Redd Posted July 6, 2014 Share Posted July 6, 2014 http://www.youtube.com/watch?v=e0beXxdHc6A. I also got this bug while using Paint.NET 4 beta and I thought that you will notice and fix it. I use Paint.NET 4.0.5288.36565 (last version). What should I do to fix it? Quote Link to comment Share on other sites More sharing options...
Ego Eram Reputo Posted July 6, 2014 Share Posted July 6, 2014 What you're seeing is the image rendering lag. When you pause the tiling catches up and displays the image correctly. What can you do? 1. move your mouse more slowly - I'M JOKING 2. Try disabling Hardware Acceleration ( = Settings > User Interface ). If this works for you - please copy the contents of the Settings > Diagnostics tab into this thread so we can see what your setup is. Quote ebook: Mastering Paint.NET | resources: Plugin Index | Stereogram Tut | proud supporter of Codelab plugins: EER's Plugin Pack | Planetoid | StickMan | WhichSymbol+ | Dr Scott's Markup Renderer | CSV Filetype | dwarf horde plugins: Plugin Browser | ShapeMaker Link to comment Share on other sites More sharing options...
Rick Brewster Posted July 7, 2014 Share Posted July 7, 2014 This isn't a bug. This is just how an asynchronous rendering engine works. Rendering is done tile by tile and if your computer isn't fast enough* then you won't see everything update at once. This pays off dividends with larger images because the application will be much more responsive since you won't have to wait for everything to finish rendering before seeing the results. EER, disabling hardware acceleration won't help and will probably hinder performance and make this subjectively worse You should only disable it if you're seeing visual artifacts! or if, for some reason, it really is actually faster on a particular system. * no computer is fast enough Quote The Paint.NET Blog: https://blog.getpaint.net/ Donations are always appreciated! https://www.getpaint.net/donate.html Link to comment Share on other sites More sharing options...
