signatures and avatars
i've read several tuitorials and still do not understand how to use my signature and avatar. i made it, uploaded to photobucket and had the following assigned to it. http://s281.photobucket.com. how do i get it back to and use it on paint.net
thank you james
Did you read viewtopic.php?f=15&t=6270 ??
If not, please remember to look around and try using search next time.
I did read myrddins tuitorial. on # 7 it says for posting your image insert it into a set of image tags url. does that mean to do this. bluewolf.jpg
do i need to do this in my post area for it to transfer it.
i guess it did, the image showed up in the post. :shock: does that mean it will show up under my user name when i post. thanks
ok now you copy the tag (the img in square brackets) and go to your User control panel (top of the page) :arrow: profile tab :arrow: avatar tab (am I correct?) there should be a space. Paste the Img tag there so it should look like this:
(Img)the url for the image should be here(/Img)
Note: I used normal brackets instead of square ones because I wasn't sure if they would show up.
I hope this helps!
"Confusion is the welcome mat at the door of creativity." -Michaul Gelb
My Gallery Check it out!
