image when it loads DDS files. Quote Plugin Pack | PSFilterPdn | Content Aware Fill | G'MIC | Paint Shop Pro Filetype | RAW Filetype | WebP Filetype The small increase in performance you get coding in C++ over C# is hardly enough to offset the headache of coding in the C++ language. ~BoltBait Link to comment Share on other sites More sharing options...
IRON67 Posted April 6, 2016 Share Posted April 6, 2016 After clicking around I noticed that PDN can save Images as DDS files with a huge amount of saving-options (see screenshot). Maybe it's wise, to check out, which of these options are used in original and working files you already have. Quote Link to comment Share on other sites More sharing options...
