jw311 Posted November 10, 2015 Share Posted November 10, 2015 hi all. brand new guy here trying to fix a jpg I got from a designer. basically part of the logo has been filled in white instead of allowing transparency so when I place the logo over a dark back ground it shows white . Any idea how to fix with paint? see below Quote Link to comment Share on other sites More sharing options...
Cc4FuzzyHuggles Posted November 10, 2015 Share Posted November 10, 2015 (edited) You need png, jpgs don't save transparency. Are you able to get a png version that does have a transparent background? If not, you will probably have to try some color removing plugins and then save the image as a png yourself. Edited November 10, 2015 by Cc4FuzzyHuggles Quote *~ Cc4FuzzyHuggles Gallery ~* Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 10, 2015 Share Posted November 10, 2015 Hi jw311 - welcome to the forum I recommend you go back to the designer and tell them you need a transparent background (i.e. not a jpg). I can't quite believe they would supply something like a logo as a jpg..... Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
jw311 Posted November 17, 2015 Author Share Posted November 17, 2015 (edited) ok I am an idiot they sent me .png files. One color, one black and white and one all white. Also an .eps file. How can I modify the transparncy here is the screenshot http://awesomescreenshot.com/0095euqf16 Thanks again to all who help the hapless....and the helpless. Edited November 17, 2015 by jw311 Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted November 17, 2015 Share Posted November 17, 2015 Open the .PNG file. Activate the Magic Wand Hold down the Shift key and click on the white region. Adjust the tolerance in the tool bar to fine tune (maximize) the captured white pixels. Press the Delete key. Use File > Save As... to save a copy under a different file name. You still want to use a PNG format. Good luck! Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Eli Posted November 17, 2015 Share Posted November 17, 2015 (edited) Not only the inside of the letter R is white (not transparent) but there are also some lines missing. Ask the designer to send you a corrected logo. Edited November 17, 2015 by Eli Quote Link to comment Share on other sites More sharing options...
