For some reason this crashes sometimes, always with the same error message, I don't know if there's a problem with this and Olden, but it seems like it since Olden runs just fine
File: C:\Program Files\Paint.NET\Effects\Random Effect.dll
Effect Name: pyrochild.effects.randomeffect.RandomEffect
Full error message: PaintDotNet.WorkerThreadException: Worker thread threw an exception ---> System.IndexOutOfRangeException: Indekset lå uden for arrayets grænser.
ved PaintDotNet.Effects.UnfocusEffect.Apply(ColorBgra src, Int32 area, Int32* hb, Int32* hg, Int32* hr, Int32* ha) i D:\src\pdn\pdn_35x\src\Effects\UnfocusEffect.cs:linje 124
ved PaintDotNet.Effects.LocalHistogramEffect.RenderRect(Int32 rad, Surface src, Surface dst, Rectangle rect) i D:\src\pdn\pdn_35x\src\Effects\LocalHistogramEffect.cs:linje 203
ved PaintDotNet.Effects.UnfocusEffect.OnRender(Rectangle[] rois, Int32 startIndex, Int32 length) i D:\src\pdn\pdn_35x\src\Effects\UnfocusEffect.cs:linje 181
ved PaintDotNet.Effects.Effect`1.Render(Rectangle[] renderRects, Int32 startIndex, Int32 length) i D:\src\pdn\pdn_35x\src\Effects\Effect`1.cs:linje 57
ved PaintDotNet.Effects.Effect`1.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length) i D:\src\pdn\pdn_35x\src\Effects\Effect`1.cs:linje 100
ved Olden.Olden.RenderUnfocus(RenderArgs dst, RenderArgs src, Rectangle[] rois, Int32 startIndex, Int32 length)
ved Olden.Olden.OnRender(Rectangle[] rois, Int32 startIndex, Int32 length)
ved pyrochild.effects.randomeffect.RandomEffect.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois, Int32 startIndex, Int32 length)
ved PaintDotNet.Effects.Effect.Render(EffectConfigToken parameters, RenderArgs dstArgs, RenderArgs srcArgs, Rectangle[] rois) i D:\src\pdn\pdn_35x\src\Effects\Effect.cs:linje 211
ved PaintDotNet.Effects.BackgroundEffectRenderer.RendererContext.Renderer(EffectConfigToken token) i D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:linje 128
--- Slut på staksporing af indre undtagelser ---
ved PaintDotNet.Effects.BackgroundEffectRenderer.DrainExceptions() i D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:linje 372
ved PaintDotNet.Effects.BackgroundEffectRenderer.Abort() i D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:linje 328
ved PaintDotNet.Effects.BackgroundEffectRenderer.Start() i D:\src\pdn\pdn_35x\src\PaintDotNet\Effects\BackgroundEffectRenderer.cs:linje 275
ved PaintDotNet.Menus.EffectMenuBase.<>c__DisplayClass1d.<>c__DisplayClass21.<RunEffectImpl>b__10() i D:\src\pdn\pdn_35x\src\PaintDotNet\Menus\EffectMenuBase.cs:linje 827
Edited by Cookies, 06 September 2010 - 01:43 PM.
